Old 08-25-2003, 04:10 PM   #1
sonicsuby03
Member#: 36060
03 Rex Cobb Stg2
Ltd Ed. Sonic Yellow
Default AccessEcu STG2 / has anyone De-Modded?
I NEED TO DE-INSTALL MY HALLMAN BOOST CONTROLLER & BLOW OFF VALVE. I AM ALSO THINKING OF REMOVING MY AFTERMARKET AIR INTAKE? HAS ANYONE HAD THIS EXPERIENCE & TO WHAT RESULTS?
THANKS ALL!!!!
sonicsuby03 is offline   Reply With Quote
Old 08-25-2003, 04:40 PM   #2
heffergm
Member#: 34672
2003 wrx
WR Blue Pearl
Huh? Are you asking should you remove that stuff if you're planning on getting a Stage 2 Cobb ECU reflash?
The answer is yes, absolutely remove it. The whole point of the updated Cobb engine manangement is to allow it to intelligently control things like boost and timing.
heffergm is offline   Reply With Quote
Old 08-25-2003, 05:04 PM   #3
sonicsuby03
Member#: 36060
03 Rex Cobb Stg2
I AM CURIOUS TO FIND ANY EXPERIENCE THAT THOSE W/STG 2 HAVE COME ACROSS. WHEN I SPOKE W/COBB THEY REALLY DIDN'T KNOW WHAT THE END RESULTS WOULD BE. OBVIOUSLY THE MBC HAS TO GO AS IT WILL OVERRIDE ANYTHING THEY FLASH INTO THE ECU.
RE: THE INTAKE - THEY HAVE SEEN GOOD & BAD SCENARIOS.
RE: BLOW OFF VALVE - THEY SAID THE CAR MAY HESITATE AS THE BOV VENTS TO ATMOSPHERE CAUSING A HICCUP IN THE ECU'S READING.
======== HAS N/E-1 HAVE SUGGESTIONS? I THINK IM GONNA RUN WITH THE INTAKE THEN W/O TO COMPARE. ===========
Old 08-25-2003, 05:30 PM   #4
SilverBoosted
Member#: 7764
11 Edge Sport
Kona Blue Metallic
First please hit your caps lock button.....Thanks....
If you let Cobb know which intake you have they may have a reflash that incorperates the intake needs .... As far as a BOV I have a GFB BOV with my stage 2 reflash and havent had any problems as of yet..... Now the boost controller definately get rid of it Its not nessasary anymore.......
SilverBoosted is offline   Reply With Quote
Old 08-25-2003, 05:40 PM   #5
sonicsuby03
Member#: 36060
03 Rex Cobb Stg2
No problem. Thanks for the feedback. Have you been impressed with the stage 2 set up?
Maybe I'll only change the Mbc to stock at 1st & go from there.
Old 08-25-2003, 05:57 PM   #6
SilverBoosted
Member#: 7764
11 Edge Sport
Kona Blue Metallic
I totally love the Stage 2 reflash best $$ I ever spent...... Check with COBB on the intake issue first just to be safe.......
Has anyone local modded JDM projectors??? BuggeyEYED Tri-State Area Forum 5 08-09-2006 04:56 PM
Has anyone gone to DE DMV with utec? 20024door Mid Atlantic Impreza Club -- MAIC 8 11-12-2005 06:23 PM
3/16 T/AccessECU-stg2...theories? Darryl Engine Management & Tuning 18 11-11-2003 01:39 PM
has anyone done Bankheists or Reiflexs blue light mods??? joostin420 Interior & Exterior Modification 21 12-01-2000 05:27 PM
Has anyone purchased or know about hesitation mod. v6scoobie Technical Forum Archive 13 08-20-2000 04:12 AM
