Old 08-26-2003, 01:57 AM   #1
scobaru
Member#: 31345
05 LGT, GC8, NA
blue, white, blue
Default fuel problem with that thing behind the headlight
I have a 94 fwd with the AWD converison if that makes a difference
and theres this thing thats behind the headlight of the passenger side and the problem is when I start up my car fuel pours out of the bottem of that thing I don't know what to do or what it is heres a pic of what it looks like
help pleaseeeee
scobaru is offline   Reply With Quote
Old 08-26-2003, 02:39 AM   #2
AWJunkies
Member#: 32934
99 2.5RS JDM WRX
I have same thing on my JDM WRX. the skylines have it too and the legacy turbo US. I have no idea what it is either nor do the poeple with the skylines. I have mine open at bottom and nothing is leaking out to my knowledge. I thought it is a vapor killer kinda thing. It recycles some gas fumes back to fuel tank. I have no idea help ME too! the skylines and the legacy's go back with a tube back towards fuel tank it also says fuel tank on it. If you look at canister closely it says fuel tank on bottom.
AWJunkies is offline   Reply With Quote
Old 08-26-2003, 04:13 AM   #3
AWJunkies
Member#: 32934
99 2.5RS JDM WRX
I am looking it up now in my manuel. May take a while eheh so many pages!
Old 08-26-2003, 05:40 AM   #4
scobaru
Member#: 31345
05 LGT, GC8, NA
blue, white, blue
well I was looking at the book and it has to do with emissans control I think its suppost to let the air out of the gas line but that doesn't explain why gas pours out of mine I'm thinking about blocking it off all together and screw it
Old 08-26-2003, 06:22 AM   #5
AWJunkies
Member#: 32934
99 2.5RS JDM WRX
Yeah there version of smog in japan! but still y does it say to fuel pump? does your say that? the skyline did and mine! There shouldn't be anything coming out I checked mine leaks fumes out of there!
Old 08-26-2003, 06:25 AM   #6
scobaru
Member#: 31345
05 LGT, GC8, NA
blue, white, blue
mine say's fuel tank I think maybe got a 1.8 jdm motor
Old 08-26-2003, 08:15 AM   #7
AKGC8
Member#: 1305
2000 Impreza
That's the charcoal canister. Don't ask me why fuel is coming out though, I thought they just handle fumes. Maybe the canister itself is bad?
AKGC8 is offline   Reply With Quote
Old 08-26-2003, 12:30 PM   #8
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
whoa bad!!!!
yes it is the charcol canister it is used to vent the vapors from the fuel tank .. all subarus have them. they are in the back of the car on the newer models..
my guess is that you hooked up the fuel pump incorrectly did you have the pump out recently?
Old 08-26-2003, 07:26 PM   #9
AWJunkies
Member#: 32934
99 2.5RS JDM WRX
WOW two questions real fast is it bad to suck those fumes into the intake? I ASSUME IT IS VERY BAD! Also is it bad to let it out into engine bay should i hook up a hose and bring it to the back of the car? and let it dump there? no fuel just fumes for me.
Old 08-26-2003, 08:48 PM   #10
HeMan1320
Member#: 26067
2003 WRX
Open Sourced
logic would tell me that gas coming out of anywhere but the injectors is bad.
HeMan1320 is offline   Reply With Quote
Old 08-27-2003, 02:17 AM   #11
sick1.8t
Member#: 22345
2003 RSX
black
there are three lines coming from the fuel tank area on your car. one for fuel feed to the injectors, one for return of excess fuel, and one that vents fuel vapors from the tank. the last one vents the fuel vapors, send it through the charcoal cannister, and then the vapors are regulated by a solenoid, and when told to they are sent into the intake.
you can take that cannister out and just plumb the hose over where is used to be. just keep that one way check valve going the right direction.
if fuel is coming out, i would gess that at some point you rearranged the 3 fuel hoses where they come into the engine bay.
either that or you have a much larger problem goin on in the rear of you car.
sick1.8t is offline   Reply With Quote
Old 08-30-2003, 07:00 AM   #12
anders8
Member#: 26658
1 Love Grassroots
NASA Rally Sport FTW!
Unfortunately, your assumption is the opposite of the intention of the design.
The whole point of the charcoal canister is to "trap" fumes like this and release them into the intake. Think of it this way: If you had a bunch of gas fumes, what's the simplest and safest way to get rid of them? Burn them up along with all the other gas, in the cylinder.
To the original question, gas pouring out: I've actually had this happen on my 1971 MGB when one of the carb needles wasn't seating properly. So in addition to checking that all the lines are routed correctly, you will need to check that there isn't a blockage in any of them.
Anders
anders8 is offline   Reply With Quote
IT crew: Problems with web server behind SonicWall 3060 Kinsbane Off-Topic 18 04-07-2010 11:43 PM
That rubber thing behind the brake under the strut Gso2k Brakes, Steering & Suspension 15 07-12-2008 06:24 PM
What is the two red things behind the grill on some subys?? BBBsti LTD Member's Car Gallery 16 12-28-2005 09:34 PM
whats that thing behind me glove box? patrick smith Car Audio, Video & Security 6 12-09-2005 03:07 PM
('93-'01) What the heck is this thing behind the wheels? Andrew Impreza Forum 18 07-08-2001 11:58 AM
