Old 05-18-2001, 03:19 PM   #1
Jessie James
Member#: 2072
Question What does more torque do?
Okay, let's say you could double your torque on a RS. (So around 300-ft/lbs of torque, or whatever.) What performance gains would be recognized?
Better 0-60? Quarter Miles? How much better, theoretically?
[Edit - re-phrased my question.]
[This message has been edited by RS25.com (edited May 18, 2001).]
Jessie James is offline   Reply With Quote
Old 05-18-2001, 03:29 PM   #2
Thor's Hammer
Member#: 6088
2002 Impreza WRX
Sedona Red
Post
First of all, torque is a measure of rotational force, measured in units of force*length. For instance, with a longer wrench, length goes up, force stays the same, and torque goes up.
Double your torque? It would have a huge effect on every aspect of operating your vehicle.
-Probable transmission, clutch, and differential damage.
-Probable change in gas mileage, depending on how you did it.
-Probable damage to the engine's lower end (crank, rod, and rod bearings).
You can't just double torque without major modifications.
Torque is most evident when taking off. The more rotational force you can exert on your tires, the faster you accelerate.
-Bryan
BSME '95, MSIE '02
[This message has been edited by Thor's Hammer (edited May 18, 2001).]
Thor's Hammer is offline   Reply With Quote
Old 05-18-2001, 03:33 PM   #3
HomerJay
Member#: 1135
2005 WRX WAGON
Post
You'll have more get up and go from a stand still. I'm sure someone with a engineering or physics background can explain it better. But it basically how power is translated into the tires at lower rpm's. Please feel free to correct me.
HomerJay is offline   Reply With Quote
Old 05-18-2001, 03:45 PM   #4
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
Post
Axles would probably snap and fly out the side of the car ahah.
Or your head would go through the headrest on the seat, on a hard launch.
ahahaha
Jay McDade
Auto Tech--Lincoln/Mercury/Jaguar
www.hometown.aol.com/impreza25rs2000
Old 05-18-2001, 04:08 PM   #5
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Post
horsepower = (Torque x RPM)/5252
Therefore, by simply increasing the torque by two-fold, you have just doubled your horsepower at that RPM.
IE: the Impreza has 166 lb-ft @ 4000 rpm, therefore it has 126hp @ 4000rpm via the equation given.
If you now have 322 lb-ft @ 4000 rpm, you now have 245 hp @ 4000rpm.
Does that help?
More or less, torque gets you off the line and horsepower keeps you going...
-Jon
Old 05-18-2001, 08:15 PM   #6
NebScoob
Member#: 2646
Post
It's a theoretical question guys...
http://www.datsuns.com/torquehp.htm
The Above is a pretty good artical about the relationship between HP, torque and acceleration. A quote from there...
"Any given car, in any given gear, will accelerate at a rate that *exactly* matches its torque curve"
Meaning...when you double the torque you are going to accelerate in any given gear a whole lot faster. What I'm not sure of is if it is double or not. When I do the math in my head it says yes...
F=MA so A=F/M
Lets say mass is 500, torque is 150 gives .3 g of acceleration. Torque is 300, mass same at 500 =.6g acceleration. (I didn't quite pull these numbers out of nowhere, they are rounded examples close to observed numbers, in case you were wondering.)
If you can go from 40 to 50 in four seconds before, will you be able to do it in 2 after doubling the torque? Maybee, but there a lot of hidden variables in there and I don't even like doing acceleration math problems, they make me dizzy. Maybee someone else could help out here.
As for 0-60, quarter mile...There will be improvements in some areas, but you still have to launch, bang gears, ect...which all take time. Doubling the torque will not make you go from 8 sec 0-60 to 4 sec... but 6 should be do-able.
NebScoob is offline   Reply With Quote
Old 05-18-2001, 08:19 PM   #7
tom@kartboy
Member#: 67
1999 Outlasting
the competition.
Post
this
<IMG SRC="http://albums.photopoint.com/j/View?u=1471652&a=12968346&p=48718564" border=0>
tom@kartboy.com
Old 05-18-2001, 08:24 PM   #8
NebScoob
Member#: 2646
Post
"I see!" said the blind man to his deaf dog.
Old 05-18-2001, 08:36 PM   #9
Jessie James
Member#: 2072
Post
I'm not worried about that puny little 5-speed tranny... I have an automatic.
So, basically, more torque sounds like it is the **** for someone who is not concerned about top speed (I'm not.)
Okay, off to do my research. Thanks for all the info guys!
Old 05-19-2001, 10:17 AM   #10
Fido
Member#: 1867
Post
Ya, more torque equals broken tranny...But oh well Ya only live once!
Fido is offline   Reply With Quote
Old 05-19-2001, 11:10 AM   #11
gavin
Member#: 3198
2005 GT LTD Wagon
Garnet Red
Post
gavin is offline   Reply With Quote
What does this switch do ? paulatkinsuk Newbies & FAQs 22 05-26-2001 01:22 PM
What does radiator coolant do to copper? IMPBOY Normally Aspirated Powertrain 2 02-16-2001 06:44 AM
What does the intake do? Skirvdawg Normally Aspirated Powertrain 6 01-15-2001 11:08 PM
So what does a clutch do? Dre2932 General Forum Archive 9 01-12-2001 04:34 PM
Message Board Statistics All times are GMT -4. The time now is 07:26 AM.
