Old 08-23-2003, 09:42 PM   #1
Costas
Member#: 13760
1999 Impreza WRX
Rally Blue
Default Hunting for Idle? Flats Spots in Torque Curve?
99 RS
Coming back from the Tri State meet today, I noticed the same old 3500 RPM hesitation... Figured I ll reset the ECU when I get home, and I should be good for a few weeks or so..
Not today. Car would shut off on me (when coming back down from a high RPM, such as at a red light, big flat spots on the torque curve too when driving (Bigger then usual hesitation).
I did the MAF recall two months ago, when I got back to my garage, checked for vac leaks in the intake. I have cold air custom intake BTW (I have a vac gauge installed on the car too, and it has never gone below 20 in over at idle..so its OK)
Idle- goes nuts when radiator fan is on and car is idling!..its OK when fan isnt on (checked volts, no drop in voltage either, I have a volt gauge on the car as well, steady 13-14 volts. Even with AC/lights/Stereo system blasting...no drop in idle or voltage, the car wigs when the radiator fan goes on. Doesnt wig any less or more with all the accessories on,+the radiator fan comes on. It hunts for an idle just the same.
In addtion, Ive done the grounding mod. and I get no CEL?
Any ideas?
Costas is offline   Reply With Quote
Change in torque curve w/"Big Box" filter? cvalle-sd Normally Aspirated Powertrain 1 08-01-2002 01:37 PM
What's the best Kit for flat-high power/torque curves? ngenear Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 07-08-2002 10:10 AM
Flat spot in acceleration!!!!!! grrrrrr! SubieRacer Technical Forum Archive 29 05-23-2000 11:01 AM
