Old 11-15-2000, 06:50 AM   #1
PerformanceAutoSolutions
Member#: 853
2011 STI Sedan
Satin White Pearl
Lightbulb 2.5 rs--engine using oil
IF YOU HAVE A 2.5 RS AND THE ENGINE IS USING
OIL--YOU MAY HAVE A POUROUS CYLINDER HEAD.
ENGINE NUMBERS--379000 AND UNDER-VERY HARD
TO DETECT-POUROUS PROBLEM FOUND ON THE
CYLINDER HEAD-WHERE THE VALVE SPRING SEATS
-UNDER THE STEEL RETAINER.THERE ARE VERY FEW
CONDITIONS OF THIS--SAME PROBLEM MAY OCCUR
IN A FORESTER.
DAVE
M.S.P.T
PerformanceAutoSolutions is offline
Old 11-15-2000, 06:52 AM   #2
yebokmj
Member#: 2213
1995 Impreza w/EJ255
Brilliant Red
Post
Are these Phase Two or Phase one blocks? Are they most likely to be in cars of what production date or lower.
Thanks
Joshua
MY98 RS
Subaru Salesman
yebokmj is offline
Old 11-15-2000, 07:32 AM   #3
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
Post
Dave, thanks for the info. Could you post the complete TSB? If it's easier you could fax it to [edited] and I will post it.
[This message has been edited by ColinL (edited November 15, 2000).]
ColinL is offline
Old 11-15-2000, 07:34 AM   #4
JGard
pooptastic
Member#: 1904
2011 E70 X5 35D
E36 M3/4/5
Post
where do you find your engine number?
JGard is offline
Old 11-15-2000, 07:34 AM   #5
ImprezaRS2000
Member#: 779
1998 STi Wagon
Post
OOH!! How do you tell what engine number you have?? I could swear my engine just eats up oil!
ImprezaRS2000 is offline
Old 11-15-2000, 08:31 AM   #6
Tony
Member#: 287
2005 9-2X Aero
Desert Silver
Post
I'd love the TSB too, or any offical document for that matter. My car is having an oil consumption test done at the dealer for the next 10 weeks. It's been eating oil for a while now. I have to bring it in every two weeks for five visits total where they are checking the oil consumption.
FWIW my car is a MY99 manuf. date 10/98.
Tony
[This message has been edited by Tony (edited November 15, 2000).]
Tony is offline
Old 11-15-2000, 08:37 AM   #7
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
Post
hmmmmmmm...
my car ate oil
my car blew up!!
lost cylinder #2
Phase I engine....
98 RS's and 99 GT's may have this problem.
not that SOA would ever admit that it's a manufacturers defect.... but...
Subie Gal is offline
Old 11-15-2000, 08:39 AM   #8
JGard
pooptastic
Member#: 1904
2011 E70 X5 35D
E36 M3/4/5
Post
so with a MY00, should i not worry? i don't even know what my oil consupmtion is (if any) since i have to change my oil about once a month
JGard is offline
Old 11-15-2000, 09:20 AM   #9
Member#: 853
2011 STI Sedan
Satin White Pearl
Lightbulb
the engine affected are sohc--2.5l
engines--the engine number is located on the top of the block-left rear-where the engine and transmission meet.embosed in the block.
there are no tsb"s available.problem is new.
-if your spark plugs are black after 500 miles-you may have this problem-also if you using 1 quart of oil in 500 miles.we are still in the process of repairing the vehicle.i will let you know.
DAVE
M.S.P.T
Old 11-15-2000, 09:37 AM   #10
Tony
Member#: 287
2005 9-2X Aero
Desert Silver
Post
Sounds exactly like my symptoms except my block number is 439,###. Assuming I got the right number. It was engraved into a metal block section on the drivers-side below the second air box.
Have you also noticed a sooted up bumper near the tail pipe?
Tony
Tony is offline
Old 11-15-2000, 03:41 PM   #11
cakagan
Member#: 251
1998 Impreza 2.5 RS
Exclamation
Crap, why wasn't something that formal posted for the Phase 1 ('98 DOHC) engines?
-Chris
cakagan is offline
Old 11-15-2000, 05:04 PM   #12
RallyeX
Guest
Member#:
Post
I had this problem.
First dealer said there is nothing wrong.
Second dealer had the car for 1 month, changed left cyclinder head and said the problem was fixed. (Problem was not fixed).
Dealer #3 had the car for 3 days and called me and said to pick up my car because I have an after market exhaust from the cat back. They said no warrenty work with the exhaust.I picked up the car, called SOA and raised hell with them. 1 month later SOA called and said to take the car back to dealer #3 as is and they would be happy to take care of it.
1 month later I got the car back with a new motor, new fly wheel, clutch plate, pressure plate, bearing, driver door glass, detailed inside and out.
The car is running good so far.
RallyeX
HTML code is On
Swap 1999 2.5 RS engine for 2001 2.5 RS engine c0mrade Subaru Conversions 5 06-15-2006 09:19 PM
WTB: Phase 1 or 2 2.5 RS engine keirnna Private 'Wanted' Classifieds 3 06-02-2005 05:18 PM
FS: Used 2.5 RS Engine, $350 O.B.O. Tony Mid Atlantic Impreza Club -- MAIC 22 08-20-2002 01:59 AM
FS: Used 2.5 RS Engine, $350 O.B.O. Tony Tri-State Area Forum 14 08-19-2002 02:43 PM
2.5 RS Engine/Drivetrain for Sale CoByRS General Forum Archive 1 05-28-2000 06:01 PM
