Welcome to the North American Subaru Impreza Owners Club Sunday July 31, 2016
Old 08-27-2003, 07:14 PM   #1
Ian
Member#: 7274
2002 WRX Wagon
Stealth
Default A/C belt tensioner is broken?
That might explain the squeaking when the compressor starts.... grrrrr
It's that piece that has the bolt that runs parallel to the pulley just below the AC compressor that's broken. I assume this is for tensioning the belt. The bottom of it is swaying in the beeze.
Is there anything else driven off the A/C belt? I'd rather just drive it in (with the flapping piece tied down) and get a new part. I think I could even replace it unless I need a special tool to tighten the belt?
Does someone have a part # I could phone in and order? (Unless it's not fixable at home)
Ian is offline   Reply With Quote
Old 08-27-2003, 07:27 PM   #2
Ian
Member#: 7274
2002 WRX Wagon
Stealth
I think this is it... 73134 73134AC001 Adjuster-idle pulley.
maybe i can find it online
can i Subaru tech tell if a timing belt tensioner is bad by looking at it? BlackoutWRX Newbies & FAQs 9 10-18-2012 10:09 PM
Broken belt tensioner. MB38 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 02-08-2009 10:41 PM
Broke the ac belt tensioner, but ac belt is still tight. Am I safe? garface Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 01-12-2009 04:18 PM
Where is belt tensioner for the AC belt Stover954rr Service & Maintenance 3 06-17-2006 02:15 PM
How do i know if the cam belt tensioner is bad? Motor is out of the car STEALTH-WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 12-14-2003 02:17 PM
