View Poll Results: Use lower o-ring
Yes, force it in there 2 22.22%
No, you don't need it 5 55.56%
I don't know, but had to vote 2 22.22%
Voters: 9. You may not vote on this poll
Old 08-26-2003, 06:28 PM   #1
GLwagon
Member#: 16696
2002 WRX Sedan Stg2
2013 OBW roll'n at 30+mpg
Default PE injector o-ring locations?
Please look at the pic & answer accordingly if you have had experence with PE series injectors...
The question is do you reuse the stock lower o-ring on a PE injector?
GLwagon is offline   Reply With Quote
Old 08-26-2003, 08:06 PM   #2
GLwagon
Member#: 16696
2002 WRX Sedan Stg2
Here is a thread I have read, however I am getting conflicting information from another source.
http://forums.nasioc.com/forums/show...E650+injectors
Old 08-27-2003, 07:57 AM   #3
chibby goku
Member#: 32121
I have PE 800 cc injectors with Perrin fuel rails. I reused the stock bottom o-rings.
chibby goku is offline   Reply With Quote
Old 08-27-2003, 10:20 AM   #4
CK02WRX
Member#: 27859
2002 EJ257 w/CP's
8cmFP Red, RA 5spd, Hydra
I used the pe injectors with their o-rings and did not have a problem. There is a piece on the stock injector plug that you need to cut off and the pe injectors will snap on and fit the stock fuel rail with no problems. So to answer your question, NO. Just take them out of the box, cut the peice off the stock injector plug, and connect them to the fuel rail.
CK02WRX is offline   Reply With Quote
Old 08-27-2003, 10:36 AM   #5
CK02WRX
Member#: 27859
2002 EJ257 w/CP's
I just noticed you were talking about the bottom o-ring. For some reason I did not look at the picture. Well, I used the stock bottom o-ring and have not had a problem. It might not be necessary but I used them anyway.
Old 08-27-2003, 05:47 PM   #6
GLwagon
Member#: 16696
2002 WRX Sedan Stg2
bump for the afternoon
Old 08-27-2003, 06:04 PM   #7
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
The o-ring in the middle of the body will seal the injector... you do not need to use that seat ring when using the PE injectors.
Old 08-27-2003, 06:29 PM   #8
GLwagon
Member#: 16696
2002 WRX Sedan Stg2
I assumed that as well...
update: the source (don't ask who... I'm not here to smear names/companies) I had been told by has changed their view & has said it also is not needed... oh well... all's well.
Old 08-27-2003, 07:08 PM   #9
03GLHWRX
Member#: 30369
03 WRX SW
Default Don't
Do not use the lower seal ring. It moves the injector up, and you'll need to shim the rail up with washers to fit semi-right. Also, it moves the tip back into the bore so that the spray cone will(?) wet out on the bore instead of spraying into the airflow. I installed with the seal rings on my first go around, then realized my mistake (and poor idle). I then re-did the job to eliminate the lower ring. The body o-ring seals quite well.
03GLHWRX is offline   Reply With Quote
Old 08-27-2003, 10:59 PM   #10
STEALTH-WRX
Member#: 7822
Multi layer snot green
Only use the supplied upper o-ring. It seals with it. You can't use the bottom seal because the injector is longer and wider in that section. I have done it in three cars including my own.
STEALTH-WRX is offline   Reply With Quote
O-Rings for PE injectors - Important Information PolarisSnT Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 20 03-27-2010 03:51 PM
PE 800 O rings??? lagodcm Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 12-13-2008 05:28 PM
helix/pe 850 side feed injector o-rings. c'dalerider Private 'Wanted' Classifieds 2 07-10-2007 03:13 PM
Pe 650 O-rings norexyet Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 01-06-2006 08:12 PM
PE 650s o-rings norexyet Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 09-20-2005 08:01 PM
