Welcome to the North American Subaru Impreza Owners Club Tuesday April 21, 2015
Old 08-23-2003, 09:10 AM   #1
aphex twin
Member#: 10426
Midnight Pearl Black
Default spark plug questions...
where are the spark plugs located? how do i get to them? and what are the most recommended performance plugs? TIA
aphex twin is offline   Reply With Quote
Old 08-23-2003, 09:53 AM   #2
Cujo31
Member#: 19843
2000 2.5 RS Sedan
Silverthorn Mettalic
http://www.scoobymods.com/forums/sho...?threadid=1596
(if there is such a thing as a 'performance' plug... I put denso coppers in)
Cujo31 is offline   Reply With Quote
Old 08-23-2003, 09:24 PM   #3
S-WRX
Member#: 9193
is the torque sequence a must since I dont have torque ranch?
Also, where can I get denso plugs? a serial # on the denso plug would be nice too
Thanks
S-WRX is offline   Reply With Quote
Old 08-25-2003, 06:36 PM   #4
QA Guy
Member#: 6739
I'd go with NGK over Denso. NGK plugs are used as OEM on the WRX, work well, and are cheap. That's a hard combination to beat.
I would go with the stock heat range in copper if you haven't modified the car that much or one range colder if you have.
http://www.ngksparkplugs.com
QA Guy is offline   Reply With Quote
Old 08-26-2003, 07:18 AM   #5
spshultz
Member#: 1415
2005 OBS 3.0R
'12 SantaFe
Get a little package of anti-seize compound for those plugs since the heads are aluminum. That way the threads won't gall. Plus it makes spinning them in much much easier.
If you don't have a torque wrench, you just kind of have to feel it out. Aluminum threads can strip with much less effort than iron threads. So be careful. I usually seat the spark plug then give it another 1/4 turn or less.
Oh and I like the NGK V-power plugs with stock heat range.
spshultz is offline   Reply With Quote
Old 08-27-2003, 10:58 AM   #6
DerFahrer
Member#: 30727
2000 Legacy B4 RSK
*Formerly subyluvr2212*
NGK V-powers are the best plug to ever use in a Subaru. Anything else is a waste of money. End of story.
I don't use a torque wrench. I jsut know about how tight they should be. If you are straining yourself to tighten them, then you're tightening them too much...
DerFahrer is offline   Reply With Quote
Idiotic Spark Plug Questions Yotsuya Mid West Subaru Owners Club Forum -- MWSOC 14 01-30-2002 03:13 PM
spark plug question Bruiser Texas Impreza Club Forum -- TXIC 14 12-13-2001 05:31 PM
Spark Plug Question Tarmac Terror Normally Aspirated with bolt-on Forced Induction Powertrain 3 10-06-2001 03:59 AM
Spark plug question/problem sbsnyder Normally Aspirated Powertrain 1 04-28-2001 04:47 PM
Spark plug question dbrown Normally Aspirated Powertrain 4 12-30-2000 10:08 AM
