Welcome to the North American Subaru Impreza Owners Club Wednesday October 26, 2016
Old 10-18-2000, 09:22 PM   #1
Member#: 2294
Angry Problem Child Impreza...
my car is only 8mo. old. i took it in to the dealer last week, cuz my check engine was on.and my car was dying on me at stoplights. the techguy said he couldn't figure out what was wrong. he said he reset the codes in the computer. then he told me to drive it around and see what happens! and i still got the same problems, it died on me today too.it seems light my impreza is coughing and can barely breathe! what should i do.im gonna take it in again soon dammit
kAn9ArOo is offline
Old 10-18-2000, 11:10 PM   #2
ImprezaRS dot com
over boosted again
Member#: 1458
2015 Forester 2.0 XT
2005 2.5 RS, 2013 Tribeca
Check the O2 sensor or fuel filter. Also, I had some cracked champion POS spark plugs that cracked by 10,000 miles! Look there too.
The filter and plugs may not explain the check engine light though.
ImprezaRS dot com is offline
Old 10-19-2000, 06:06 AM   #3
Member#: 1415
2008 IS350
'13 SantaFe
I found the same thing on one of my plugs. A hairline crack. If you wiggled it you could see it barely separate but not enough to cause a misfire. Also I had 32K on those plugs and they were worn down to .049. I couldn't believe it. I had 40K on my Dakota champions and they were only worn maybe .002 or so. Heck even the tips weren't rounded yet. In the Subie they were quite rounded. I guess this car loves Spark plugs.
spshultz is offline
HTML code is On
what are the common problems- 99 Impreza Outback dusterbd13 Outback Forum 2 06-03-2007 09:12 PM
ej20 timing belt problem 99 impreza sublime Normally Aspirated Powertrain 10 08-14-2006 12:06 PM
Knock sensor problem 2000 Impreza RS billingsmc Service & Maintenance 2 08-05-2004 09:37 PM
02 WRX wagon problem child, advice? jasonb Warranty Issues & SOA Problems 7 02-03-2004 01:58 PM
Weird starting problem--1993 Impreza KUgrad Normally Aspirated Powertrain 8 03-07-2003 10:07 AM
