Old 08-25-2003, 05:44 PM   #1
simwahWRX
Member#: 20870
Midnight Black mica
Default WRX parameters
Does anybody know one place where I can get the recommended values/ranges for things such as a/f ratio, oil pressure, oil temp, coolant temp, egt numbers, injector duration,battery voltage, air flow, etc, for the WRX? The more the better.
I though I saw a thread a while back that had a few of these on it, but I coudn't find it with a search.
simwahWRX is offline   Reply With Quote
Old 08-26-2003, 06:47 AM   #2
simwahWRX
Member#: 20870
Midnight Black mica
For instance, what temp should my EGT's be? What is too low? Too high?
My boost shows -.6bar. Is this normal? (It shows +1.16bar under load).
What psi range should my oil pressure be within?
What grams per second should the air flow be?
Other measurments like oil temp, coolant temp, injector duration, pressure, etc. - where can I find them?
Old 08-26-2003, 07:13 PM   #3
BOFslime
Member#: 23845
2015 FLAT SIX
I should be getting my delta dash tomorrow, my car is running fine, and so i assume numbers i log, should be normal. I'll post my info when I get that.
there are verous threads for the different ranges you're asking about. To my knowlege there has never been a single thread for it all.
BOFslime is offline   Reply With Quote
Old 08-27-2003, 02:36 AM   #4
QA Guy
Member#: 6739
A/F: 14.7 closed loop, ~10-11 open loop
Boost: ~20mm Hg vacuum to 15-16 PSI (stock turbo)
Oil pressure: 15-20 PSI (hot and no load) to 90 PSI (cold or high load)
Injector duty: less than 85-90%
Battery voltage >12v (probably 13-14)
EGT < 1600F under heavy load is the conventional wisdom
A lot of these measurements are going to vary based on your set up. Higher viscosity oil, bigger turbos, different injectors, etc...
QA Guy is offline   Reply With Quote
Old 02-27-2004, 12:43 AM   #5
abqkid
Member#: 52295
2003 WRX Wagon
do you know by chance what the oil temp and water temp should be?
abqkid is offline   Reply With Quote
Old 02-27-2004, 09:13 AM   #6
SlideWRX
Member#: 3803
07 Mustang GT
Ford Crappy Paint White
Boost stock is ~14 falling to ~12 at redline.
My oil temp with a warm engine is around 180-185 from the rear access galley, 195 under spirited driving.
Tom
SlideWRX is offline   Reply With Quote
Old 02-27-2004, 11:23 AM   #7
Kha0S
Member#: 8808
2011 WRX
DGM 5D
Water temp should run between 175 and 215F, depending on ambient temps and activity.
/Andrew
Kha0S is offline   Reply With Quote
Old 02-27-2004, 12:02 PM   #8
abqkid
Member#: 52295
2003 WRX Wagon
thanks that is exactly what i needed!
FS : Sold sd 05 sti SCIC Private Classifieds 93 07-29-2010 03:21 PM
All WRX parameters/ Values abqkid Engine Management & Tuning 0 02-27-2004 01:05 AM
Mass Air Flow (MAF) sensor parameters...ie- voltage/values, max/min...?? dug-e-fresh Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 02-06-2002 07:38 AM
Changing the stock ECU parameters! Kevin Thomas Normally Aspirated Powertrain 29 12-14-2000 12:20 AM
