Old 08-29-2003, 10:56 AM   #1
gtguy
Member#: 2184
2005 Legacy GT wagon
Platinum Silver Metallic
Default F1 tire tizzy...Bridgestone vs. Michelin vs. the FIA
You knew this was coming....
<<Tyre controversy set to rock Formula 1
Rule change could hurt Williams and McLaren's title chances
The FIA is planning to change the way it measures tyre width
The world championship hopes of Williams and McLaren appear to have suffered a massive blow with tyre supplier Michelin set to be forced to scrap its currently dominant tyres in time for the next round of the title fight in Italy.
It is understood that motor racing's governing body, the FIA, has written a letter to all the teams this week claiming that it will change the way it measures tyres from the next grand prix at Monza on September 14.
In the letter, the FIA explains that the previous tread width limit of 270mm for the front tyres will now be measured after the race rather than before it, as had been the previous practice.
It is believed that this new ruling will hurt Michelin more than Bridgestone because its tyres have previously used the 270mm limit to the maximum.
Confirming the FIA's decision, Williams' chief operations engineer Sam Michael told AUTOSPORT: "The FIA have changed the way they measure the front tyre contact patch. They will now be measuring the contact patch new as well as worn. We are reviewing the consequences of that."
The new ruling is believed to have come after complaints from Michelin's rivals who claim that when the French tyre manufacturers' rubber wears down during a race the tread width of the tyre exceeds the 270mm limit. There may also be instances that the tread width exceeds the limit when the tyre is running at speed, although this is difficult to prove.
Although Michelin is expected to fight the decision, because it claims the tyre design has been fully legal since it was first used at the 2001 San Marino Grand Prix, it could be forced to build completely new designs for Monza.
There may not be enough time for Michelin to prepare these tyres in time for the pre-Monza test next week which means Williams and McLaren could race with tyres at the Italian event which have not been tested before.
A spokesman for the FIA said: "A letter was sent to Formula 1 teams regarding tread width, but we cannot say any more at the moment.">>
gtguy is offline   Reply With Quote
Old 08-29-2003, 11:13 AM   #2
elgorey
Member#: 4374
06 Titan,99,94 SM
06 nasa spec miata champ
they really need to get these little nitpicks taken care of in the offseason.....
especially when it affects engineering and manufacturing.
mid-season changes just arent good for the sport.
elgorey is offline   Reply With Quote
Old 08-29-2003, 11:39 AM   #3
AndyRoo
Member#: 20952
MINI & Datsun
BRG & White
hmmm dont like that much.
How badly do they want schumi to win?
AndyRoo is offline   Reply With Quote
Old 08-29-2003, 12:19 PM   #4
LordBass
Member#: 3266
2006 Jetta 2.0T 6MT
2009 Jamis Aurora Elite
Especially when we're set up for one of the hottest title fights in recent memory.
lb
www.trancelab.com
LordBass is offline   Reply With Quote
Old 08-29-2003, 12:33 PM   #5
gtguy
Member#: 2184
Here's the quandary:
Michelin, if they have been taking advantage of the rule as specified, with a tire that is in spec some of the time and out of spec some of the time, how do you deal with that?
Perhaps this is why the Michelin runners have been so loath to change tires at many races and further, why the Michelins have such a square shoulder compared to the Bridgestone. Ferrari is running big camber in an effort to get more rubber on the road, while Michelin, with its wider, squarer shoulder can get away with a flatter stance, which means more rubber on the road, and more even tire wear. Bridgestone should stand by their design decision. I think that their quibble (and we KNOW that they instigated this) is that they are being penalized for following the rule to the letter (post-race compliance as well as pre-race), while Michelin is fudging, it would appear.
I don't know if it is as much trying to help Ferrari as it is trying to make sure that nobody has an unfair advantage during these last three critical races. The Michelin, as measured pre-race, has almost a 3 cm width advantage over the Bridgestone. This also means that the B-stone, measured post-race, would still be in compliance with the width specification. The Michelin would not.
I'm not sure how I feel about this rule. The timing is certainly interesting. Perhaps, like NASCAR with its malleability of rules enforcement, the FIA is coming to re-level the playing field, so to speak.
Kevin
Old 08-29-2003, 12:44 PM   #6
Dr. WOT
Member#: 3623
EXACTLY!! The decision seems sensible, long overdue in fact. But to do this now is to tamper with the course of the season.
Dr. WOT is offline   Reply With Quote
Old 08-29-2003, 01:25 PM   #7
bohica
Member#: 8590
oh 5 sti & a
So this "new rule" doesn't fall under the concord agrement?
Or are there rules that can be changed like this, without all of the teams approval?
bohica is offline   Reply With Quote
Old 08-29-2003, 02:18 PM   #8
gtguy
Member#: 2184
As I understand it, regulations that pertain to hard and fast measurements, part of the "formula," as it were, are simple matters of interpretation. Michelin could well argue that hey, you weren't measuring them after the race until now, so why start now?
But I think it's the same thing as when a car's overweight. It either is or it isn't. The tire should be x. If it isn't, that's wrong. The problem is that the FIA has suddenly said "Hey, we're going to use this other measurement that we should have been using all along."
Kevin
Old 08-30-2003, 01:53 AM   #9
bohica
Member#: 8590
oh 5 sti & a
Oh, I agree. I dont have a problem with rules. Just dont change them mid stream. Michelin has run this tire since Imola 2001.
Now it's suspect?
Old 08-30-2003, 03:37 AM   #10
shoracer
Member#: 25247
1999 Coupe L
and, to think bridgestone was going to come out with a tire like Michelin.
shoracer is offline   Reply With Quote
Old 08-30-2003, 10:13 AM   #11
gtguy
Member#: 2184
Apparently, the rule regarding width applies to the tires when new. And when new, Michelin's tire conforms to the specification. Further, who the heck knows why Bridgestone makes their tire to conform, post-race, as well as pre-race.
Pierre Dupasquier of Michelin says that it is quite impossible for Michelin to make tires that conform to this new ruling (I'd like to wave the BS flag at Michelin at this point, but he has to say that...they have the capability to make tires within a week of the event...), and that the tires for Monza are already made, so leave us alone.
Seems like the FIA is going to lose this one and frankly, should. Bridgestone needs to get its act together, rather than carping about Michelin, IMHO.
Kevin
Old 08-30-2003, 03:17 PM   #12
RRR-K2
Member#: 22365
98 Outback Wagon
2000 Impreza Sedan
--edited for grammer, er, I mean grammar
Personally, I applaud Michelin for having taken advantage of the FIA's poorly written rule. If the FIA wanted to allowed a maxiumum tire width of X before AND after a race then THAT'S THE WAY THEY SHOULD HAVE WRITTEN THE RULE! The FIA shouldn'd penalize Michelin for their mistake.
It's like the winner of a NASCAR race being penalized because his roof is out of spec when they measure it after the race because HE JUMPED ON IT WHEN CELEBRATING!?!
In such a competitive (and often cut-throat) series as F1 teams will try everything to gain the slightest advantage, and to me, that's what F1 has always been about, innovation and creative thinking/engineering.
Why do you think Rodger Penske has almost always been a dominant force in whatever series his teams compete in? Heck, back during the hay-days of the original Trans-Am series there was a rule that stated that "the battery must be visible from the engine compartment." Rodger, knowing that the battery was a a major source of weight that can have a huge affect on the balance of the car (front to rear) mounted the battery in the foot well area of the passanger's side of the car and installed a flap in the fire wall so that you could lift the flap and still "see the battery from the engine compartment!"
__________________
Matt "RRR-K2" Kennedy
www.RockyRoadRacing.com
1996 Subaru Impreza - ProRally Open
1991 Subaru Legacy - RallyCross Production 4WD
RRR-K2 is offline   Reply With Quote
FS: Tires tire Bridgestone, pirelli, michelin, goodyear jrodela06 SCIC Private Classifieds 150 11-09-2009 09:58 PM
The FIA Needs Your Help to Fix F1... Ferg Motorsports 9 07-07-2005 10:12 AM
Do you think that the FIA is ruining F1? Kwyjibo Motorsports 32 07-06-2005 10:51 PM
Bridgestone RE070 vs. Michelin PS2 triguy Tire & Wheel 9 04-28-2005 02:54 AM
Tire sidewalls Bridgestone S-03 vs RE070 rich728 Tire & Wheel 21 08-20-2004 02:14 AM
