Mid Atlantic Impreza Club
Old 08-27-2003, 10:00 PM   #1
Impreza Rider
Member#: 756
2003 Legacy L wagon
2009 Kawasaki C14
Default Sources of Oil in Coolant?
Per jonmacs22 instructions on coolant level, I decided to check mine and there was none in the overflow tank, so I opened up the cap to see if that was low as well. When I opened it up, I saw a couple of little oil bubbles in the coolant tank. The water temp (from the stock one ) have been normal, but I don't know if it's really high or not.
Sooo...possible places it can come from besides the head gaskets? Please don't tell me that's the only place
Thanks
Impreza Rider is offline   Reply With Quote
Old 08-27-2003, 10:13 PM   #2
SkToBe
Ghost Mod
Member#: 1278
2001 RS
Cracked block?
SkToBe is offline   Reply With Quote
Old 08-27-2003, 10:49 PM   #3
Impreza Rider
Member#: 756
2003 Legacy L wagon
2009 Kawasaki C14
hmmm...I think that I'd prefer head gaskets
Old 08-27-2003, 10:54 PM   #4
cavymeister
Member#: 24463
2003 Chevy S10
91 Hunduh Civic BASE
Could be... could also be cracked head... Or warped head...
Do you over heat much??
cavymeister is offline   Reply With Quote
Old 08-27-2003, 11:11 PM   #5
Impreza Rider
Member#: 756
2003 Legacy L wagon
2009 Kawasaki C14
Like I said, water temps have been normal, but that's also going by the stock gauge.
Old 08-27-2003, 11:14 PM   #6
cavymeister
Member#: 24463
2003 Chevy S10
Is there coolant in the oil?
Old 08-27-2003, 11:32 PM   #7
Impreza Rider
Member#: 756
2003 Legacy L wagon
2009 Kawasaki C14
Is it as obvious as oil in the coolant? I didn't see anything out of the ordinary when I checked the oil level
Old 08-28-2003, 12:31 PM   #8
elgorey
Member#: 4374
06 Titan,99,94 SM
06 nasa spec miata champ
how much is it? a little bit of discoloration in the coolant isnt much to be worried about.
elgorey is offline   Reply With Quote
Old 08-28-2003, 03:00 PM   #9
awoland
Member#: 36455
04 WRX
Platinum Silver
If it is a head problem (cracked, warped, or gasket) you will see oil in the coolant & coolant in the oil.
But, Elgory is right. It might be NOTHING.
A.
awoland is offline   Reply With Quote
Old 08-28-2003, 04:07 PM   #10
Big C
Member#: 3586
2000 RSTI Rally Car
2012 STI SWP Hatch
I've known people who have had this problem when they didn't use sealant on a metal HG install (non subaru). It ends up seeping small amounts of oil into the coolant and vice versa. You need to check your oil though because if enough water gets in there you can damage the bearings in the motor from lack of lubrication. If that happens you will wish you had taken the time to locate and fix the source of the problem!
Big C is offline   Reply With Quote
Old 08-28-2003, 04:09 PM   #11
rhdude
Member#: 6637
2009 Acura MDX Sport
thats true, but if the overflow tank was completely empty, then he must of burned some coolant somewhere...
rhdude is offline   Reply With Quote
Old 08-28-2003, 07:39 PM   #12
Impreza Rider
Member#: 756
2003 Legacy L wagon
2009 Kawasaki C14
I checked the oil again, it looks like it's just oil.
I guess I'll just keep an eye on it, and see what happens.
Thanks
Old 08-29-2003, 02:58 PM   #13
WRX Jim
Member#: 22321
its not unusual to see ur coolant levels going down in the summer expecially with heavy use of ur AC
WRX Jim is offline   Reply With Quote
Old 08-29-2003, 03:40 PM   #14
dj_noose
Member#: 17302
2002 Impreza WRX
you know... the blue one
I would flush the coolant system and do an oil change if you're the least bit worried about it. That way you'll be starting fresh. This way you can see for sure if you're getting oil in the coolant.
dj_noose is offline   Reply With Quote
Old 08-29-2003, 04:00 PM   #15
Big C
Member#: 3586
2000 RSTI Rally Car
2012 STI SWP Hatch
If the system is properly sealed you should never see your coolant levels go down. If you are you have a leak (pressure or otherwise) or you are burning it off somewhere. A properly functioning engine does not use any coolant.
C
Old 08-29-2003, 04:36 PM   #16
AcquaCow
Member#: 36838
2001 SRP RSTi
2011 DGM WRX hatch
I don't think I have anything in my overflow tank...I'll have to look at it tonight.
AcquaCow is offline   Reply With Quote
bad radiator. oil in coolant. what to do!?! koyo users.. jfizzle024 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 06-15-2006 09:27 AM
Oil in Coolant STISTL Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 08-04-2005 07:59 PM
2005 WRB WRX, think theres oil in coolant onyx445 Newbies & FAQs 8 05-30-2005 07:51 PM
Oil in Coolant sniece Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 11-10-2004 07:46 PM
Help: Source Redline Oil in San Diego Albert Southern California Impreza Club Forum -- SCIC 2 07-22-2001 01:36 PM
