Old 09-28-2010, 01:37 PM   #51
Odyknuck
Member#: 192866
2006 Impreza
So what areas did you tune to get rid of the Backfire. Also did you need to go rich or lean.
Odyknuck is offline   Reply With Quote
Old 09-28-2010, 04:03 PM   #52
thumpetto007
Member#: 156358
2001 Miata LS
Gay Blue
So I read through this thread, and still haven't answered the question I have.
I have a 2001 2.5rs and am doing a turbo build. I need 1200cc injectors, and am still researching what I need.
I will be using the 2001 intake manifold. Aren't there high flowing injectors that fit and work perfectly without modification?
Thanks.
thumpetto007 is offline   Reply With Quote
Old 09-28-2010, 04:22 PM   #53
Skidd
Member#: 1853
GC6 Supercharged
STM
Originally Posted by Skidd View Post
The problem isn't the flow rate or availability of options.
It's the dang intake manifold design of the 00-01 EJ251 and the damn AirAssist ports!
Nobody, I repeat Nobody makes a high-flow replacement designed for that Manifold.
Perhaps this post didn't answer your question? Or you missed it.
But, no. Nobody makes a direct replacement.
WRX injectors can be made to work, but very minor modifications (O-Rings and AirAssist plugging). You don't "need" to hog out the ports like on the previous posts. It's just helpfull.
So, go find some 1200cc injectors designed to fit the top feed WRX, and grab a bag of Injector ORings.
Skidd is offline   Reply With Quote
Old 01-04-2013, 04:12 AM   #54
Zefy
Member#: 105104
1979 BRAT / 01 RSTI
99 2.5TS (DEAD)
sorry to bump up this old thread but I'm currently installing some wrx 440's into my RS manifold. Just wanted to confirm what I'm doing is reasonable and also get some pictures out there that are a little more specific.
so just for reference, stock RS injector
Here is a picture of my stock wrx injector with the 'proper' o-rings setup I have chosen from my selection of o-rings. The top two are from the stock RS injector. The little one in the middle isn't really needed but i thought it might keep debris and stuff from getting inside the fuel rail. The bottom o-ring is the stock wrx one.
This o-ring seems to cover the air assist port fully.
Here it is installed in the stock RS rail. Also installed is a stock RS injector just for reference.
And here it is installed in the manifold. Note I can't use the injector clip as the wrx one is different.
Also from underneath...
Is this right?
Zefy is offline   Reply With Quote
Old 01-04-2013, 03:42 PM   #55
akfmx
Member#: 226059
Icy Silver
Legacy
Based on my own research, I don't think you will be able to use the bottom wrx o-ring like that. I have never heard of anyone doing that. I hope someone else chimes in because I too am trying to find the right o-ring setup for wrx blues in a MY 2000 air assist manifold.
I guess if nothing else you could try it out and see if that wrx o-ring seals the injector to the manifold with no leaks.
akfmx is offline   Reply With Quote
Old 01-04-2013, 11:26 PM   #56
retrac
Member#: 217208
2001 Porsche 911
LSx Twin Turbo
I used wrx o-rings. The air assist stuff was removed and filled/plugged from the outside with Right Stuff RTV.
retrac is offline   Reply With Quote
Old 01-05-2013, 05:44 AM   #57
Zefy
Member#: 105104
1979 BRAT / 01 RSTI
99 2.5TS (DEAD)
what did you use for the top? Stock RS ones?
I was looking around and there was a few posts about a rallitek o-ring kit for doing this swap. I phoned them today and they still carry them. Just curious if it's really necessary. Probably a good idea to replace anyway (mine are used) but its just a pain getting them.
Old 02-17-2013, 10:07 PM   #58
rs_sedan
Member#: 323517
2000 2.5RST
Stm, one day Wrb
I believe some users over on rs25 were having issues withe the rallitek kit
rs_sedan is offline   Reply With Quote
Old 02-18-2013, 12:25 AM   #59
Zefy
Member#: 105104
1979 BRAT / 01 RSTI
99 2.5TS (DEAD)
ya... i am...
Using 06 wrx clutch in 2000 RS? KONKILR Transmission (AT/MT) & Driveline 10 10-15-2009 11:49 AM
WRX Injectors in 2000 RS what am I missing? Aphex28 Normally Aspirated with bolt-on Forced Induction Powertrain 4 07-15-2006 12:48 PM
Do I need a WRX Fuel rail to run WRX injectors in an RS-T? Tattoo Collector Normally Aspirated with bolt-on Forced Induction Powertrain 10 01-14-2006 10:06 AM
fuel injectors for 2000 rs brokemypiston Normally Aspirated with bolt-on Forced Induction Powertrain 6 03-17-2003 08:11 AM
02 WRX Injectors in my RS-t? Kinda Important! adamsrs Normally Aspirated with bolt-on Forced Induction Powertrain 1 03-05-2002 03:25 AM
