Old 08-28-2003, 08:51 AM   #1
garface
Member#: 1581
MY00 RS/STi7
MY01 RS Both Silverthorne
Default What's the purpose of the coolant reserve tank/header tank on top of the engine?
Just wondering what its exact function is. Seems like Subaru has been putting them on their turbo cars forever, but not on the N/A cars. Thanks.
garface is offline   Reply With Quote
Old 08-28-2003, 09:30 AM   #2
CloNeGTS
Member#: 23341
04 Rex STi
WRB/Gold
The reserve tank is set higher than the turbo so that coolant continues to trickle through the turbo after the engine has been shut down. Eliminates need for turbo timer.
CloNeGTS is offline   Reply With Quote
Old 08-28-2003, 09:31 AM   #3
tcs007
Member#: 4103
2016 Mazda6
Red
Hot liquids rise. Your turbo is lower than the coolant cap. Hot liquid leaves the turbo in search of higher ground, pulling cooler liquid in behind it.
Basically it helps the turbo live a longer, happier life.
I'm sure someone will pipe in with a long winded, technical answer, but thats the short of it.
-Todd
tcs007 is online now   Reply With Quote
Old 08-28-2003, 09:40 AM   #4
CTKAG
Member#: 15001
STi V8 Spec C Power
NESIC TrackH0z # 10
The radiator fill needs to be at the highest point of the engine in order to fully get all air out of the system. Since the turbo is essentially higher than the top of the radiator, it would be possible for air to remain in the system, potentially causing an overheating problem. This is common on vehicles with low, sloping noses (Corvettes for example) where the top of the radiator is lower than the water outlet on the engine.
-Keith-
CTKAG is offline   Reply With Quote
Old 08-28-2003, 12:23 PM   #5
samowrx
Member#: 8403
-Todd
hot liquids rise? is that even possible? do you mean hot fluids rise?
samowrx is offline   Reply With Quote
Old 08-28-2003, 01:34 PM   #6
ccdelro
Member#: 14398
2003 White Wag Wrx
Stage Dos
should be hot coolant vapor (not liquid) from the turbo that rises. . . . .
ccdelro is offline   Reply With Quote
Old 08-28-2003, 01:47 PM   #7
garface
Member#: 1581
MY00 RS/STi7
Thanks, I actually found some info on this. Here it is:
"The Subaru WRX engines have their water catch tank high on the engine above the turbocharger. It is that little can where you check the water level. When the engine is shut off the water continues to circulate via a physical property of water called a thermal siphon. Simply put, hot water rises up to the catch tank, being drawn from the relatively cool cylinder head water jacket up through the turbo housing. This nifty little idea works every time you turn off your engine."
fuel lines on top of tank... legacydreamz Legacy Forum 0 03-09-2010 04:06 PM
2 screws on top of gas tank broke with fuel pump install Soflasti Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 18 05-15-2008 06:27 AM
So... I nailed my girl on top of a tank. ryde666 Off-Topic 26 08-21-2006 02:45 PM
Coolant reservoir on top of intake manifold 15secWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 07-28-2005 11:46 PM
dried coolant on top of timing belt cover supermoose Service & Maintenance 8 11-18-2003 11:02 PM
