Old 08-26-2003, 03:17 AM   #1
bambams247
Member#: 39366
2003 Impreza 2.5RS
Midnight Black Pearl
Default A few questions about Hyper Ground System (low resistance grounding cable system)
HEY! I am jsut doing some research and wondering about a Hyper Ground System (low resistance grounding cable system).
I would be interested in purchasing this for a 2003 Subaru Impreza 2.5RS (bugeyed)
Here are my questions:
- Has anyone purchased this kit?
- What is the performance improvement on the kit?
- Was it worth it?
- Does anyone have pictures of the install?
Thanks in advance!
bambams247 is offline   Reply With Quote
Old 08-26-2003, 09:13 AM   #2
IggDawg
Celebrity Guest Star
Member#: 10648
1998 Acura CL... D:
Mostly kind of red
just go to home depot or radio shack. buy a bunch of big gauge braided copper wire and some crimp fittings. more flexible is better. it won't wiggle out of the crimp fittings as quick. and run your own grounds. all the hyperground kit is is just wires and a distribution block. there's no magic.
-IggDawg
IggDawg is offline   Reply With Quote
Old 08-26-2003, 09:19 AM   #3
Neek
Member#: 3400
2016 Red Pirate Cat
1981 CJ-7
Agree with Igg...I did my own grounding as well...scoobymods has a page on it too, I believe. I haven't noticed much difference, but who knows
Neek is offline   Reply With Quote
Old 08-26-2003, 10:56 AM   #4
PARANOID56
Member#: 22035
2003 Brocoma DCab
71 FJ40, 13 DRZ400SM
I used the Speedmonkee kit (and now i see a group deal going on for these for only 55 bucks shiped LINK look at the last page, or in the group buy section.
I put this on my 03 RS2.5 and it smothed out the idle, and got rid of the little hesatation.
for the price, (and look) its a good deal.
Thanks
Shane
PARANOID56 is offline   Reply With Quote
Old 08-26-2003, 11:51 AM   #5
IggDawg
Member#: 10648
1998 Acura CL... D:
Mostly kind of red
I wouldn't reccommend that design if it is what I think it is. it says that it has one big mother wire that goes to the passenger side strut tower, and a bunch of smaller wires that go from that point. the whole idea behind the grounding mod is to reduce the number of connections between the sensors and the battery. it should be one wire from the battery to that strut tower, and a bunch of other wires from teh battery to all the locations. it has nothing to do with the width of the wires. it has everything to do with the number of connections.
-IggDawg
Old 08-26-2003, 11:58 AM   #6
PARANOID56
Member#: 22035
2003 Brocoma DCab
Yep, that is the design, but it really has to do with path with the least resistance. So, with the 8ga wire, there is little to no resistance from the ends (all 5 of them) to the negative side of the battery. One of the other reasons that I think all the other kits out there are just a bunch of wires is because of ease of manufacture, where as these look like a PITA to make.
Shane
Old 08-26-2003, 01:36 PM   #7
IggDawg
Member#: 10648
1998 Acura CL... D:
Mostly kind of red
a much thinner wire would still have close to zero resistance. it really has to do wiht the number of connections, since hte wires themselves are not a high resistance path. the chassis is a big chunk of metal. much less resistance than a wire. the engine block is solid metal. even less resistance. so where does the resistance come in? at the connections where wires meet and whatnot. and believe me, it doesn't take much of a wire to be a very low resistance path. 12-14 GA would be fine. it's a simple 12-volt circuit with very few amps running through each wire. the benefit comes from reducing the number of junctions the current has to travel between the ground post and the sensors.
trust me on this one . look up the big long SPG thread we had in here a while back. I go VERY deep into detail about how all this works.
-IggDawg
Old 08-26-2003, 05:35 PM   #8
Dr. Morbid
Member#: 24945
1994 Burnt In Fire
White Metal
I have the AroSpeed Groundwire kit (my buddy works at the local import shop so the price he cut me was cheaper than buying wire and conncections myself).
Looks very nice and seems to work. Dropped my low idle by ~500rpm, fuel economy improved a bit, and the cool thing is at 3000rpm its like a little shot of nitrous that makes the tach ramp up much faster than it used to.
Could be psychological desire playing a role although it makes my butt dyno smile sideways so something happened inside the engine bay.
Dr. Morbid is offline   Reply With Quote
Old 08-27-2003, 05:25 PM   #9
4wheelflyer
Member#: 18247
90 R32 Skyline
GTS-T Type M
I just made one a little while ago, I just used some nice 8G wire
and bunch of connectors ect.... any ways it does help a bit , I noticed better response , bit more torque thats about it.
if you are going to put one make sure you battery is unplugged for about 1 hour (to reset ecu) then idle for a few min, then go for a good high RPM ride and your set.
4wheelflyer is offline   Reply With Quote
A few Questions regaurding the steering system. 05Scooby Brakes, Steering & Suspension 2 05-18-2010 02:37 PM
A few remaining questions about wiring a system... xenster Car Audio, Video & Security 11 03-19-2008 08:27 AM
Few questions about 2004 STI rear diff and a few other related concerns sonic03rex Transmission (AT/MT) & Driveline 9 01-31-2008 01:54 PM
Few questions about the Perrin Turbo Inlet and about the Samco MAF arm???? BLUETURBOWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 27 08-21-2003 03:53 PM
Question about 99RS intake system johnlee Newbies & FAQs 4 12-08-2000 07:35 PM
