Welcome to the North American Subaru Impreza Owners Club Tuesday February 9, 2016
Old 12-12-2005, 11:56 AM   #1
FalconRS
Member#: 92913
2005 2.5RS Wagon
Crystal Grey Metallic
Impreza WRX To Wrap or Not To Wrap?
Well, tonight I'm finally going to have time to install my header, borla catback, and lightweight crank pulley. Problem is, I haven't had time to wrap the headers yet like I'd planned and that's a process that takes a few days to do right, so it's not like I can throw on the wrap and get it all done tonight.
So, should I hold off and just do the catback and pulley, and get started on the wrapping tonight, or should I say to hell with it, install the header and hope I don't get a cat code?
FalconRS is offline   Reply With Quote
Old 12-12-2005, 12:22 PM   #2
gtwagon941
Member#: 16874
2008 2008 Audi RS 4
2014 Audi S Q5
What header?
gtwagon941 is offline   Reply With Quote
Old 12-12-2005, 12:31 PM   #3
FalconRS
Member#: 92913
2005 2.5RS Wagon
eBay Borla-replica
Old 12-12-2005, 11:09 PM   #4
saloonracer
Member#: 62687
2007 Its a Suby
Yeah..its stock :)
What would wrapping the header do anyway. I know it does something with heat transfer but what does it do specifically.
cheers
saloonracer is offline   Reply With Quote
Old 12-12-2005, 11:16 PM   #5
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
it makes it super pretty and keeps the heat in. The stock header is cast and it's pretty thick. The borla goes all over the place and is much longer so wrapping it is probably not a terrible idea.
Tim Sanderson is offline   Reply With Quote
Old 12-13-2005, 12:07 AM   #6
saloonracer
Member#: 62687
2007 Its a Suby
Yeah..its stock :)
How about sound. The stock header is cast iron and it is thicker than the borlas. The borlas are noisy so would wrapping them do anything to the sound? EX. header noise
Old 12-13-2005, 12:08 AM   #7
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper Wagon
Borlas also had (have?) a tendency to crack even without being wrapped.
I never suggest wrapping headers on a street car.
Old 12-13-2005, 02:11 AM   #8
joltdudeuc
Member#: 6119
1999 GM6
RBP
My exhaust guy told me that header wraps can crystalize, and bond to the stainless steel, and not come off. He advised that I not wrap my OBX headers, and ceramic coat them instead. I decided to just run them, and with about 3,000 miles on them now, they have held up beautifully. They get HOT, but they cool down pretty quick. I have a HFC, and I've so far not seen a CEL for inefficient cat.
-Gagan
joltdudeuc is offline   Reply With Quote
Old 12-13-2005, 10:38 AM   #9
jimbobrand
Member#: 21935
2010 '13 BRZ Premium
WR Blue Pearl
Yeah, ceramic coating is the way to go and as long as they coat it on the inside and out wou won't get the cracking problems like you would with wraping.
-Jim
jimbobrand is offline   Reply With Quote
Old 12-13-2005, 07:02 PM   #10
subygirl
Member#: 61617
2009 WRX 5-door
Dark gray metallic
how much (generally) would a ceramic coat job on borla headers run?
subygirl is offline   Reply With Quote
Old 12-13-2005, 07:32 PM   #11
shoeler25
Member#: 52202
2001 2.5RS
Wrapping them comes from keeping the gases hotter so they move faster, hence letting the engine breathe better. I would definetly coat them, they will help prevent, rust and cracking...plus help insulate. If thats not enough for you then you could wrap them as well. I recommend Swaintech coatings as an alternative to Jethott.
shoeler25 is offline   Reply With Quote
Old 12-14-2005, 10:02 AM   #12
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
bah....
I'd wrap them. (again)
I've had my borla's on the car for 2 years now
wrapped since day one
no cracks. no CEL's. and i just passed emissions....
Jamie
Subie Gal is offline   Reply With Quote
Old 12-14-2005, 10:40 AM   #13
kheff46
Member#: 66739
2002 WRX wagon
wrapping them(on a SS header) helps them rust faster for sure. if you live in a state with salt on the roads have them coated instead of wrapped. you'll thank yourself in the long run! unless you're made of money, then wrap away! -keith
kheff46 is offline   Reply With Quote
Old 12-14-2005, 02:58 PM   #14
veightkiller
Member#: 78967
2011 335i
go ahead and wrap it..it's how much $50 bucks for the heat wrap and a couple of hours..why not?!?!?!
veightkiller is offline   Reply With Quote
Old 12-14-2005, 04:00 PM   #15
shemoves
Member#: 80663
2005 STi
If you do wrap it though...don't use too much or make it thick...follow the instructions.
shemoves is offline   Reply With Quote
Old 12-14-2005, 09:58 PM   #16
mattvct
Member#: 100377
In my experience, wrapping headers does not have much of a negative effect and is worth it. If you're worried about cracking just don't wrap over welds where you've got two pipes coming together in a Y and you'll cut down on hot spots.
mattvct is offline   Reply With Quote
To Heat Wrap Or Not To Heat Wrap? pr4mnc Newbies & FAQs 37 06-08-2011 04:10 PM
To wrap or not to wrap borla header?? scoobysnack69 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 23 08-08-2006 06:04 PM
scooby sport downpipe: to wrap or not to wrap? Hanyoung Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 07-06-2006 04:27 PM
headers: to wrap or not to wrap, what is the answer? wrxracer55 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 12-23-2003 12:02 PM
to heat-wrap or not to heat-wrap downpipe iloveturbos Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 01-29-2003 01:58 PM
