Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 08-25-2003, 07:45 PM   #1
Clutch784
Member#: 42331
2008 BMW 328xi
Default Impreza L --> 2.5RS --> EJ20 swaps
I'm wanting to start an Impreza project and my budget is a little tight. I was entertaining the thought of buying an Impreza L and swapping an EJ20 into it. Is this possible? And if so, how hard would it be to do? The L would be the chassis I'd be swapping the motor into since I don't have enough money to afford anything higher up in the Impreza line.
After the engine, I'd like to get the styling of a 2.5RS. I was talking to a friend of mine and he said to make the L look exactly like the RS, the only things needed would be the front bumper and the rear wing. How accurate is this? What other cosmetic differences are there between the L and the RS? How difficult are they to do?
THe answers to these questions will greatly determine the decision of purchasing an Impreza L for my project car. I know this is my first post on here but hey, gotta start somewhere! Thanks a lot!
-Andy
Clutch784 is offline   Reply With Quote
Old 08-26-2003, 12:09 AM   #2
atmosphere
Member#: 37641
98 Impreza 2.5 RS
You'll need 2.5RS side skirts if they fit an L and it doesnt already have them. Now correct me if Im wrong but the L has a 2.2L engine? If this is the case you prob need to do a tranny swap in conjunction with the motor swap.
atmosphere is offline   Reply With Quote
Old 08-26-2003, 12:56 AM   #3
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Take a look at the FAQ. It should answer a lot of your questions.
-Jon
Old 08-26-2003, 02:49 AM   #4
Clutch784
Member#: 42331
2008 BMW 328xi
Thanks guys.
Old 08-26-2003, 10:23 AM   #5
geronimo66
Member#: 26929
2000 Impreza
with Gremilins
I just had this done to my MY00 L, I now have a complete MY02 WRX under my L
To do it right you should do the UP pipe and downpipe and cat back at the same time... I changed my trans and rear diff also to match the WRX. (I bought the whole drivetrain from one car.) I also bought a Yoshio ECU from the guy, and I bought gauges to keep tabs on the new motor.
All said I think I spent 10k on the swap so far, I have yet to do any body work other than the hood, which is a VIS CF hood with OEM scoop.
geronimo66 is offline   Reply With Quote
Old 08-26-2003, 02:24 PM   #6
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
I just did this swap into my 94 and it's well worth it. I have a few minor problems that are being fixed (i.e. A/C). The cost of the whole project came in at under $7000 including the cost of the car!! I highly recommend the swap.
Take it easy, Micah McMahan
Old 08-26-2003, 02:25 PM   #7
Clutch784
Member#: 42331
2008 BMW 328xi
This is exactly what I wanted to hear! $7000 is RIGHT at my budget! Thanks again!!!
Old 08-26-2003, 06:49 PM   #8
boarder206
Member#: 9222
1995 Impreza Lw/EJ20
Silverstone Metallic- NSX
Depending on the year of your Impreza L, you might have to spend a little more on the RS(look). If it is 97+ then all you have to do is wing, which on some is actually the same as the RS sedan. The coupe has the higher sitting wing. The hood, front bumper, and side skirts. However if you have an L earlier than 97 then you have more to change over. The lights are shaped slightly different and those need to be upgraded to a 97+ headlight. From there you either have the normal looking lights, or the crystal lights that went on the RS I believe in 99 and also onto the OBS in 99. Also the front grill will need to be changed out. This is almost a worth while upgrade as the lights are much brighter and have an overall better look. A couple things on your swap, make sure it is a AWD L. You don't have to swap over the tranny, but it might be a very good idea. If you go with the auto, they are increadibly good and are the same as the RS, but you will still want to upgrade a bit. Consult the likes of I-Speed, or Lachute as to what you will need to do the swap. The only big hurdle is the wiring which is a pain in the arse. Have fun... peace. ~Erick
boarder206 is offline   Reply With Quote
99 2.5rs -> V4 Ej20 Sti JDMdrifter Newbies & FAQs 3 05-23-2010 07:25 PM
FS/WTT: '00 BRP 2.5RS USDM EJ20 swap - St.Louis tverdek MWSOC Private Classifieds 3 08-06-2008 09:50 AM
FS/WTT: '00 BRP 2.5RS USDM EJ20 swap - St.Louis tverdek Private Vehicle 'For Sale' Classifieds 14 08-06-2008 09:47 AM
2.5rs to ej20 swap, what times did you trap? erice1984 Subaru Conversions 32 06-17-2005 06:31 AM
wrx ---> 2.5rs muffler swap xthexjoker Normally Aspirated Powertrain 1 06-05-2003 02:18 PM
