Old 08-30-2003, 07:04 PM   #1
Sunrise City Rider
Member#: 1503
2000 Impreza W"RS"X
Blue Ridge Pearl
Default Blinking Check Engine Light on MY00 RS with MY02 WRX Swap
Ok, I have a serious annoying problem with my 2002 WRX swap in my 2000 RS Coupe...
I get the annoying flashing Check Engine Light and the fans turn off and on when the key is in the ON position...Not when the car is running...
This is supposed to happen when you are diagnosing the car thru its Diagnosis Port in the inside, under the steering wheel...
But, I don't want to diagnose anything and I can't see where the wires may be shorted...
Anyone know where I should look and what I should look for?
Thanks for any advice or direct help,
Zee
Sunrise City Rider is offline   Reply With Quote
Old 08-30-2003, 09:01 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
It sounds like at some point when you were working on the car, you connected together the green plugs that are underneath the dash. Those plugs are normally left disconnected and when plugged together will activate a diagnostic mode that does exactly what you are experiencing- flashing CEL and constantly cycling fans. Go under there and check, you will probably find the green plugs connected, unplug them and all will be fine.
Old 09-01-2003, 12:54 AM   #3
AWJunkies
Member#: 32934
99 2.5RS JDM WRX
Yep sounds like the green plugs check them out then get back to us!
AWJunkies is offline   Reply With Quote
Check engine light on and cruise control blinking 06EzSTI Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 05-13-2008 10:10 PM
HELP! Check Engine light on & Cruise Control Light Blinking STiURBO Southern California Impreza Club Forum -- SCIC 21 03-15-2007 01:54 AM
Check engine light on and cruise blinking? STIdrivr Electrical & Lighting 1 02-24-2007 08:38 PM
Blinking Check Engine Light MorrisCountyWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 11-22-2001 11:58 AM
HELP: MY00 Check Engine Light... ON.. :(... 2.5RSt'd General Forum Archive 1 11-21-2000 05:05 AM
