#1 |
Member#: 35903
NESIC
Vehicle:99 R & 05BugShield I RBP & PSM |
My friend and I were installing the s-afc yesterday, after we connected all the wires correctly except we connected the ground(brown and black) wire to ignition ground instead of oxgen sensor ground (we didn't know that until i found it in scoobymods.com).
After I turned the ignition to perform the initial set up, the engine light started blinking, we didn't know what went wrong so we disconnected all the wires and put everything back to normal, but the engine light remains blinking whenever i turn on the car, so my friend used one of those computer to check the codes inside the computer, it said 3 somethings: speedometer sensor at fault front o2 senor, rear o2 sensor at fault undocument code the speedometer works fine and i can still drive the car without any abnormal behaviors except when i turn on to the ignition (without startin the car) the engine fans go on and off continously if anyone knows what we did wrong and what we possibly broke( o2 sensers maybe?)... and how we can fix this please help... PLZ HELP ME thx Walt
#2 |
Member#: 2817
Vehicle:2001 Impreza 2.5RS BRP |
You put everything back to the original state, right? Reset the ECU first and see what happens.
#3 |
Member#: 35903
NESIC
We fixed the problem after mulder taught me...my friend connected the green connector on the passenger side which is not supposed to be connected
now the safc runs fine thx for helping, mulder Walt |
| Thread Tools | |
| Display Modes | |
| Help! Check Engine Light + Blinking Cruise Control | mindz0f1 | General Community | 3 | 02-15-2007 09:35 AM |
| Check engine light blinking!?! | Chonojake | Factory 2.0L Turbo Powertrain | 30 | 03-11-2006 09:06 PM |
| check engine light blinking | jimball21 | Tri-State Area Forum | 20 | 01-25-2005 12:31 AM |
| Check engine light blinking!!! | rageatm007 | Electrical & Lighting | 5 | 07-26-2004 07:54 AM |
| check engine light blinking after installins safcII for 99 2.5rs | q0Y0p | Electrical & Lighting | 5 | 08-26-2003 09:08 PM |
