Old 08-25-2003, 02:53 AM   #1
impreza2002
Member#: 30428
1999 Impreza 2.5RS
RALLY BLUE
Default Is better spark plug wire can +hp???
I just bought the "option fans magazine" recently b/c of the article "6mt GC8 vs 6mt GDB" that attracts me. Anyways, there is an article talking about the tunning of the Acura RSX. And they found that by putting in the HKS spark plug wire (hotwires) alone can add up to 6hp (tested on the dyno!). So, I just want to know is that true? If so, then I will get one for my car, and which brand makes a good spark plug wire? Thanks.
impreza2002 is offline   Reply With Quote
Old 08-25-2003, 09:26 AM   #2
nySulli
Member#: 32617
2008 STi
i doubt on a new car you would get that gain, but on an older car with worn wires yes, you'll see a "hp gain". in reality you'll just be regaining lost hp
maybe with some mods being done i could see a gain, especially if you had an ignition system installed, and maybe some specific applications where the factory wires just aren't good
but for our cars, most seem to say you won't notice a hp gain if you have good wires, but you will notice a little refinement in engine smoothness and throttle response
oh, and for our cars, everyone seems to like magnacores
nySulli is offline   Reply With Quote
Old 08-25-2003, 12:04 PM   #3
HondaH8er
Member#: 3097
2013 Ford Focus ST
Performance Blue
I wonder how many pre and post runs they did, and how far apart the pre and post runs where from each other. 6 hp could be the difference between a warm day for the pre and a cooler day for the post.
HondaH8er is offline   Reply With Quote
Old 08-25-2003, 01:55 PM   #4
scotty305
Member#: 8877
2000 Impreza 2.5RS
(sept '01-jan '04)
Each car is different, some cars' factory wires aren't very good, maybe the Honda wires are cheap?
Most of the Subaru people agree that replacing spark plug wires doesn't add a noticeable amount of HP.
It could also be that the honda engine is so weak-feeling, that any improvement is noticeable, and the subaru engine feels stronger, so adding a little power doesn't feel like a big improvement.
An RSX makes less torque than our 2.5RS, correct?
-s-
scotty305 is offline   Reply With Quote
Old 08-25-2003, 06:12 PM   #5
nySulli
Member#: 32617
2008 STi
yep, the rsx type-s only makes 142 ftlb at 6000 rpm, 141 ftlb at 4000 for the normal rsx
Old 08-25-2003, 08:33 PM   #6
IggDawg
Celebrity Guest Star
Member#: 10648
1998 Acura CL... D:
Mostly kind of red
if the wires he mentions are the "hotwires" I'm thinking of, they may increase HP. Nonology makes wires with capacitors on them that store up extra charge or some crap. I dunno, but it's more than "just a wire" so it there might be something to them. I haven't looked into it.
-IggDawg
IggDawg is offline   Reply With Quote
Old 08-25-2003, 09:25 PM   #7
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
"just be regaining lost hp"
Exactly right.
Your purpose should be to find wires that dont lose power over time. The only good set of wires I know of that doesnt wear out are the Magnecore. 7.5mm can be had for the same price as normal wires, 8.5 for less than double.
Old 08-26-2003, 06:25 PM   #8
impreza2002
Member#: 30428
1999 Impreza 2.5RS
RALLY BLUE
I can get the NGK wires from my dealer, so how is this one compares to the Magnecore?
Old 08-26-2003, 08:27 PM   #9
nySulli
Member#: 32617
2008 STi
couldn't tell you, but i know magnacore also uses the factory subaru boots, which ensures a good snug fit
does any know where i can buy spark plug wire for ver4 sti myurbanracer Pre-2002 Factory Turbo Powertrain 11 02-25-2008 12:21 AM
New spark plug wires = much better driveability MaddMax Legacy Forum 25 10-28-2004 08:20 PM
IF a spark plug wire is too long... GimmeScoobySnacks Normally Aspirated with bolt-on Forced Induction Powertrain 2 03-09-2004 05:07 AM
Where can I get spark plug wires? SubieFL Normally Aspirated Powertrain 8 03-13-2003 09:40 AM
Have Magnecore Spark plug wires been chaged to fit better yet? Snoopy Engine Management & Tuning 3 10-24-2002 02:24 PM
