Old 10-18-2000, 07:57 PM   #1
Nemesis
Member#: 2465
Post New Impreza with VTD
Just read a post about Outback VTD and whether the New Impreza will get it.
Well I have a Japanese magazine, called "Subaru Impreza: Test Drive Report and Complete Buyser's Guide" (title translated from Japanese), it says that Turbo AT (namely WRX NB with automatic trans.) has VTD system, while MT model (manual) uses "Viscous LSD center diff."
WRX NA uses "Active Torque Split" (translation)...
Well, I may be wrong on the translations.
Nemesis is offline
Old 10-18-2000, 08:01 PM   #2
RidinLow
Member#: 329
1995 325i
Arctic Gray
Post
Is that the same as VDC?
RidinLow is offline
Old 10-18-2000, 08:06 PM   #3
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
Post
Yes.
ColinL is offline
Old 10-18-2000, 08:08 PM   #4
Nemesis
Member#: 2465
Post
Not sure, Japanese uses a lot of abbreviations. I don't even know what VTD stands for. Probably, "variable torque differential"?
This is Japanese Spec. We might get different stuff in america.
By the way, in Japan if you get WRX NB 4-speed auto, you get the "speed-shift"(or manu-matic) for sure, any info on what we'll get here?
Nemesis is offline
Old 10-18-2000, 08:10 PM   #5
Nemesis
Member#: 2465
Post
oops, that's "sport-shift" not "speed" :-)
Nemesis is offline
Old 10-18-2000, 08:14 PM   #6
Nemesis
Member#: 2465
Post
Oh, for the safety issue, the front seats get side airbags too.
Nemesis is offline
Old 10-19-2000, 12:37 AM   #7
Necromancer
Member#: 477
GC4 -> GGA -> GM6
Yeah, that's about right.
Post
VTD is NOT the same as VDC!
VTD is variable torque distribution all wheel drive. Similar to the existing MPT clutch system in U.S. spec automatic tranny Subarus, except I think it has the ability to actually rear-bias the car (rather than simply lock up the center diff). The turbo automatic wagons in Japan have had this for a long time.
VDC is vehicle dynamics control. This is the ABS-like yaw control system employed on the H6 Outback to correct bonehead maneuvers. Given the option, I would probably pass on this feature since it is likely going to try and prevent me from turning the car in properly to a turn. But I haven't driven it yet, so we'll see if that changes.
Cheers,
Joe
Necromancer is offline
Old 10-19-2000, 06:19 AM   #8
T-WRX
Member#: 2468
08 RS4
05 STi - Gone
Post
In AutoWeek's review of the Outback H6, it stated that VDC/VTD will be standard on the New Impreza Turbo.
Here is an explanation:
The Outback H6-3.0 VDC provides unequaled traction and stability using Variable Torque Distribution (VTD) All-Wheel Drive, working in conjunction with the Vehicle Dynamics Control (VDC) system. The VTD and VDC systems operate simultaneously to help maintain traction and stability, and take corrective action before the driver even notices.
The new VTD automatic transmission uses an electronically controlled hydraulic transfer clutch that works with a planetary gear-type center differential to control power distribution between the front and rear wheels. Under most conditions the VTD system splits the power 45 percent front and 55 percent rear. The slight rear-wheel bias enhances the performance driving feel, and the VTD system can vary the power split as needed to respond to road conditions.
Like Active All-Wheel Drive, VTD adjusts the front/rear power split, always helping to ensure that the wheels with the best traction receive the most power.
Vehicle Dynamics Control (VDC) works together with VTD All-Wheel Drive and four-wheel electronic traction control to help maintain directional stability under all driving conditions. The system monitors vehicle stability by continually measuring inputs such as steering angle, yaw rate, lateral g-force and individual wheel speed.
Using that input data, VDC can tell whether the car is going where the driver is steering it. To correct understeer (front-wheel drift), VDC applies split-second brake pressure to the inside rear wheel to help pull the car back on the desired course. To correct oversteer (rear-wheel drift), VDC applies split-second brake pressure to the outside front wheel to bring the rear of the vehicle back in line. Under certain oversteer conditions, VDC can even direct the All-Wheel Drive system to transfer more power to the front wheels. If the situation requires greater intervention, VDC can also direct the engine control module to turn off one or more fuel injectors to reduce power.
The Outback H6-3.0 VDC system adds another layer of driving control -- an all-wheel, all-speed Traction Control System (TCS). Should any wheel spin on a slippery surface, VDC will apply braking force to that wheel to help keep wheel spin under control. Depending on the traction situation, the VDC system can instruct the engine control module to reduce power by turning off one or more fuel injectors. The Outback H6-3.0 VDC can maintain traction even if three wheels are slipping on ice or snow, without the need for a limited-slip differential.
T-WRX is offline
Old 10-19-2000, 07:05 AM   #9
WRC666
Member#: 2351
Unhappy
Out of the sudden an overly tailhappy old 911 comes to the mind of true drivers.
Cars tend to become less driver oriented(for most moron drivers a good thing),
but also very boring to drive. My old 280Z was a blast to powerslide through a turn.
Lets keep in mind, thats fun driving.
Too much control for me in those new cars.
666
WRC666 is offline
Old 10-19-2000, 09:26 AM   #10
bluesubie
Member#: 767
04 FXT
Post
IF the new US/Can Impreza gets VTD and VDC, a VDC off button would be great for more "spirited" driving. But in the litigious(sp?) U.S. - I don't know.
Dennis
bluesubie is offline
HTML code is On
Brand new Impreza with rusted exaust?? nyrican Newbies & FAQs 12 07-27-2009 08:28 PM
which Forester XTs have VDC with VTD? bWRX Transmission (AT/MT) & Driveline 1 03-05-2009 12:34 PM
new here small problem with new impreza aduke Normally Aspirated Powertrain 10 08-31-2006 10:06 AM
my impreza with new pic [freeman] Member's Car Gallery 25 05-28-2001 08:19 PM
my impreza with new pic JC Interior & Exterior Modification 7 05-22-2001 01:53 AM
