Welcome to the North American Subaru Impreza Owners Club Sunday April 20, 2014
Old 08-30-2003, 12:15 PM   #1
Benjamin Tang
Member#: 4496
2009 Forester
red
Default questions about emissions and mileage when doing turbo upgrade
when u start bumping up into fuel pumps, ihi vf30's, sti injectors... what happens with emissions? i have mandatory testing where i live which involves an idle test and a driving test on a dyno. was wondering if i could still pass on a stock ecu without having to pull everything out?
also wondering if my mileage will get worse under normal driving conditions? with gas prices going sky high well....
Benjamin Tang is offline   Reply With Quote
Old 08-30-2003, 01:27 PM   #2
zaxrex
Member#: 9898
Water Injected Blue
You will be super rich if you are running STi injectors at more than idle. If you are tested on a AWD dyno under load, you will probably not pass with those injectors on stock maps.
If you use stock injectors and exhaust bits, there will be no problems at all. The turbo alone will not make you fail inspection, the 550 injectors without proper management most likely will, without some engine management or fuel control.
zaxrex is offline   Reply With Quote
Old 08-30-2003, 02:32 PM   #3
Benjamin Tang
Member#: 4496
2009 Forester
red
as odd as it may seem, the only thing they look for in the visual inspection is the last catalytic converter under the car. they don't care about the first two, as long as there is one visible, which is why i couldn't buy an MRT downpipe because the cat is too high up to be seen from under the car... they also don't care about the turbo... i could be running something out of a kenworth and they wouldn't be any wiser
i've been sitting on the fence for some time now not knowing what to do... the plan was to do this:
ihi vf30/34 (still looking)
fujitsubo exhaust manifold/uppipe (sitting in a box )
turboxs stealthback w/cat (in transit)
prodrive WR axleback (on car)
sti 550cc injectors (also in a box)
turboxs UTEC stage3 (in my dreams! )
walboro fuel pump (or sti?) (if i can find one)
i mentioned stock ecu because i was under the misconception it would fail for sure with UTEC mapping
if this fails, i'm just going to sell the injectors and get a monster TD04 done by deadbolt and be happy?
Old 08-30-2003, 11:35 PM   #4
big_adventure
Member#: 40501
2005 Decathalon 21sp
One WheelSeanPower
Well, I think that if you run a bigger turbo, even just a Deadbolt version of the TD04, you're probably going to lean out with the stock injectors and pump. Just a theory, mind you, since I've never tried it.
Question - does your area actually have an AWD dyno to test emissions on? Most of the dyno-test emissions areas I'm familiar with don't have AWD dynos, so you get to just do the idle test and be happy.
Good luck!
big_adventure is offline   Reply With Quote
Old 08-30-2003, 11:50 PM   #5
Benjamin Tang
Member#: 4496
2009 Forester
red
we used to do just idle, but just recently they retrofitted all the testing stations with an awd dyno just for awd and cars with traction control
Old 08-31-2003, 12:01 AM   #6
big_adventure
Member#: 40501
One WheelSeanPower
That's just nasty. I guess it's time to move to Sasketchawan?
-Sean
Old 08-31-2003, 12:23 AM   #7
CobraKLR
Member#: 12986
How about a ECU reflash? Cheaper than a UTEC although not as cool. You definately need to lower the injector voltages with larger injectors or you will run super rich and not pass. Plus you will lose power with such a low AFR.
CobraKLR is offline   Reply With Quote
noob question about tires and mileage. poetic--playa Newbies & FAQs 6 05-30-2008 01:39 AM
Question about emissions and CEL sovietjet Mid West Subaru Owners Club Forum -- MWSOC 23 01-28-2008 04:37 PM
about to do turbo upgrade lilsix Mid Atlantic Impreza Club -- MAIC 18 02-01-2006 03:30 PM
questions about ej20 and bolt on turbo upgrades 280hp_REX Factory 2.0L Turbo Powertrain 0 08-12-2005 04:34 PM
question about octane and mileage m4r10 Newbies & FAQs 17 04-22-2005 06:51 PM
