Old 08-29-2003, 01:00 AM   #1
bemani
Member#: 5673
16 Hellcat
05 LGT, 02 bug eye
Default turning slotted and drilled dba rotors
Is there anything special I need to tell the shop to do when turning drilled and slotted DBA rotors?
bemani is offline   Reply With Quote
Old 08-29-2003, 07:36 PM   #2
WRXURV8
Member#: 14848
2007 Tribeca
TS w/ 20" OZ's
Yeah, you can't turn them. Buy new ones.
WRXURV8 is offline   Reply With Quote
Old 08-29-2003, 11:32 PM   #3
Zornorph
Member#: 17332
2004 Black STI
Not stock anymore
are you sure? Other companies tell you it's ok, just take a minimal amount.
Zornorph is offline   Reply With Quote
Old 08-30-2003, 08:36 PM   #4
captain_dingaling
Member#: 39218
2004 WRX Aspen White
every rotor should have a minimum thickness that can be safely acheived weither it be slotted or crossdrilled, you can get this info from the manufacturer. now once a rotor is warped you can resurface it but it's never really the same, and a resurfaced rotor will always warp faster than a new one. you see race teams resurfacing rotors but its not becuase theyre warped to the point where they vibrate, theyre doing this to maintain a flat surface for the brake pad to stop on, because theyre using new pads. hope that helped.
captain_dingaling is offline   Reply With Quote
Old 08-31-2003, 05:59 PM   #5
imprezzakc
Member#: 22462
2001 AutoFozzyFTW
SilvernBlack
I have the same rotors on the front of my 00 impreza RS I had to take mine to a machine shop for turning . I would trust a machine shop before a auto parts or brake shop . Remember auto parts stores are in the buisness of selling parts .
imprezzakc is offline   Reply With Quote
Old 08-31-2003, 06:32 PM   #6
Steppin Razor
Member#: 24035
2002 GGA 5MT
Seal Gray
how many times do i have to say it before people understand that BRAKE ROTORS DO NOT WARP!!!
the reason that drillled rotors are more prone to breaking is that unless the holes are chamfered and stress relieved is that the sharp edge left by the drilling creates "hot spots" where the rotor will become hotter than the rest of the rotor and this increased heat cycling weakens the iron alloy.
even IF you were using properly made drilled rotors, by machining them, you would be recreating the sharp edges on each hole and thus greatly increasing the chances of your rotor cracking. unless you went back and rechamfered each hole and then stress relieved the rotors again. but then you'd be wasting your money because drilled rotors are for tools anyway.
Steppin Razor is offline   Reply With Quote
Question on slotted and drilled rotors Derx Brakes, Steering & Suspension 5 02-08-2010 05:35 PM
EBC red pad and EBC slotted and drilled rotors vibrating bozz Brakes, Steering & Suspension 12 04-07-2008 08:47 PM
FS: DBA 650 slotted and drilled WRX brake rotors bemani Private 'For Sale' Classifieds 8 10-31-2003 01:04 PM
4Sale DBA slotted and cross drilled rotors DBA-644X ( Rear ) Saposat Private 'For Sale' Classifieds 5 10-17-2003 06:52 AM
