Welcome to the North American Subaru Impreza Owners Club Friday June 24, 2016
Old 08-25-2003, 11:20 PM   #1
digitaltekniq
Member#: 18029
Default 30k service + injector flush = serious knock
So,
I had my WRX's 30k service done today, and besides the bill, I thought everything was cool. Well, on the drive home after picking the car up from the dealership, I was getting SERIOUS knock activity in 2nd gear, 3rd gear and 4th gear under load - but it was inconsistent.
My car has knocked twice since I tuned my stage 2 map and has been running very consistently. My question is this, apparently I needed to do an injector flush and I am wondering if the chemicals in the flushing agent will cause poor combustion? I am using the same 93octane gas, which has been very consistent.
For the record:
- TXS stage 2 with uppipe
- IC hoses
- Denso IK22 gapped correctly
- Grounding cables.
- ECU reset was not performed during the service
- Blitz LM panel air filter
My dealer was instructed not to change the air filter and plugs, which to my knowledge they didn't - so I doubt it's the result of putting stock plugs in instead of 1 heat range colder like the Denso's.
I didn't have my laptop with me to run logging, but it was around 3.5k RPM and I am guessing in the 70-90% load columns for fueling. Anyone had a similar experience? I will be running some logging tomorrow on the run to work.
The only major change I can think of is that it was very humid and hot in Austin today. I'm already running pretty rich, I've barely advanced timing over the standard TXS stage 2 map (although I have mapped it down to the 10% load column).
Cheers for your thoughts
Rich
digitaltekniq is offline   Reply With Quote
Old 08-26-2003, 12:42 AM   #2
Member#: 13004
2002 Pump Gas Homo
yucky!! I hate to hear that did they itemize your bill?? I really really wouldnt put it past them to do the plugs. I assume that the boost is still the same? any overheating at all?Better yet make sure the fuel filter is in the right way and the lines are cool
David@Vishnu is offline   Reply With Quote
Old 08-26-2003, 09:25 AM   #3
digitaltekniq
Member#: 18029
Yeah, I have the itemised bill, I'll run through it and check, and I might just pull the plugs to check too. They did change the fuel filter, so I'll check that too
*sigh* - just when my car was running strong too. We might have to do some logging/tuning this weekend if you're free
Edit: Boost is still the same, and I think they did a radiator flush, which will have got rid of my Water Wetter cocktail, so I'll have to get more of that in there. I'm probably going to do a pure water and water wetter mix, seeing as though we rarely ever freeze in TX.
Old 08-27-2003, 08:02 AM   #4
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
Originally posted by digitaltekniq
Yeah...
...I'm probably going to do a pure water and water wetter mix, seeing as though we rarely ever freeze in TX.
That could end up being a very costly decision on your part.
Old 08-27-2003, 08:34 AM   #5
PaulRex
Member#: 12454
10 Toyota Taco
K8 SV650SF
An injector flush at 30k? I have 52k on my car and have never done this is that a common thing in wrx's to flush injectors?
PaulRex is offline   Reply With Quote
Old 08-27-2003, 08:36 AM   #6
digitaltekniq
Member#: 18029
We don't freeze solid in Austin very regularly, the days when it does freeze, my car is sat in the garage. I might mix in a bit of glycol to keep it from freezing if it ever got cold enough to freeze solid in the garage (which I very much doubt).
The one thing I do know is that Water Wetter does not have enough of a rust inhibiting characteristic. There is another coolant mix (forget the name) that I am trying to find that is similar to Water Wetter but is a very good rust inhibitor.
Old 08-27-2003, 08:40 AM   #7
digitaltekniq
Member#: 18029
Yeah, apparently it needed it. As an update, I did some tuning yesterday and richened up the fueling .2 across the board, no more knock, car seems happier than it did before. Power is back, and it's smooth and progressive, so I guess my car just likes running pig rich.
Old 08-27-2003, 11:45 AM   #8
Member#: 13004
2002 Pump Gas Homo
ECU fuel table in CL fighting the UTEC
Old 08-27-2003, 12:10 PM   #9
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
Even experts suggest no less than 30% anti-freeze in a normal street driven vehicle because of the corrosion inhibitors present in the anti-freeze.
Freezing isn't really the issue, corrosion is. Trust a materials engineer: Pure water + aluminum / copper + high temperature + a few years = BAD combo.
Corrosion is the primary reason to replace the coolant regularly. There's nothing 100,000 miles does that degrades cooling performance of the liquid that much, but corrosion inhibitors are gone after a year or two. Hence the need to drain and fill with new stuff.
Concillian is offline   Reply With Quote
Old 08-27-2003, 01:40 PM   #10
digitaltekniq
Member#: 18029
Concillian : cheers for that, I bow to your superior materials science knowledge
Hmmmmmmmm....
Old 08-27-2003, 01:51 PM   #11
Member#: 13004
2002 Pump Gas Homo
Hmmmmmmmm....
Its not bad (though not ideal either) Its just having to make slight comprimise in CL conditions between parameters thatare close to the different tables and performance so the changes wont be severe enough to cause knock. I do assume that this occured out of OL Utec controlled conditions?
Old 08-27-2003, 02:43 PM   #12
digitaltekniq
Member#: 18029
Yup - right on the crossover between CL and OL. It's running fine now, I'm keeping an eye on it.
Old 08-27-2003, 04:10 PM   #13
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
I believe the coolant that you're looking for is NPG+ --> http://www.evanscooling.com/html/npgPls2.htm
Old 08-27-2003, 10:45 PM   #14
digitaltekniq
Member#: 18029
Nice one, thanks 8Complex
Midwest Services - Oil Changes, 30k Services, 60k Services, Dyno Rentals!! P&L Motorsports Inc. MWSOC Vendor Classifieds 28 07-02-2007 05:17 PM
('93-'01) 30k service...what did you pay? JasonRan Impreza Forum 17 11-22-2006 10:16 AM
30k service. How much? Dorkfish South West Impreza Club Forum -- SWIC 1 07-24-2001 07:28 PM
Performing 30k service..... BoxeRShorts General Forum Archive 2 01-21-2001 08:58 PM
30K Service-? paultg New England Impreza Club Forum -- NESIC 12 12-12-2000 10:03 AM
