Old 08-23-2003, 11:26 PM   #1
bruce cohen
Member#: 19179
02 wrx
Question How fast will my WRX be with a vf34
How fast will my WRx be with a vf34 along with walbro fuel pump and STI injectors? My mods are: Perrin up pipe, Perrin down pipe, perrin crank pulley, Perrin short ram intake, Perrin turbo inlet, Denso 1 stage colder sparkplugs, samco intercooler hoses, GT Spec intercooler splitter, STI Genome axelback, and cobb stage 2 reflash. I want gusses on 1/4 mile, wheel hp, and 0 to 60. Thanks.
bruce cohen is offline   Reply With Quote
Old 08-24-2003, 12:00 AM   #2
2MANYCARS
Member#: 24046
2007 STi, EVO, M6
E55, ML63, & Old 02 WRX.
0-60, probably at 4.8 sec; 1/4 mile, in the mid 12s for sure; WHP, I would say 280-ish.
2MANYCARS is offline   Reply With Quote
Old 08-24-2003, 02:53 AM   #3
A-REX
Member#: 8525
2006 Stang GT
Make sure you get your engine management updated. And at this time - I'm not sure if COBB has any "off the shelf" maps for your set-up. If not - then you'd have to go to Salt Lake City to get a custome dyno-tune.
A-REX is offline   Reply With Quote
Old 08-24-2003, 06:05 AM   #4
PaulRex
Member#: 12454
10 Toyota Taco
K8 SV650SF
If you have the right supporting mods and tune it well you should be able to run mid-high 12s.. A person I know has an VF34, with all the good mods to go along with it, but had IMO, a very conservative tune done (Ecutek by Metric subaru) and I win when racing from a roll in my stock turbo car So just goes to show you how important tuning is, there are a few stg.4+ cars running 13s, sometimes because of slow drivers, and sometimes because of tuning, or lack thereof.
PaulRex is offline   Reply With Quote
Old 08-24-2003, 10:17 AM   #5
StevieD
Member#: 14029
I'd say with those mods you might want to think about ditching the stock TMIC for a larger unit.
StevieD is offline   Reply With Quote
Old 08-24-2003, 11:09 AM   #6
bruce cohen
Member#: 19179
02 wrx
Thanks for the replies so far every one. bump
Old 08-24-2003, 11:20 AM   #7
Need4Boost
Member#: 15194
2004 Lightning,
2001 BMW 330ci
With those mods, I find it very hard to pull off a mid 12. You must be a good driver and have an aggresive tune for that.
Pretty much what you are running equals out to a TXS Stg4. I have seen guys with the same setup run high 12's.
You really won't know until you 1320 it. The trap speed will give a good indication of what you could run.
Need4Boost is offline   Reply With Quote
Old 08-24-2003, 07:22 PM   #8
MustGoFast
Member#: 33370
2002 Impreza WRX
Blue now w/ 6 fun flavors
The 280 ish sounds about right...
I think High 12's 1/4 are more likely
and 0-60 better be faster than 4.8 as I hit that on my stage 2 (TD04 power baby) haha...
Can't wait to finish my turbo upgrade.
MustGoFast is offline   Reply With Quote
Old 08-26-2003, 06:42 PM   #9
bruce cohen
Member#: 19179
02 wrx
bump
Old 08-26-2003, 10:41 PM   #10
tm999xxx
Member#: 34408
07 Spec B
SoapBox?
ive seen a pull of a vf34 with similar mods at 300 whp with an agressive map and utec at local dyno.. no knock
tm999xxx is offline   Reply With Quote
Old 08-27-2003, 09:31 AM   #11
PaulRex
Member#: 12454
10 Toyota Taco
K8 SV650SF
Me too! (notrorious's car)
Old 08-28-2003, 02:48 PM   #12
Mrsir
Member#: 12720
2008 Porsche
Cayman S - Red
ditto, turboxs stage 2 had me at 4.8 0-60.
(however this was recorded using my gtech so it isnt necessarily 100% accurate)
Mrsir is offline   Reply With Quote
Old 08-28-2003, 03:27 PM   #13
Saposat
Member#: 24720
STI GTX4202R
Street/Drag Car
I do not know about 0-60 but my buddy Brandon from Ultimate Racing with UR satge 3 setup that includes a VF30 did 12.475@108.12. He pulls mid 12`s all the time.
Saposat
Rui
Saposat is offline   Reply With Quote
Old 08-28-2003, 05:34 PM   #14
hotsam
Member#: 3862
That's due to the excellent tuning Ultimate does as much as it is the actual mods.
hotsam is offline   Reply With Quote
Old 08-28-2003, 06:48 PM   #15
StevieD
Member#: 14029
I'm wrapping up installing
1. STI Rear Muffler
2. Gruppe-S headers
3. Bosal twin dump downpipe
4. Vishnu up-pipe
5. unichip
6. STI injectors
7. TXS TMIC
8. VF34
I'll be going to get it dyno tuned this weekend so I'll let you know how it turns out.
Old 08-29-2003, 08:24 PM   #16
bruce cohen
Member#: 19179
02 wrx
bump
Old 08-30-2003, 05:37 PM   #17
SGOSWRX
Member#: 10921
04 04 STi
12.8 @ 105 mph
0-60mph is more driver skill than anything. A 1.75 sec 60' time with a low 8 sec 1/8 mile (mid to high 12 sec 1/4 mile) puts you in the 3.9 - 4.2 sec 0-60mph range. A stage 4 WRX is very capable of running these numbers.
Like I mentioned, this is based on driver skill at launching the car.
SGOSWRX is offline   Reply With Quote
Old 08-30-2003, 05:47 PM   #18
StevieD
Member#: 14029
1. STI Rear Muffler
2. Gruppe-S headers
4. Vishnu up-pipe
5. unichip
6. STI injectors
7. TXS TMIC
8. VF34
Made 274WHP at 16psi.
Old 08-30-2003, 11:32 PM   #19
topgrinder
Member#: 31649
stevie pump up that boost dude,,,,, at least 17.5,, very safe level
did u do any dyno runs at a higher psi? if so what were the results
topgrinder is offline   Reply With Quote
Old 08-31-2003, 01:41 PM   #20
StevieD
Member#: 14029
No, we just ran it to 16psi. I kinda wish we'd tested a 17 and 18psi just to see what difference it would have made.
Pretty happy with my current levels. Just need to find a high flow cat that works between the bosal DP and STI axleback.
Old 08-31-2003, 11:35 PM   #21
tm999xxx
Member#: 34408
07 Spec B
SoapBox?
i agree. turn up the boost....i put down a 247 torque with stock turbo, injectors, and ic
Old 09-01-2003, 12:15 AM   #22
Schaf100
Member#: 19647
2002 WRX Sedan
12.697 @ 108.95
0-60 should definitely be faster. When I was TXS Stage II I could manage consisten 4.7's and a best of 4.6. With Stage IV/VF22, the best I could muster was a 4.27. Now.... with the launch control, FMIC and ACT clutch it feels like 3.8-3.9 or so. Gonna have to make some G-Tech runs and find out. 1/4 mile is highly dependant on your 60' time. If you can pull off high 1.7X's/low 1.8X's then you should be capable of 12.7-12.9 or so on the stock IC. With 1.9's or 2.0 60ft's you're gonna be low 13's..... With an aftermarket intercooler and a new clutch/launch control you may be able to pull 12.5-12.7 more easily, though that is very fast for a VF34.
Schaf100 is offline   Reply With Quote
Old 09-01-2003, 12:23 AM   #23
StevieD
Member#: 14029
Not too smart for stock injectors... I'd imagine they were wide open.
Old 10-26-2006, 04:39 PM   #24
okaythen
Member#: 63397
how many psi r u running?
okaythen is offline   Reply With Quote
Old 10-26-2006, 04:47 PM   #25
dvang
Member#: 84188
05 legacy
caravan full of kids now
must be a new fad to dig up really old threads
dvang is offline   Reply With Quote
How fast will my stage 2.5(vf39) be? dalu3100 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 03-03-2010 08:37 PM
How fast will my 1/4 time be if... RedlineRacer Newbies & FAQs 12 01-14-2005 01:55 PM
How fast will my car be? bruce cohen Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 03-31-2004 05:40 PM
How fast will stock turbo spool with intake and 3" exhaust mods ?? alfriedesq Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 28 04-10-2002 09:36 PM
205/55/16 to 205/45/16? how screwed will my speedo be? jmott Brakes, Steering & Suspension 4 07-02-2001 06:24 PM
