Welcome to the North American Subaru Impreza Owners Club Sunday September 21, 2014
Old 08-25-2003, 02:14 AM   #1
QAboy
Member#: 21711
2012 2.0i Premium
Ice Silver Metallic
Default TB Bypass
I am aware of the dangers and have read a multitude of posts on this but haven't been able to find an answer to my question. I want to split the hose with a "Y" fitting on either side of the TB and put a valve on the incoming side. The problem is which side is the incoming side and which is the outgoing?
I have the day off tomorrow and would like to do this so I would really appreciate any help.
Thanks
eric
QAboy is offline   Reply With Quote
Old 08-25-2003, 10:26 AM   #2
Dr Ken
Member#: 5885
2000 RS (GME)
SilvAr
Someone please correct me if I'm wrong....
With a Y at each side, it seems to me that it would not really matter which direction the flow goes, nor which Y you chose to place a stopcock. The beauty of your approach is there is never any air in the line.
I gotta do this mod someday
Dr Ken is offline   Reply With Quote
Old 08-25-2003, 11:25 AM   #3
QAboy
Member#: 21711
2012 2.0i Premium
Ice Silver Metallic
OK, not sure if this helps but this is sorta what I was picturing. I suppose that putting a valved "Y" fitting on each side would work. But I would prefer to just do one side.
Well crap. I drew a really cool diagram but now it won't show up right. Oh well Y'all can probably picture it anyway.
Old 08-25-2003, 11:59 AM   #4
HondaH8er
Member#: 3097
2013 Ford Focus ST
Performance Blue
Dr Ken is right, it doesn't really matter which side you put the valve on. If you close it, the coolant will go through the bypass anyways, since there won't be any way for it to flow back through the TB since the valve is closed, and the TB line will be a dead end. Or, if you want to be really sure that nothing can get through the TB, put a valved Y on both sides.
HondaH8er is offline   Reply With Quote
Old 08-25-2003, 12:17 PM   #5
QAboy
Member#: 21711
2012 2.0i Premium
Ice Silver Metallic
I'm leaning owards putting a valved Y on each side but want to be sure that no harm can be done by having coolant just sitting in the TB. I assume that since air isn't getting in as well it would be fine.
Old 08-25-2003, 08:37 PM   #6
IggDawg
Celebrity Guest Star
Member#: 10648
2002 Escort... D:
Mostly kind of white
it's not so much the coolant sitting around as the sediment building up behind the valve. particles build up slowly and will all flush thorugh at once like opening up a tournequit. it can clog small passages in the cooling system. it's not that tough to just manually attach and remove it.
-IggDawg
IggDawg is offline   Reply With Quote
Old 08-25-2003, 08:59 PM   #7
QAboy
Member#: 21711
2012 2.0i Premium
Ice Silver Metallic
yah that's what i've decided to do. what is the best way to cover the unused nipples?
Old 08-25-2003, 09:10 PM   #8
Dr Ken
Member#: 5885
2000 RS (GME)
SilvAr
... or maybe periodic flushing by momentarily opening the valve ...
edit: nipples, hehehe
Old 08-26-2003, 09:30 AM   #9
DanzBorin
Subaru Bounty Hunter
Member#: 7131
2008 STi DGM (3rd
STI) prev 05 STi (white)
buy some little doohickeys at the autoparts store... that's what I did... and by doohickeys I mean little rubber plug things...
DanzBorin is offline   Reply With Quote
Old 08-26-2003, 10:51 AM   #10
RokketRide
Member#: 17984
1967 Barracuda
Vacuum caps?
RokketRide is offline   Reply With Quote
Old 08-26-2003, 10:53 AM   #11
DanzBorin
Member#: 7131
2008 STi DGM (3rd
Originally posted by RokketRide
Vacuum caps?
If that's what they are called... don't know... just when to that isle of random plugs and clips...
Old 08-26-2003, 12:58 PM   #12
QAboy
Member#: 21711
2012 2.0i Premium
Ice Silver Metallic
thanks I'm gonna try that today. Interestingly enough the 1/4 inch brass coupler was too small so I'm gonna have to go back out and get a bigger one
Old 08-26-2003, 01:00 PM   #13
DanzBorin
Member#: 7131
2008 STi DGM (3rd
yeah... I think you need 3/8...
Old 08-26-2003, 02:53 PM   #14
mprezuhguy
Member#: 39921
'00 RS Sedan
STM
realisticly, what kind of gain should someone expect from this mod? Is it significant?
mprezuhguy is offline   Reply With Quote
Old 08-26-2003, 03:04 PM   #15
Zen
Member#: 12656
Expect maybe ~3hp? It's basically free so you might as well do it.
Zen is offline   Reply With Quote
TB bypass observation IggDawg Normally Aspirated Powertrain 18 11-16-2002 03:08 PM
Another darn TB bypass thread HamFist Normally Aspirated Powertrain 46 09-28-2002 12:56 PM
TB Bypass ImprezaRSX Hawaii Impreza Club Forum -- HIIC 2 09-28-2002 12:15 AM
Did the TB bypass mod today ImpreziveRS Normally Aspirated Powertrain 15 09-22-2002 09:56 PM
Just did the TB bypass mod... IggDawg Normally Aspirated Powertrain 46 09-19-2002 10:00 AM
