Old 08-22-2003, 02:17 PM   #1
Craig W
Member#: 643
1999 2.5RS
WRX powered
Question Lots of misfire CELs
Hey all,
I've got an '02 WRX engine, only mods are a gutted up-pipe, k&N panel filter and light weight flywheel. I've had it since February.
Starting about two months ago, I've been getting CELs for P0301, P0302 and P0303, misfires on 1st, 2nd and 3rd cylinders.
Almost always happens when the car is still warming up, idling at the first stop light from my home, (about 1/8-1/4 mile). I've also gotten the CEL using engine braking down the parking garage ramp as I'm leaving work.
I'd occasionally get these CELs about once every couple months, but now they're happening more frequently within a week of clearing the codes.
I've heard that misfire CELs are fairly common and nothing to worry about. But I'd heard it usually is only one certain cylinder, #3 I think. Since I'm getting the CEL for 3 of the 4 cylinders, could it be some defective part? Any solutions?
Thanks for any input.
Craig W.
Craig W is offline   Reply With Quote
Old 08-25-2003, 09:51 PM   #2
Craig W
Member#: 643
1999 2.5RS
WRX powered
Any Hypothoses? Educated guesses? Shots in the dark?
Bad coils? bad sensor? touchy knock sensor? bad fuel injectors?
Old 08-26-2003, 12:19 AM   #3
Austin
Member#: 7089
2016 STi
Lightweight flywheels and lightened crank pulley can cause false knock indications and play havoc with the crank position sensor and the cam position sensor.
It doesn't happen on all cars.
The ecu compares the crank position sensor signal and the cam position sensor signal to determine whether a misfire for a given cylinder has occurred.
If you're not actually misfiring (and it's doubtful that you are or you'd've mentioned it), then it's likely that your lightened flywheel is causing your CEL.
As a precaution, pull your spark plugs and check their gaps.
Austin is offline   Reply With Quote
Old 08-26-2003, 07:46 PM   #4
WagonMonster
Member#: 3781
2002 Legacy GT Wagon
2009 Forester X Limited
I just got my first CEL this past Sunday
P0303 & P0304: Misfires in cylinders 3&4. Both happened when I started the car after getting a cup of coffee, so the engine was still warm.
The dealer sent the codes to SOA and they advised that I be sure not to rev when starting, let the car cool 30 seconds before turning off and to use high-octane gas.
WagonMonster is offline   Reply With Quote
Old 08-26-2003, 08:12 PM   #5
Precision Tuning
Member#: 38696
Do a compression test if you are concerned about the codes. They can be set by a million things, but have the integrity of the motor verified. Most shops only charge an hour to do it. Low compression in say cyl 3 can cause a misfire code for cyl 3, or for the previous or next cyl in the firing order. It is all based on the speed at which the crank sensor "sees" the piston travel down the cylinder. Can be anything from low compression, to a lean cylinder, to a faulty crank sensor etc, etc....
Rich
Precision Tuning is offline   Reply With Quote
3 cars, lots of snow, lots of subaru, lots of gettin stuck, and lots of pics kessler89 Member's Car Gallery 10 11-18-2010 09:44 AM
Misfired, CEL, fixed misfire, cleared CEL, failed smog... mc2 Service & Maintenance 3 03-20-2009 08:50 AM
Misfired, CEL, fixed misfire, reset CEL, failed smog... mc2 Normally Aspirated Powertrain 1 03-19-2009 05:59 PM
Lots of Mods + No CELs = Impossible??? xfactor834 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 09-01-2002 12:34 AM
Misfire CEL because of alcohol in fuel??? PunksWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 12-20-2001 12:32 AM
