Welcome to the North American Subaru Impreza Owners Club Sunday February 14, 2016
Old 08-29-2003, 03:01 AM   #1
atmosphere
Member#: 37641
98 Impreza 2.5 RS
Default Forrester XT motor
Has anyone used this motor in a swap yet? Im looking to do a swap in the future for my GC8 and was wonder if this motor is a good option aside from the standard WRX 2.0 and if there are any problems associated with it. Thanks.
atmosphere is offline   Reply With Quote
Old 08-29-2003, 12:38 PM   #2
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
it is very simmilar to the sti motor
it will eventually be a very popular swap but i don't know of any one who has doen it yet..
if you do it get the whole car as the ej255 has some new/odd differnces like throttel by wire
Old 08-29-2003, 02:45 PM   #3
cavymeister
Member#: 24463
2003 Chevy S10
91 Hunduh Civic BASE
AFAIK the only difference between the STi and XT long block is the cams. The STi has a longer durration and a little higher lift IIRC.
The STi also has a bigger i/c, bigger turbo and more boost.
cavymeister is offline   Reply With Quote
Old 08-29-2003, 05:15 PM   #4
atmosphere
Member#: 37641
98 Impreza 2.5 RS
EJ255? Whats the extra 5 indicate or is it a typo? Also is it possible to retro fit a standard throttel, Ive heard that throttel by wire takes away "felling" in the gas pedal. Thanks.
Old 08-29-2003, 05:25 PM   #5
totoherbs
Member#: 7321
.... 122 IggPoints
Work... ahhh... so tired.
the ej255 = xt motor ej257 = sti motor
cams are the only difference... and yes you can change it from fly by wire BUT that would be crazy amount of work. You would have to rewire eveything with like a v7 harness and I dont know what the hell you would do for an ecu... would the v7 ecu work with the 2.5 block?
Old 08-29-2003, 11:55 PM   #6
rbehny
Member#: 1908
the cams aren't the only difference... remember the sodium filled valves aren't part of the XT package. So the short block is identical and the heads have a few differences. That sums it up.
If your just looking to keep a 2.5 liter displacement why not get the STi short block bolt it up to RS heads and run that? Yeah a bit more technical but a whole lot easier than trying to find something (other than oem ecu) to run the throttle by wire and the avcs.
Either way good luck. I was originally gonna go with the XT engine then saw the difficulties of TBW and AVCS with any ecu other than the xt's. But if you feel like wiring in the XT ecu more power to ya.
Robert
I also second the thought that you should get a whole car to transplant from cuz odd little do-dads..
Also would you need a new front crossmember? I've been rattling my brain on that one for days.. HELP
rbehny is offline   Reply With Quote
Old 09-02-2003, 11:00 AM   #7
gvmelbrty
Member#: 11145
1997 Legacy wgn 5sp
2013 Crosstrek XV
According to this "Forester XT technical description supplement" PDF posted on the Subaru Australia web site, the XT heads do have the sodium exhaust valves:
XT Cylinder Head Features
  • Four valves per cylinder in cross flow format with straight tumble airflow being achieved by manifold and intake port design.
  • Tumble Generator Valves (TGV) for good combustion efficiency and low emissions during cold start. After starting, the TGV immediately opens to maintain good airflow and performance.
  • Twin camshaft per cylinder head, with direct valve actuation and Active Valve Control System (AVCS) variable valve timing.
  • Camshaft weight has been reduced 1700g by using a hollow shaft and an assembly of sintered cam lobes.
  • Sodium filled exhaust valve stems for low inertia and improved heat dissipation.
  • Single timing belt with self-adjusting tensioner. (100,000 km replacement interval)
Lots of other interesting XT info in that doc as well.
-tom
gvmelbrty is offline   Reply With Quote
Old 09-02-2003, 02:29 PM   #8
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
The Forester XT block is said to be open-deck whereas the STi block is semi-closed. If that is the case, then the blocks aren't the same. I've just been too lazy to have my buddy at Subaru look up the part numbers.
-Jon
Old 09-02-2003, 05:21 PM   #9
NYCshopper
Member#: 5126
-Jon
if you look at the pdf posted by gvmelbrty
it says...on page 8
The Cylinder Block on the Forrester XT turbo engine features a semi closed deck design due to the higher thermal loads and pressures associated w/ a turbo engine.
NYCshopper is offline   Reply With Quote
Old 09-03-2003, 12:40 AM   #10
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Huh. Guess I need to find the part numbers.
-Jon
Old 09-03-2003, 12:36 PM   #11
Storm
Member#: 5218
96L Most Over-
Developed Beater
As I talked with a salesman (who had built up his own RST) he noted differences such as cast vs forged pistons along with a different turbo and intercooler. I can't remember if the rods were the same or different as well. The actual block&crank is supposed to be the same though....
I don't think the manifold can be retrofitted with a regular TB, but I haven't tried.....
Jay Storm
www.sourcemotorsports.com
Old 09-03-2003, 01:08 PM   #12
Scoob
Member#: 6204
2002 WRX Sedan
WR Blue
As far as I'm aware, the shortblocks are the same exact part number between XT and STi. I'm thinking about modding my WRX with the shortblock.
Scoob.
Scoob is offline   Reply With Quote
Old 09-06-2003, 02:42 AM   #13
MattDell
Member#: 16803
I've thought about this swap as well. It would be a lot easier on the transmission than the EJ257, and it would still keep the torque of the RS unlike the EJ20.
I think it'll be more common once the XT has been in production a bit longer.
-Matt
MattDell is offline   Reply With Quote
Old 09-06-2003, 04:04 PM   #14
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
I think guys will be using the shortblock, I don't know about the whole motor though. There are alot of WRX guys (myself included) who are going to be using the STi block since it's relatively cheap ($1200) compared to alternatives.
You could just bolt an old intake manifold with a wired throttle to the heads. If you wanted to use the AVCS you could use an ECU/engine harness from a STI/WRX with AVCS heads and do a little splicing.
Old 09-10-2003, 01:36 AM   #15
LVSUBARU
Member#: 4520
93 STi V.4 RA
www.flat4lv.com
$1200!!!
Is that a complete short block!?
Do either of the EJ255, or EJ257 have oil squirters for the pistions?
LVSUBARU is offline   Reply With Quote
Old 09-10-2003, 01:42 AM   #16
LVSUBARU
Member#: 4520
93 STi V.4 RA
www.flat4lv.com
To get the AVCS to work you could probally just use a RPM activated switch like the Honda guys do for VTECH swaps!
Old 09-10-2003, 01:55 AM   #17
totoherbs
Member#: 7321
.... 122 IggPoints
No oil squirters, And getting the avcs to work is a lot harder then slaping on a vtec controler. It operates differently then vtec, and has been coverd many times.
I dont know about useing a sti block in my wrx. It has been said to have "high CR" and for the same price I could have an ej22 wich is a stronger block. But time will tell, Its been said that the ej257 isnt as strong as its jdm ej207 brother.
Old 09-10-2003, 02:44 AM   #18
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
I've seen the EJ257 and the EJ207 blocks together and there isn't much difference. The nature of the 2.5 motor isn't real good for running high RPM or real high boost applications. It has an enormous amount of low end and mid range power though, as we've already seen from some tuners doing minimal tuning. All depends on what you are after.
Yes it's $1200-1400 for a complete short block. Good luck finding an EJ207 block for that price. It's generally almost twice as much. As for the EJ22T you can get the block for about the same price but most people I know who have them replace the pistons and rods and increase the CR anyways.
Old 09-10-2003, 01:45 PM   #19
kgb
Member#: 1366
2000 RS-T -> RSTi-8
Blue Ridge Pearl
Lightbulb
If you retain your heads from your EJ251 and use the EJ22T shortblock, you get a really low CR (7.7:1 with SOHC heads) but with the EJ255/EJ257 you get a more favourable CR of around 8.48:1
kgb is offline   Reply With Quote
Old 09-10-2003, 10:32 PM   #20
LVSUBARU
Member#: 4520
93 STi V.4 RA
www.flat4lv.com
So a EJ255/EJ257 block and EJ25 heads will give you a CR about:8.5?! That would be perfect for a very steertable very fast turboed motor!!!
I want one!!!
Old 09-11-2003, 02:28 PM   #21
Coati
Member#: 9106
2015 FXT - DGM
2008 STI - Aspen White
Would a Forester XT ECU be simpler to set up in a WRX wagon than a WRX sedan? It seems like the layout (4dr + hatch w. wiper) would mean the controls would be nearly identical.
An XT longblock + shorter ratio XT tranny could be fun in a wagon body...
Coati is offline   Reply With Quote
Old 09-11-2003, 02:31 PM   #22
AKGC8
Member#: 1305
2000 Impreza
The ECU doesn't handle anything like the wiper or what not. It would be the same.
AKGC8 is offline   Reply With Quote
Old 09-11-2003, 03:13 PM   #23
totoherbs
Member#: 7321
.... 122 IggPoints
[Here are two dyno plots/comparison people have been waiting for:
RED Graph is with a 2.0 WRX with these mods:
Stock IC
Stock Injectors
Helix up pipe
Samco IC hoses
NGK Platinum 7s
I-Speed USA tuned ECUtek
Running 16psi
Blue Graph is a 2002 WRX with a 2004 STi 2.5 short block
Stock IC
Stock Injectors
Helix up pipe
Samco IC hoses
NGK Platinum 7s
I-Speed USA tuned ECUtek (which was the same map for the RED graph, plus a tad more fuel)
3 turbo back exhaust
VF30
Running 16psi
Next we will be Dynoing Crawford Performance wrx rebuilt heads. These will mate perfectly with our STi setup.
Let the mods begin
Chris
I-Speed USA
cescamilla@i-speedusa.com
[/quote]QUOTE]Originally posted by I-Speed USA
http://forums.nasioc.com/forums/show...&pagenumber=10
After seeing this it may just be worth it to get the short block and an ecutek reflash..... and a lot cheeper then a full swap with the new fly by wire system. And apparatly the US sti has the same deration cams as the us wrx just higher lift and avcs on the intake cam.
Old 09-11-2003, 03:18 PM   #24
Coati
Member#: 9106
2015 FXT - DGM
Nice. What kind of exhaust did the 2.0L have?
Old 09-11-2003, 10:04 PM   #25
Crawford/I-Speed
Vendor
Member#: 12347
ECU ReProgramming
Dynapack AWD Dyno
The 2.0 had the stock WRX exhaust. Knowing that the tdo4 would be too tiny and that the stock exhaust would hamper the 2.5 STI block , we changed them out for the dyno run.
Also, we felt that the mods we dynoed ,with the STi block, were common wrx mods that most people would already have.
Chris
I-Speed USA
Crawford/I-Speed is offline   Reply With Quote
Forrester XT, Outback XT Wgn or Legacy GT Wagon wrxgolfr General Community 17 03-25-2006 01:43 PM
Forrester XT = not slow metoo Texas Impreza Club Forum -- TXIC 1 08-23-2003 02:12 PM
Forrester Xt Nu2Subies Forester Forum 6 08-06-2003 12:29 PM
forrester xt 8.6sec 0-60? vile Forester Forum 20 07-25-2003 05:56 PM
Forrester XT or WRX wagon ? Help phatbob General Community 2 06-13-2003 08:23 AM
