Welcome to the North American Subaru Impreza Owners Club Sunday March 1, 2015
Old 08-26-2003, 07:32 PM   #1
TheWRX
Member#: 10279
2005 Lotus Elise
Yellow, #94 SS
Default need part# for... plastic doohickey
I'm looking for a part#, but don't even know the name of the part.
Description: '02 WRX. There's the fairly large platic cover/shield at the bottom/front of the engine (held by 3 bolts and a bunch of plastic pins). Then there's another smaller plastic cover (about 1' by 1' ?) to each side of the large cover, which are only held by plastic pins. My right one (passenger side) is missing (they come loose when you hit cones).
Does anybody have a part# (and possibly name) for the mistery piece? In addition, I could also use a bunch of the platic pins that keep breaking/disappearing. What's the proper name for those, and is there a part#?
TheWRX is offline   Reply With Quote
Old 08-26-2003, 07:46 PM   #2
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
Old 08-26-2003, 07:49 PM   #3
Zola
Member#: 16876
2002 Impreza WRX
WR Blue
I looked for a part number but came up empty. I'm not sure on the actual name of the part, but aren't those things ducts to channel air over your brakes to help cool them? You probably don't need a part number anyway, I'm sure the parts guys at your dealership will understand which part you're describing.
Zola is offline   Reply With Quote
Old 08-26-2003, 08:11 PM   #4
TheWRX
Member#: 10279
2005 Lotus Elise
Yellow, #94 SS
Thanks DrD, forgot that they have those diagrams there. So, navigating WRX, Body Parts, Mudguard, what I'm looking for seems to be called "Plate-right", and the part# is 59123FE000. Does that sound right? And the small pieces used to attach all that stuff are called "clip", and come in a few part numbers, like 46064AE000 and 57728AC090.
Zola Rex: I haven't found the parts guys at the local dealerships to be very helpful, so I'd rather know what exactly I need.
Old 08-26-2003, 10:52 PM   #5
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
If you are looking for the covers to the brake cooling ducts, that sounds right - each one of the plates takes 6 clips, I think. The clips you want are part no 46064AE000 (my car didn't come with either of the plates installed, and my dealer said they couldn't get them so I ordered them from subaruparts shortly after I got my car last year)
Old 08-28-2003, 06:03 PM   #6
TheWRX
Member#: 10279
2005 Lotus Elise
Yellow, #94 SS
Yes, it's the cover that forms the bottom of the cooling duct. I was at the dealer, and the parts should be here in about a week. Subaruparts.com doesn't have the plate in stock, so it would probably be slower. Thanks for the help!
Bolting on front brembos...need part# for knuckle bolts... JeffrWRX Brakes, Steering & Suspension 3 05-19-2008 09:46 PM
Need part# for Subaru rear 2-Pot Backing Plate altibaby Brakes, Steering & Suspension 52 03-16-2007 08:44 PM
need part# for spare tire hold down thingy willyb Tire & Wheel 2 12-07-2005 06:03 PM
Need part# for WG c-clip please Tony Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 10-06-2005 03:21 PM
Need part# for a rubber between top mount and the spring in '02-'03 rear suspension i_doni Brakes, Steering & Suspension 4 09-22-2003 09:44 PM
