Old 08-25-2003, 11:33 AM   #1
Dude
Member#: 10653
Default SECS users: does your EGT read high?
I've got a PSI3 SECS unit hooked up to my WRX and my EGTs seem to be registering very high. Normal driving usually gives me an average of around 1250 C - 1300 C, and upwards of 1400 C during spirited driving. Please correct me if I'm wrong, but that sounds like my engine is going to blow up at any moment. But, I haven't heard any knocking, and my coolant and oil temp readings don't seem abnormal. The car has been set up the same way for months before the install of the SECS unit without any problems. Is there something different about the way the unit reads EGTs through the ECU, or have I just been extremely lucky up to now? Any light on this would be greatly appreciated.
Here are the details:
When I start it up in the morning:
EGT: 680 - 690 C
CT: 80 C
Oil Temp (From Elec Omori Meter reading from rear oil gallery): 0 F
After full warm up:
EGT: 1250 - 1300 C
CT: 180 - 190 C
Oil Temp: 190 - 200 F
"Spirited" driving:
EGT: 1400+ C
CT: 200 C
Oil Temp: 200 - 210 F
I have:
Monster TD04 (ported and polished) at 15 psi
STi intercooler
stock injectors
Helix flex uppipe with bung
ECUTek tuned
Greddy EVO catback
Dude is offline   Reply With Quote
Old 08-25-2003, 12:02 PM   #2
Member#: 13004
2002 Pump Gas Homo
I hope your just confused and the EGT reads in F- that would be spot on. If its a real C reading then you would have a puddle of aluminum under your car were the engine used to be mounted
David@Vishnu is offline   Reply With Quote
Old 08-25-2003, 12:56 PM   #3
Dude
Member#: 10653
Yeah, that's what's got me worried.
The SECS unit has the capability to toggle between F and C units. I've go the unit set to read in F right now. But EGT remains labeled as C, while all other measurements (Coolant, Intake temp, Oil temp, etc.) read as F. I'm hoping that it's just the label that hasn't changed, and that the values are Fahrenheit units......I hope.
But, wouldn't my car be blowing engine chunks out of its arse by now if those readings were correct?
Old 08-26-2003, 08:38 AM   #4
Kha0S
Member#: 8808
2011 WRX
DGM 5D
The SECS release that I have (v9, IIRC) displays "C" regardless of whether C or F is selected in the unit display option, the number is converted, but the unit on the display is left unchanged.
FWIW, with no cat in my up-pipe, I generally read between 750 (at idle) and 1050 (light throttle, climbing hill, high gear, etc.)
/Andrew
Kha0S is offline   Reply With Quote
Old 08-26-2003, 10:44 AM   #5
simwahWRX
Member#: 20870
Midnight Black mica
Mine (v9) reads more like Kha0s' - around 800 at idle, up to around 1100, with 1020 being the norm.
What are some other numbers the SECS is giving its users in other categories?
My knock correction is generally 0.0, but can get up to 8.0. My lambda numbers hang around 1.0, but go down to .6 or up to 1.4. Are these normal?
Also, my coolant gets up to 208 - any suggestions?
Is there a resource that shows what values are recommended/normal?
simwahWRX is offline   Reply With Quote
Old 08-26-2003, 10:45 AM   #6
ataac_flat04
Member#: 19050
2005 Black STi
Happily rowing 6 gears
Ditto on what Kha0s wrote. I did the unit conversion to "F" and noticed that EGT was still labeled as "C". Done a little math on the displayed numbers and figured there was no way that the displayed numbers could actually be celsius readings, or there was some serious melting going on. -Chuck
ataac_flat04 is offline   Reply With Quote
Old 08-26-2003, 11:58 AM   #7
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Sounds buggy.
1050C is 1922F. Obviously way too high.
1050F is not correct for up-pipe-less EGT readings. Go WOT and you should see at least 1300.
jblaine is offline   Reply With Quote
Old 08-26-2003, 06:11 PM   #8
Dude
Member#: 10653
Default whew!
Okay, I'm not as freaked out now. If "C" is actually "F", then the numbers aren't that scary. A bit high, but not nearly as worrisome.
Sounds like my EGTs are still a bit high though. Does this mean that I am running to lean? What could be some other possibilites? Forgot to mention that I already have a larger PWR radiator.
Thank you for all your help homies.
Old 08-26-2003, 07:49 PM   #9
zacek
Member#: 19467
02 WRX
WR Blue
the numbers on the top of the post look very normal. Nothing abnormal. 1400 F on spirited driving is waaay normal, mine used to go up to 1550 on canyon runs during summer.
zacek is offline   Reply With Quote
Old 08-26-2003, 07:51 PM   #10
edkwon
Member#: 453
2014 Audi S4 B8
Metallic Gray
Yep, thats a software/firmware error, i figured that out when you switch to C, all the temp values are correct, and i told this to quantum-racing.com who is going to notify PSI^3 about this bug. The absolute numbers should be right.
Ed
edkwon is online now   Reply With Quote
Old 08-27-2003, 12:35 AM   #11
Dude
Member#: 10653
Default woo hoo!
Wow thanks guys!
That's a big load off of my mind. Absolution from my fellow subrothers!
thanks again
Old 08-27-2003, 12:58 PM   #12
Kha0S
Member#: 8808
2011 WRX
DGM 5D
Originally posted by jblaine
Sounds buggy.
Tapped where?
/Andrew
Old 08-27-2003, 01:06 PM   #13
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
WOT on a stock setup with EGT probe in catted up-pipe read right around 1350 on both my 02 WRX and another one (as recorded via DeltaDash).
WOT gauge readings with a tap just outside of the driver's side collector are around 1400 for me.
NOVA Cingular Users: Does your phone work right now? tairese Mid Atlantic Impreza Club -- MAIC 22 06-22-2006 12:24 AM
does your DTEC read too high? metoo Engine Management & Tuning 11 04-19-2006 01:34 PM
More questions for RS-T owners - how high would your EGT reading get? kgb Normally Aspirated with bolt-on Forced Induction Powertrain 5 09-30-2005 11:07 AM
Does your SO read your threads? Midwayman Off-Topic 42 06-30-2005 12:29 PM
Kartboy users: does your shift lever squeak, too? Siper2 Transmission (AT/MT) & Driveline 6 07-17-2002 12:54 PM
