Old 08-26-2003, 02:55 AM   #1
imprezive one
Member#: 16906
2k3 wrx wagon
Default Help me diagnose my engine problem!
Long story short:
Parts on the car as of now: Turboxs UTEC stage 4, off the shelf stage 4 map, throttle body coolant bypass mod, halman MBC... turbo (vf-30), injectors, fuel pump, and uppipe have been on the car for about 600 miles... turboback has been on there a bit longer. I've noticed the exhaust backfiring a bit before problems started happening, but I think this was just simply due to the conservative off the shelf map and a rich A/F. I was having issues boosting too high (~20 psi) and was knocking the slightest bit on the rare occasions that I pushed the car in the higher gears.
Two days ago I got on the throttle in second gear to pass a car when I hear my exhaust suddenly get a lot raspier and a lot louder from the engine side. The car sounds like it has an old rusted out muffler on it, except I think I've isolated the origin of the new sound to the uppipe/turbo/downpipe area. I checked all of my boost lines, my intercooler piping is secure, my egt probe didn't pop out of my uppipe, I'm not overheating, not leaking any fluids, still building/holding boost just as before, car idles fine and drives fine. Performance is the same with just a slight drop in throttle response and maybe a little bit slower spooling up. I suspect it's my uppipe and the subydude gaskets that I used... maybe those have blown out like they did for other people. Does an uppipe leak have more of a squeeling sound though? This is just a really raspy gurgly type of noise when I get on the gas over ~3k rpm's.
Anyone have any other ideas?
Is internal engine damage a possibility here? Please note that the Nitrous Oxide 50 shot is/was not currently on the car and when it was, only used around 4 times. Also, a compression test was done after uninstalling the nitrous and everything was fine. any suggestions or agreements on the uppipe leak? Thanks.
-DK
imprezive one is offline   Reply With Quote
Old 08-26-2003, 08:23 PM   #2
imprezive one
Member#: 16906
2k3 wrx wagon
anyone? anyone? bueller? bueller?
Old 08-26-2003, 09:43 PM   #3
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
You more than likely have a uppipe leak. This is because it is taking longer to get boost and have slower response. I am guessing that you aren't hitting your normal boost level as well.
I would probably guess you have a problem with your subydude gaskets.....JUST LIKE I DID! This thread talks about the problems people have been having with them. This is exactly what my problem looked like:
There was a chunk missing on the engine side of the uppipe to manifold gasket. You can't see it unless you have an inspection mirror. I got my money back from subydude, which is really cool, but feel he does lead people astray. The reason for this is he recommends you re-tighten the gaskets after 100 miles of use. This was emailed to me 2 weeks after my purchase and after 1000 miles of gasket use. After 1500 miles or so on my gaskets, I had a blow out. This advice is also not on the purchase page of his site where you buy the gaskets either. Had I known prior to purchase, I wouldn't have messed with it.
$70 in OEM gaskets and I am good as new now, but really wouldn't recommend these gaskets to anyone. Subydude for other stuff, but not these gaskets.
FYI, I discovered the problem as follows, which is rather different than the other uppipe leak sounds I have read about in the past. Upon start up, I heard say 50% of the regular muffler noise and it seemed like 50% of the noise was coming from under the motor. It really sounded like a loud VW engine. It was tolerable under 3k RPM and no boost. Boost or over 3k RPM and it sounded like a top fuel VW.
Check your gaskets, I am willing bet it is a blow out and maybe in the same location. The pic used above is the blow out from another subydude gasket user with the SAME exact blow out. Best of luck.
Old 08-27-2003, 10:42 AM   #4
imprezive one
Member#: 16906
2k3 wrx wagon
Thanks a lot man. I managed to get under the car after work yesterday and I did feel a stream of hot air coming from under the car around the area you've described. I'm almost certain that you're right because it does sound like the 50/50 sound mixture that you described, dead on consistent with the below 3k rpm's and no boost also.
Now my question is, $70 in OEM gaskets? They cost that much? I was under the impression that they were a lot cheaper. How many gaskets in total did you change out? Thanks.
-DK
Help me diagnose my brake problem! WRXinEFX Brakes, Steering & Suspension 2 10-28-2009 10:09 PM
Help me diagnose my brake problem! GLrunner13 Newbies & FAQs 9 10-14-2009 05:01 PM
OT, Help me diagnose my laptop problem, please. karnick Off-Topic 16 05-22-2009 09:06 PM
Please help me diagnose my WRXs problem (thought it was a CV shaft) tja1618 Transmission (AT/MT) & Driveline 19 08-16-2008 04:31 PM
Please help me diagnose my clutch problem redoktober_99 Transmission (AT/MT) & Driveline 0 01-27-2007 11:48 PM
