Welcome to the North American Subaru Impreza Owners Club Friday October 21, 2016
Old 08-23-2003, 03:29 PM   #1
Member#: 28853
2003 WRX Wagon
Default Oil change question
I am planning on changing the oil on my 2003 WRX wagon. I am on my way to the store to get the oil and filter and realized that I don't know what size and type of washer I need for the oil drain plug.
Does anyone know what the size and type required is???
blackjettaglx is offline   Reply With Quote
Old 08-23-2003, 03:51 PM   #2
Member#: 19843
2000 2.5 RS Sedan
Silverthorn Mettalic
I don't know the dimensions, but I know it'd be hard to find a similar crush washer anywhere other than at your local subaru dealer.... I think they are $0.75 or $0.50 apiece. You can't go wrong at the dealer service desk.
besides, I don't change off the washer EVERY oil change.. I let it go 3 or 4 times. No leaks no problems.
Cujo31 is offline   Reply With Quote
Old 08-24-2003, 01:37 AM   #3
Member#: 36099
'02 rex
I've never had a washer on mine and it's got 33k miles on it and 9 oil changes. Still as good as the first day I got it. Never needed to add any oil, nor has it leaked.
SidneyWRX is offline   Reply With Quote
Old 08-24-2003, 02:04 PM   #4
Member#: 33515
2003 WRX
Me neither..no leaks thus far
Platinum2003WRX is offline   Reply With Quote
Old 08-25-2003, 01:06 PM   #5
Wagon Joe
Member#: 34436
For me, it's definitely worth < $1.00 / 3 months for the peace of mind associated with changing the washer each time.
Wagon Joe is online now   Reply With Quote
Old 08-25-2003, 09:37 PM   #6
Member#: 25187
'08 Foz Prem TGM
'10 Challenger R/T Blk
The crush washer helps ensure you don't ruin the threads on the pan by over tightening. It also helps keep the bolt from loosening between oil changes. Since the washer is "crushed" (hence the name) when you tighten the bolt, you're supposed to replace it at every oil change. If you use the same washer over and over again, it's not doing it's job.
- Kean
Kean is offline   Reply With Quote
Old 08-27-2003, 11:00 AM   #7
Member#: 30727
2000 Legacy B4 RSK
*Formerly subyluvr2212*
Kean is absolutely correct...
DerFahrer is offline   Reply With Quote
Fujimoto oil drain valve and oil change questions ps99115 Newbies & FAQs 38 10-14-2005 08:14 AM
wrx oil change question inchoate Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 07-03-2001 02:39 PM
('93-'01) Stupid Oil Change Question Star*Child Impreza Forum 7 05-19-2001 09:23 PM
Few oil change questions? Turk Normally Aspirated Powertrain 10 03-01-2001 12:50 AM
Oil change question... ImprezaRS2000 General Forum Archive 6 05-09-2000 08:06 PM
