Old 08-26-2003, 10:03 AM   #1
Mike Smith
Member#: 744
00 BRP RS Coupe
02 Forester, 00 S-10,
Question Dumb question about oil changing
Once upon a time, I always changed my own oil. I'm fully capable of the task. However, a looong time ago, I was changing the oil on a car for the first time, and I confused the oil pan drain with the transmission oil drain. After unknowingly draining the tranny, I proceeded to fill (over-fill) the engine oil. Next day I went to a Solo 2 and the excess oil pressure during a run caused the extra oil to blow through the PCV valve into the carb, causing a HUGE cloud of smoke out the exhaust. I then drove home and noticed a little extra gear whine from the tranny. At that point I realized what I had done. After refilling the tranny everything was fine - no harm done. However I've been a little gun shy about doing my own oil again - that and having the quick lube places do it for $20 makes changing my own oil less attractive.
However, now that I use Amsoil and get my oil mail-order, it makes sense for me to go back to doing it myself. Am I correct in thinking the drain on the bottom of the passenger side of the 2.5 engine is the crankcase oil drain? If someone has a pic, I'd feel even better. Thanks.
BTW, anyone who wants to make light of my little adventure, feel free. My wife - who witnessed the whole thing, still reminds me of it from time to time. And a few Solo people who are old enough to remember also bring up the occasion - it's a bit of Glen Region SCCA lore. In fact, when I'm lying under the car next weekend, changing the oil, I fully expect my wife to remind me SEVERAL times of my shady history. It's one of the joys of marrige.
Mike Smith is offline   Reply With Quote
Old 08-26-2003, 11:23 AM   #2
Zola
Member#: 16876
2002 Impreza WRX
WR Blue
Default Re: Dumb question about oil changing
Yes, that's the correct spot. Shouldn't there be a picture of this in your owner's manual? I'm pretty sure mine shows it.
Zola is offline   Reply With Quote
Old 08-26-2003, 12:03 PM   #3
Mike Smith
Member#: 744
00 BRP RS Coupe
Default Re: Re: Dumb question about oil changing
Actually, I didn't look, because I've had so many manuals that don't show it, they just say "get your oil changed by a qualified service representitive".
Old 08-27-2003, 06:48 PM   #4
thng
Member#: 8062
Don't feel bad. In the beginning I drained the oil on a car once and forgot to put the plug back in. I had the 4 quart fill can already full and proceeded to fill the engine. I walked away for a moment then came back and checked the oil level. No oil on the stick!
I never considered to check the drain plug and thought maybe I didn't fill the can with enough oil so I filled the engine again but with 2 quarts, walked away and came back. Still no oil on the stick. Some one across the alley yelled out that I have a massive oil leak. I looked and sure enough there's a river of oil that wound its way towards the back of the car and along the fence and I never saw it.
That was a major embarassment and I always remembered to put the drain plug back in and never walked away from the car with a job half done again.
thng is offline   Reply With Quote
Old 08-27-2003, 07:38 PM   #5
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
thng: I had that happen. Luckily I can blame it on my buddy who didnt know what I meant when I said "put the plug back"
Old 08-29-2003, 05:02 PM   #6
kturner
Member#: 8225
Besides being on the tranny instead of the engine, the tranny plug on my 01 is 21 mm. Much bigger that the engine oil plug.
kturner is offline   Reply With Quote
Old 09-06-2003, 03:15 PM   #7
Mike Smith
Member#: 744
00 BRP RS Coupe
This was a Fiat, and the tranny plug was a standard hex nut, while the crankcase plug was a big allen head bolt. It never occured to me that they would use the allen for the crankcase - I figured it would be the other way around. Italians!
Question about oil change at 1,000 Miles eshtog Service & Maintenance 75 07-07-2004 07:55 PM
Quick question about oil change AlucardR Service & Maintenance 5 03-27-2004 04:21 AM
Quick question about oil change T-WREXX Texas Impreza Club Forum -- TXIC 11 03-19-2004 02:59 PM
A few questions about Oil change... IBO Newbies & FAQs 20 07-13-2001 03:42 AM
Question about Oil Changes + Dealership Fido General Forum Archive 6 11-17-2000 06:47 AM
