Old 08-22-2003, 10:54 AM   #1
Scooby South
Subtly Outspoken
Member#: 238
99 Ver6 Recreation
JDM Speedwagon 3 LSDs..:)
Default USDM 2.0motor CLOSER to radiator
Well last night I did some Tweeks on some things....connected the fuel lines, Mounted the Boost Solinoid, mounted the Belt cover, connected my Brake booster.....then I noticed that the front of the USDM 2.0 is WAY closer to my radiator...have a 1.5 inches of clearance...from the fans...where the 2.5 sat back in the engine compartment about another 2 inches....is THIS normal???? Car has never been hit...Hence the reason the stock RS Radiator hoses don't fit.......
Can some one take a picture of the front of their motor looking down toward the fans...
Thanks..
Bill
Old 08-22-2003, 02:03 PM   #2
Crawford/I-Speed
Vendor
Member#: 12347
ECU ReProgramming
Dynapack AWD Dyno
Crawford/I-Speed is offline   Reply With Quote
Old 08-22-2003, 02:26 PM   #3
garface
Member#: 1581
MY00 RS/STi7
MY01 RS Both Silverthorne
Yea, this surprised me too. Here's a crappy picture that kind of shows it. I took the picture for another reason(coolant coming our of cap and hose ruptured), but you can see the belt on the left and the radiator fans so you can see this distance. Apparently it's perfectly normal. But is it only the GD engine in the GC chassis that does this or is it any 2.0 from any year? I have tons of room behind my STi intercooler even though I have a Cusco bar, so I don't know if a GC8 engine would sit differently.
garface is offline   Reply With Quote
Old 08-22-2003, 03:28 PM   #4
AWJunkies
Member#: 32934
99 2.5RS JDM WRX
WOW you guys are pretty snug in there. I did JDM 2.0 swap and used JDM radiator in my GC8 and have lot more room than you on top. The bottom is where it is close for me. My plugs sit on the heat shields. I also had 2.5rs radiator in there and wasn't like that. I used the stock JDM hoses and had no problem. Heard you had to modify them if you use stock US is that true?
AWJunkies is offline   Reply With Quote
Old 08-22-2003, 03:46 PM   #5
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
This should be very interesting. I'm installing a 38mm core radiator in there for my swap. Hope it fits. Looks like I might be removing the radiator to do anything with the belts.
I-Speed (or anybody for that matter), do you guys have some pictures of engine bays with USDM engines installed?
-Jon
95 jdm 2.5 non turbo to a usdm 2.5 non turbo wireharness c1poweredeg Subaru Conversions 2 11-04-2008 01:28 AM
Gettin closer to 10's... [email protected] MARKGSTI Proven Power Bragging 136 10-06-2006 07:53 PM
doing a 02 usdm 2.5rs to 02 usdm wrx simprezl25 Subaru Conversions 1 01-12-2006 12:52 AM
US 2.0motor rev to 7.5k Blackpantherwrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 06-05-2005 08:22 PM
Getting closer to the 2.5l turbo swap. Solomon Legacy Forum 3 08-05-2003 02:53 PM
