Old 08-25-2003, 03:19 PM   #1
duckride
Member#: 19065
Default Intercooler Water Spray nozzle
Hey all,
Yesterday I built a spray kit for my intercooler (stock). I secured a five gallon tank in the trunk using bungee chords and put a washer pump on it (bought it from Autozone. Part5-768) Ran the tube through the door moulding and through the firewall and mounted Toro blue Stripe drip nozzles (7 of them. Three on one side and 4 on the other in a kinda staggering config. Got them from the plumbing section of home depot) I then hooked up the pump to UTEC spare solenoid control. Everything works honky dory except the nozzles are a complete dissapointment They just kinda leak (quite profusely actually) when the pump is on no mist no spray nothing. I read on some other post in one of the forums that these are excellent nozzles. Which makes me wonder, am i running the tube too long? Is the washer pump not making enough pressure? or do i have to many nozzles or something? or should i do somehting to the nozzles to get them to mist the water? Or should i be using some other nozzle?
Manoj
duckride is offline   Reply With Quote
Old 08-25-2003, 08:00 PM   #2
z&cobb
Member#: 12344
2002 2JC
blue
Default Re: Intercooler Water Spray nozzle
Originally posted by duckride
Hey all,
Manoj
I don't know if this can help with all the questions since my system is based on the Sti tank and pump in the trunk. I found that the best setup for my large IC (TXS TMIC) is a linear arrangement of 12 "Misty Mate" nozzles. This produces a fog from each nozzle, and cools the IC down to ambient or below ambient wheneven I see a temp I don't like. A series of 2 to 3 second bursts works well. Here are some links that might help.
Nozzles
My Setup
z&cobb is offline   Reply With Quote
Old 08-26-2003, 09:05 AM   #3
omahasubaru
Member#: 1594
1995 WRX
2002 Legacy
Problem #1: I bet you pump can't push enough water at a high enough pressure to make 7 nozzles mist
Problem #2: I don't think you really need 7 nozzles to accomplish a nice mist when two good ones will do the job
Problem #3: Your hose likely can't handle the capacity needed to feed 7 sprayers @ the right pressure.
This is all based on the information I have from developing & installing a kit on a friends WRX & I'm in the process of replicating it in a cheaper way & with a seperate tank.
Two nice Cone Jet nozzles, a decent amount of water (3/8th in. line) & some pressure will provide such a nice fog. It has also been proven to bring I/C core temps back down to ambient. This is done with a temp probe on the rear of the I/C core on near 100 degree days. He is also using an autospeed controller which is very nice & really do a great job at keeping the I/C cooler. Once set, you can pretty much leave it alone.
Many people are trying to be cheap on the main place that you shouldn't... the pump. They try and offset this with cheaper nozzles as well. It works, but not as well as it could. I'm not talking about spending $125-250 on a I/C mister set-up. Cone Jet nozzles are reasonably cheap, a nice pump can be had for $40 some similar for less. Hose is cheap, fittings are cheap, labor is cheap (if you DIY).
I would try & go back to just 2 or 3 if you have to nozzles & see how that works. If it doesn't do the trick... that's gonna suck.
What kind of pump & what are the specs on it as well as how big of hose do you have feeding to your nozzles & how are you seperating that water from one feed line to the 7 nozzles?
Jon
omahasubaru is offline   Reply With Quote
Old 08-26-2003, 11:30 AM   #4
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Oil Dry Sump Goodness
You need to go large:
DIY Water Sprayer on WRXHackers
mick_the_ginge is offline   Reply With Quote
Old 08-26-2003, 04:23 PM   #5
duckride
Member#: 19065
Default Wrong nozle type
Hey guys, I guess I was just using hte wrong type. I, by mistake got the emitters (and they are for drip irrigation) I went back and got foggers and this seems to work fine (even with 7 nozzles) i get a fine spray. Though I did buy the misty mate today. I want to see if that works better than what i have right now.
Thanks all!
Manoj
Old 08-26-2003, 05:13 PM   #6
Jon [in CT]
Member#: 2992
02 WRX Sedan
A good resource for nozzles is www.spray.com since they offer specifications so you can make informed decisions.
Jon [in CT] is offline   Reply With Quote
Old 08-27-2003, 03:40 AM   #7
clamdip
Member#: 18709
you should just purchase the STi waterspray nozzles. 2 will do the job just fine. i've got them, well, those with a cusco waterspray nozzle and my IC keeps very cool especially on those hot days. i also have the spec C 12L trunk mounted tank so i can flow much more water over the IC and not have to refill it every day. maybe every week or so, depending.
clamdip is offline   Reply With Quote
STi IC water spray nozzle 02WRXTURBO Private 'Wanted' Classifieds 1 07-24-2008 11:34 PM
WTB: STi IC water spray nozzles seest Private 'Wanted' Classifieds 1 05-14-2007 10:29 AM
For Sale 3 sti ver 7 water spray nozzles mrtrex Private 'For Sale' Classifieds 3 11-24-2003 06:15 PM
Intercooler water spray - when to spray? [email protected] STi Forum Archive 9 01-07-2003 08:30 PM
water spray nozzles Jonnathan Normally Aspirated with bolt-on Forced Induction Powertrain 13 09-18-2002 03:31 PM
