Old 08-30-2003, 09:48 PM   #1
MyRuRex
Member#: 21349
02 WRX Wagon
Default Greddy Profec-B Spec II Help
Just installed this baby. Looks awesome....mounted right above the steering wheel column. I took out the "P" switch.
BUT...how the heck do you set up this thing???
Lo/Hi boost is not working right....I'm getting higher boost in the Lo setting eventhough the Hi setting is set higher. The directions that came w/this are worth ****ake
I have a Unichip Stg 1......was set at 1.1 bar (~16psi) w/the MBC
The problem w/this is that the settings is based on percentage....it's not making sense. I set it @ 100% and that goes way up to about 1.5 bar at part throttle in 1st gear!!! When I turn it down......I can't even get up to stock boost (~14.5psi)!!
What's up
Another problem is.....My BOV isn't blowin off!! My guess is I have to many T's in that area.....It's like a LA freeway in the BOV area. I also have a mechanical boost gauge in that area.....
I know I'm just yappin away but HELP !!!!!!
MyRuRex is offline   Reply With Quote
Old 08-31-2003, 10:51 AM   #2
MyRuRex
Member#: 21349
02 WRX Wagon
Old 08-31-2003, 11:02 AM   #3
DuoMaxwell
Member#: 24565
2000 V6 STi RA #856
Errr I cannot find my directions for the thing but I believe you have to adjust your balance before you select low boost setting and high boost setting. Also make sure you have it connected correctly!!
DuoMaxwell is offline   Reply With Quote
Old 09-01-2003, 09:27 PM   #4
Quantum-Racing.com
Vendor
Member#: 20483
Call me during the day on tuesday (probably when you read this). I'll try to walk you through the settings from memory (they're not too bad).
Mark
www.Quantum-Racing.com
Quantum-Racing.com is offline   Reply With Quote
Old 09-01-2003, 11:00 PM   #5
wrxdaddy
Member#: 14164
02 Impreza Wgn
95 L Project in progress
Mark
I just installed mine this weekend. The Profec-B Spec II is the digital EBC version. I was wondering what is a good base setting for our WRX motor boosting 14.5psi or 1.0 bar
According to the manual,
SET = ? % (This mode is used to set the desired boost pressure).
GAIN = ? % (This mode is used to adjust the boost consistency).
SET GAIN (START BOOST) = ? psi or bar (This mode is used to adjust the boost pressure).
I sure appreciate it if someone can help save us some time with the trial and error part
Thanks.
wrxdaddy is offline   Reply With Quote
Help tuning Greddy Profec B Spec II sunnyniazi South West Impreza Club Forum -- SWIC 7 02-02-2007 08:19 PM
OH:2003 WRX Greddy Evo II Exhaust (used), Greddy Profec B Spec II (used) subaman81 Private 'For Sale' Classifieds 17 02-22-2006 11:18 PM
Greddy Profec B Spec II Boost Controller Help mcgehman Electrical & Lighting 1 09-14-2004 09:50 PM
Help w/ Greddy Profec B Spec II Settings unwrittenlaw Newbies & FAQs 2 06-01-2004 06:43 PM
GReddy Profec B Spec II, experience? Henry Engine Management & Tuning 25 10-14-2003 10:32 PM
