Old 08-25-2003, 01:56 AM   #1
q0Y0p
Member#: 35903
99 R & 05BugShield I
RBP & PSM
Default check engine light blinking after installins safcII for 99 2.5rs
My friend and I were installing the s-afc yesterday, after we connected all the wires correctly except we connected the ground(brown and black) wire to ignition ground instead of oxgen sensor ground (we didn't know that until i found it in scoobymods.com).
After I turned the ignition to perform the initial set up, the engine light started blinking, we didn't know what went wrong so we disconnected all the wires and put everything back to normal, but the engine light remains blinking whenever i turn on the car, so
my friend used one of those computer to check the codes inside the computer, it said 3 somethings:
speedometer sensor at fault
front o2 senor, rear o2 sensor at fault
undocument code
the speedometer works fine and i can still drive the car without any abnormal behaviors except when i turn on to the ignition (without startin the car) the engine fans go on and off continously
if anyone knows what we did wrong and what we possibly broke( o2 sensers maybe?)...
and how we can fix this please help...
PLZ HELP ME
thx
Walt
q0Y0p is offline   Reply With Quote
Old 08-25-2003, 02:38 AM   #2
sti27
Member#: 33715
98 2.5rs
rallyblue pearl
Sorry I dont have an answer for you but I do have a question. Do you have/ or where did you get instructions for install the safc II. I'v been looking for help or difficultly level of the install.
Hope you find an answer,
Sti27
sti27 is offline   Reply With Quote
Old 08-25-2003, 08:48 AM   #3
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
By any chance did you plug together the green connectors under the drivers side dash? They are normally just sitting there not connected and very often when someone is working under there they will see them and assume they should be connected and plug them in. When you do this it activates a diagnostic mode for the ECU which will constantly flash the CEL and cycle the fans and various other relays and solenoids.
If that is what you did just go back under there and unplug them.
Your codes might have come from improperly wiring the SAFC, now that you have removed it and reconnected everything back to normal you may want to check to see that the codes have not come back. Anyway those codes would give you a steady CEL and not a flashing one.
Old 08-25-2003, 10:36 AM   #4
q0Y0p
Member#: 35903
RBP & PSM
sti27
the safc comes with english instructions, then i got the wire diagram from www.ravenshield.com/impreza (i dun remember it wrong i got this link from one of the posts in this section)
then i followed the safc instructions...
mulder
maybe...because before i worked on the safc, we also did something under there I will take a look at it today and will take you what happens
thank you
Walt
Old 08-26-2003, 10:04 PM   #5
q0Y0p
Member#: 35903
RBP & PSM
thx, mulder
we got the problem fixed. my friend connected it, after i unplugged it, everything runs fine
thank you
Walt
Old 08-26-2003, 10:08 PM   #6
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Thought so
Maybe it won't make you feel any better, but believe me you aren't the first to have done this and you won't be the last.
Happy to help, glad to hear your car is ok now.
Help! Check Engine Light + Blinking Cruise Control mindz0f1 General Community 3 02-15-2007 10:35 AM
Check engine light blinking!?! Chonojake Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 30 03-11-2006 10:06 PM
check engine light blinking jimball21 Tri-State Area Forum 20 01-25-2005 01:31 AM
Check engine light blinking!!! rageatm007 Electrical & Lighting 5 07-26-2004 08:54 AM
check engine light blinking after installins safcII for 99 2.5rs q0Y0p Electrical & Lighting 2 08-26-2003 09:59 PM
