Old 08-24-2003, 07:57 PM   #1
DDMan
Member#: 11221
2002 2.5 RS
Black as Midnight!!!
Default Leaky headers?
Here is a pic of my engine-header gaskets. Let me guess....THIS is the sign of my hissing which started when I put on the Borla headers.
So I guess my question is.... Is this a sign that the headers were not properly sealed against the block, and that my headers were leaking?
DDMan is offline   Reply With Quote
Old 08-24-2003, 08:06 PM   #2
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
i dont know exhaust but it sure as hell looks like it
were ur surfaces clean when you mounted the gasket?
Old 08-25-2003, 11:27 AM   #3
DDMan
Member#: 11221
2002 2.5 RS
It was just my borla headers. The header-cat gasket was fine. The headers were brand new and were a pretty good fit....maybe I should drill out the holes just a tiny bit more so they fit better
Old 08-26-2003, 07:26 AM   #4
spshultz
Member#: 1415
2008 IS350
'13 SantaFe
I to think my Borlas are just a little leaky around the flanges.
I bought some Flowtech Afterburner headers for my Chevy 350 and the flanges had a lot of junk on them so I took a large file and carefully filed them down so that they would make a good seal against the gasket. No leaks so far.
I plan on doing the same thing to my Borlas when I have the time. I'll take them off and clean them up with a large file so that the mating surfaces are as flat and true as possible.
spshultz is offline   Reply With Quote
Old 08-26-2003, 06:48 PM   #5
DDMan
Member#: 11221
2002 2.5 RS
Anyone else have an opinion?
Old 08-26-2003, 08:43 PM   #6
mysubaruimp
Member#: 36721
borlas are junk, they will crack, just a heads up. i had to drill out the holes in mine to get them to fit right. they didnt leak after i did that.
mysubaruimp is offline   Reply With Quote
Old 08-26-2003, 09:39 PM   #7
DDMan
Member#: 11221
2002 2.5 RS
That was the Gen 1-3. I have the Gen 4's which dont have that brace so they wont crack.
I havnt had a problem, with them including no CEL's, but there was a slight hissing whenever I was on the gas. Does this seem to be the culprit?
Old 08-27-2003, 06:16 PM   #8
mysubaruimp
Member#: 36721
gen 4's crack too, trust me, im on my third set.
like i said, you can try to drill out the holes so the bolts can push more flat against the flange. you might not have tightened them enough, there may have been debri on the flange, or if it happened a little after you started using them, they may have cracked, look for a hairline crack at the welds on the collector nearest the flange where the cat bolts to.
Old 08-27-2003, 08:06 PM   #9
thng
Member#: 8062
If the holes are close fit holes then they have to be drilled in the right location. If they are offset slightly then they will cause the flange to warp as you tighten them up. I would resort to tightening them up but after I drilled two of the three holes slightly oversized.
Also, the flanges may have been flat after they were cut but the welding might just pull them every which way. So, the drilling is not a bad idea but drill only two of the three not all three.
thng is offline   Reply With Quote
leaky header causes turbo oil leak? razgriz Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 11-03-2007 10:52 AM
what are symptoms of leaky header/upipe? blackie Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 05-13-2004 07:38 PM
HELP! Need a quick fic for a leaky sunroof... eastbaysubaru Legacy Forum 4 05-04-2001 12:43 AM
car wash = leaky weather stripping = water in my car M a t t General Forum Archive 10 02-13-2001 12:58 AM
Leaky Air Shocks aross Legacy Forum 6 04-24-2000 10:14 AM
