Old 08-26-2003, 02:02 PM   #1
schnell
Member#: 14362
2002 TS Wagon
Midnight Black Pearl
Question Help diagnose an oily transmission
I have a 2002 TS wagon, MT.
A week ago it was on a lift and I noticed that the drivers side of the tranny was oily and had lots of oily crud clinging to it.
There are no drip marks in my driveway, and the level when cold is at the Min mark.
On the tranny where it is 'wet' there are numerous bolt heads on it, could one be loose? Can I tighten them? Is that most likely the problem, because I couldn't see any other place for the fluid to come from.
Thanks,
jason
schnell is offline   Reply With Quote
Old 08-26-2003, 03:28 PM   #2
cky211
Member#: 31129
02 WRX MPB
No TGV + lots of P&P
One day at the dealer I got to stand under a WRX on a lift and talk with the Subaru mechanic. My main concern was a layer or film of oil on one of my axles that caused a little bit of dirt to stick to it. He said that was normal and the WRX on the lift the axles were both almost solid black. I also asked about the tranny oil level and he told me they come from the factory with the oil on the low mark. That is how my WRX was.
No oil on your driveway is a good sign.
-Scott
cky211 is offline   Reply With Quote
Old 08-27-2003, 02:32 AM   #3
santofontana
Member#: 26876
1994 Camaro Z28 383
Black M6
Check your trannys axle seals I found my drivers side one leaking the other day. Anyone else notice this?
santofontana is offline   Reply With Quote
Old 08-27-2003, 10:58 AM   #4
schnell
Member#: 14362
2002 TS Wagon
How do I check the axle seal? Does a shop need to do that?
Old 08-27-2003, 05:09 PM   #5
cky211
Member#: 31129
02 WRX MPB
My car did this and I thought it was a transmission leak.
I was wrong this is a bad axle. You go to the dealer and they fix it.
-Scott
Old 08-27-2003, 06:17 PM   #6
thng
Member#: 8062
-Scott
What was bad about the axle? At first it looked like the oil mixed with water. Is the bearing broken or worn?
thng is offline   Reply With Quote
Old 08-27-2003, 06:20 PM   #7
santofontana
Member#: 26876
1994 Camaro Z28 383
Black M6
-Scott
Same exact prob on my car ...
(i thought it was the tranny though)
Old 08-09-2005, 05:42 PM   #8
menghang
Member#: 58966
I got the same problem.
What did you ever do?
menghang is offline   Reply With Quote
help diagnosing whine from the engine bay or transmission Chuck H Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 03-19-2010 08:58 AM
help diagnosing transmission noise atlblu Transmission (AT/MT) & Driveline 4 08-06-2009 05:14 PM
help diagnosing transmission noise atlblu Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 08-06-2009 08:20 AM
help diagnose an axle problem, pic inside... doubledribble Transmission (AT/MT) & Driveline 8 04-25-2007 01:16 PM
Need help diagnosing an engine problem Yotsuya Mid West Subaru Owners Club Forum -- MWSOC 10 04-07-2003 02:17 PM
