Old 08-27-2003, 01:17 PM   #1
mooshoo
Member#: 19432
Default knocking and pinging on MY00 rs
Well, I think my car is starting to knock and ping. Bought the car new in 2000, and just recently I noticed it. What's the best solution you guys have?
mooshoo is offline   Reply With Quote
Old 08-27-2003, 04:39 PM   #2
Zen
Member#: 12656
there are alot of things to consider
what kind of mods do you have
what kind of conditions do the knocking and pinging happen at
what kind of gas do you put
how long has it been doing this
do you have a cel
Zen is offline   Reply With Quote
Old 08-27-2003, 05:43 PM   #3
Penphoe
Friendly Neighbourhood
Member#: 269
2005 ABP LGT LTD BP6
00 Impreza RS GM6 RIP
I notice that my MY00 pings quite a bit when the weather is hot and I'm crusin up a slight incline. It's definetly related to the weather - since the weather has cooled off here in Vancouver, the pinging is almost nonexistent.
LaterZ!
Darren!!
Penphoe is offline   Reply With Quote
Old 08-27-2003, 06:26 PM   #4
Dr Ken
Member#: 5885
2000 RS (GME)
SilvAr
Please exuze my noobiness...
How does one discern either sound from normal engine noise... or is so damn obvious when it happens, that you just know ?
Thanks kindly.
Dr Ken is offline   Reply With Quote
Old 08-28-2003, 12:46 AM   #5
kickin_81
Member#: 16679
2004 Forester XT
The brand of gas and octane rating of it will have an affect on the motor. I always stick to Amoco and their 92 octane. Get the good stuff for your motor.
(I have the ProECM chip installed. The gas price is expensive, but the throttle response and acceleration makes up for it).
kickin_81 is offline   Reply With Quote
Old 08-28-2003, 09:33 AM   #6
m750
Member#: 2278
8Sti | 07 allez
White | Comp
grade & type of gas?
How many miles on it?
When was your last tune up?
AO
m750 is offline   Reply With Quote
Old 08-28-2003, 12:26 PM   #7
mooshoo
Member#: 19432
The gas I've been using is the costco stuff, 91. Don't laugh. Their gas is actually not bad at all. And plus, they go through so much of it that it's always fresh, and they change out the pump filters more often. Besides, I always see MB, BMW, and Audis there (all new models).
In terms of mods, just an intake and exhaust, grounding mod, (the rest is just handling stuff). I thought the weather might have somthing to do with it, but it hasn't been all that hot lately.
There was no load on the car except me. 1/4 throttle. Sometime it shows up under full throttle. Wierd.
Well, come next week I plan on tearing everything apart, as my new struts are coming in, and fluids, and plugs. Speaking of which, last time I used Redline all around, but I forgot the quantities we need for front tranny and rear lsd. Doh!
Old 08-28-2003, 12:27 PM   #8
mooshoo
Member#: 19432
oops.
70,000.00 miles,
I've always worked on it myself.
Old 08-28-2003, 04:38 PM   #9
m750
Member#: 2278
8Sti | 07 allez
White | Comp
Plugs, wires, fuel filter, air filter?
Old 08-28-2003, 05:04 PM   #10
mooshoo
Member#: 19432
Yeah, I changed the feul/air filters. Havent messed with the wires yet.....
Old 09-02-2003, 10:46 AM   #11
m750
Member#: 2278
8Sti | 07 allez
White | Comp
If you haven't changed the plugs, do so. While you are at it, I'd grab a set of wires too.
Old 09-02-2003, 12:34 PM   #12
mooshoo
Member#: 19432
Well, the plugs went in, along with a new fuel filter, a bottle of injection cleaner. Hopefully that works. I wonder if the fuel injectors themselves are shot??
Old 09-02-2003, 05:31 PM   #13
subijitsu
Member#: 35372
99 STM GM6
RIP BRP GC6
If the plugs dont help try new wires. Mine was doing a similar thing and when I replaced plugs and wires it made all the difference in the world.
subijitsu is offline   Reply With Quote
Old 10-01-2007, 10:41 AM   #14
Benjamin Tang
Member#: 4496
2009 Forester
red
bringing this back from the dead... why would the plug wires make a difference with knocking/pinging?
and would changing to a colder spark plug make any difference?
i'm currently running 89 octane in an 03 forester xs ej25AT trying to get rid of the noise... hoping not to have to go to premium because gas is expensive in my parts
Benjamin Tang is offline   Reply With Quote
Old 10-01-2007, 12:38 PM   #15
mattwalters
Member#: 422
1998 Legacy 2.5GT
Rio Red
If your plug wires are decomposing, they'll deliver less energy to the spark plugs, which will therefore produce a weaker spark. New plug wires = more spark energy = better combustion. This may or may not help pinging.
-Matt
mattwalters is offline   Reply With Quote
Old 10-01-2007, 12:47 PM   #16
Benjamin Tang
Member#: 4496
2009 Forester
red
gotcha. what should i be getting? oem or aftermarket? if aftermarket, what would you recommend?
i can't remember the damn mileage... it's somewhere in the 40k mi range.
Old 10-01-2007, 12:59 PM   #17
imprexaRS03
Member#: 145883
2008 wrx
psm
if it goes with the idle of the car it might be your throw out bearing?
imprexaRS03 is offline   Reply With Quote
Old 10-01-2007, 01:04 PM   #18
Benjamin Tang
Member#: 4496
2009 Forester
red
i am confused by your statement... do automatics have a throwout bearing?
and it dosen't make any noise when at idle.
Old 10-01-2007, 03:38 PM   #19
imprexaRS03
Member#: 145883
2008 wrx
psm
ill ask.......
Old 10-01-2007, 04:11 PM   #20
imprexaRS03
Member#: 145883
2008 wrx
psm
i dont think they have throw out bearings.i mean that could be one of so many things. nearly everything on car has potential to squeak id suppose?
-justin
Old 10-01-2007, 06:19 PM   #21
imprexaRS03
Member#: 145883
2008 wrx
psm
''no automatic's do not have a throw out bearing, instead of a clutch/flywheel they have a torque converter(fluid coupling), now the torque converter does has torrington/roller bearings inside of it." -drummerRS2505
Old 10-01-2007, 07:48 PM   #22
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Modern cars with knock sensors should not be knocking and pinging. If it is, that tells me something else is wrong.
Old 10-05-2007, 01:43 AM   #23
Richard L.
Member#: 8465
'00 2.5RS Coupe, AW
'93 GMC Typhoon AWD
Because many have experienced pinging problems caused by bad spark plug wires. One cylinder (maybe more) would misfire, causing the ECU to detect a rich condition, and lean out the mixture to the other cylinders, causing the engine to ping. Look for open wires, intermittent wires, and leaking wires.
Richard L. is offline   Reply With Quote
Old 10-05-2007, 01:48 AM   #24
Richard L.
Member#: 8465
'00 2.5RS Coupe, AW
'93 GMC Typhoon AWD
The knock sensor can only retard ignition timing to a certain limit. Even without knock sensors, a car should not ping. If the knock sensor has to pull out timing, then yes, there is a problem.
At What Milage are people seeing DET, Knocking and Ping problems JDMTEG98 STi Forum Archive 2 07-17-2003 10:13 PM
Momo hub on MY00 RS? Ashton Interior & Exterior Modification 7 06-15-2001 06:13 PM
MY02 WRX muffler on MY00 RS? HomerJay Normally Aspirated Powertrain 0 05-12-2001 12:56 AM
Will this wheel fit on MY00 RS? raptor Brakes, Steering & Suspension 1 02-17-2001 04:15 PM
Anyone with APEX exhaust on MY00 RS? Momo Technical Forum Archive 10 07-27-2000 12:23 AM
