Old 12-05-2000, 07:25 AM   #1
lordgreatsharo
Guest
Member#:
Question yet ANOTHER (not so) stupid WRX question.... for all you WRXjunkies out there
Ok, this is my first time on this board... so give me some slack. I know this has probably been asked a gamillion times or so, but i'd like to know anyway.
Does the US-spec WRX have the same engine as the japanese WRX? If so... will we be able to simply "plug" the japanese bad-boy computer into the US car and magically get 280hp? Im sure it doesnt work that way... but hey, I can dream cant I?
peace,
shawn
'98 Neon
HRC stageII turbo - 6lbs of boost
13.8 @ 98 (w/ 2.5degrees -camber i might add)
Old 12-05-2000, 08:16 AM   #2
ScoobyDriver
Member#: 195
2001 BH9
Post
Welcome round headlight lover
It is all speculation at to which engine we will get. The UK/Aussie's got the standard non-variable timing 2.0 with 218hp.
The current rumor is North America will get a ~230hp model, whether that means ours has the VT or not is unknown. My bet is the same 218hp everyone else got.
I'd say the possiblity of a chip to add HP is there, but by looking at the UK/Aus path to HP, other steps should be taken first. Figure a good $1500 in engine stuff will get you approaching the 270hp mark.
Hope this helps a little,
Shane Kullman
'98 RS Red
ScoobyDriver is offline
Old 12-05-2000, 09:06 AM   #3
Patrick L
Member#: 634
2000 Impreza 2.5RS
Becasue ITS racecar
Post
Hey Peaty, where are you?
Peaty has a friend who writes articles for Mags and drove the new Impreza down in Florida. He got to read the book that had all the specs on it. He said it was going to be 227hp at about 217ft/lbs.
Peaty, you there. What else did he till you.
Pat
MY00 impreza 2.5RS
P.S. Shawn, I sent you a private message.
[This message has been edited by KC_TopDog (edited December 05, 2000).]
Patrick L is offline
Old 12-05-2000, 09:22 AM   #4
Keith
Member#: 191
2012 J train
Brown
Post
at what rpms are are we putting out these numbers??? No one has said that
Keith
Keith is offline
Old 12-05-2000, 09:50 AM   #5
T-WRX
Member#: 2468
08 RS4
05 STi - Gone
Post
The Japanese engine gets variable valve timing. We don't. Something about emissions.
BPM says that the new WRX cannot be chipped. I don't know why.
T-WRX is offline
Old 12-05-2000, 09:51 AM   #6
T-WRX
Member#: 2468
08 RS4
05 STi - Gone
Talking
By the way, welcome to the board!
T-WRX is offline
Old 12-05-2000, 09:56 AM   #7
SubyRacer
Member#: 2439
2000 2.5RS
aspen white
Post
l
l
actually i heard a rumor that the they managed to pass the AVCS through emissions and that is why we're getting more hp than the euro spec cars. i have noe clue if its true or not. can anyone tell if it has AVCS by looking at the pictures of the U.S. spec engines compartment.
[This message has been edited by SubyRacer (edited December 05, 2000).]
SubyRacer is offline
Old 12-05-2000, 10:08 AM   #8
AKGC8
Member#: 1305
2000 Impreza
Post
I doubt it, the AVCS is an internal camshaft type of system. I doubt you could tell the difference from the outside. Especially with the H4 engine that puts the heads on the side of the engine compartment.
AKGC8 is offline
Old 12-05-2000, 01:12 PM   #9
matt7184
Member#: 1797
2003 MazdaSpeed
Protege
Post
Maybe the AVCS is be used for emmisions in the US, like VTEC (dont start a VTEC war please VTEC Lovers)
matt7184 is offline
Old 12-05-2000, 05:58 PM   #10
Akiata
Member#: 297
Smile
You can't "chip" the new computer. Go here----> http://www.geocities.com/clintsc9/Im...mpreza2001.htm
and read about the new car.
Akiata is offline
Old 12-05-2000, 06:43 PM   #11
matt7184
Member#: 1797
2003 MazdaSpeed
Protege
Post
Some interesting things I noticed in the brochure. Is this the same type of turbo as the EVO? (prob. not but just checking)
Is the new intake system really worth it for the turbo, wouldnt a short pipe be better?
I dont see anything that says anything about changing the ECU. Prodrive is coming out with an ECU for the PPP so why couldnt other tuners do the same?
matt7184 is offline
Old 12-05-2000, 10:15 PM   #12
Patrick L
Member#: 634
2000 Impreza 2.5RS
Becasue ITS racecar
Post
You can tell if it has the VVT, there is a big bulge in the cam belt covers where the top cam shaff sproke is. If it did not. It would the same as the bottom half of the cover like the older version of the 2.0L
Here is what it would look like if it had it.
Old 12-05-2000, 10:28 PM   #13
ChAi
Member#: 1277
1999 Minnam Stage 2
Cobb Stage3 engine, TEC3
Post
a very cool info thanks
ChAi is offline
Old 12-05-2000, 11:47 PM   #14
ChosenWon
Member#: 2236
2000 Audi S4
silver/rally dirt brown
Post
To back up kc top dog, my salesman also said that at a training meeting, he was told it would have 227hp. he is pretty knowledgable. I'm pretty sure i can trust him. *shrug*
but then again he is a salesman.....
ChosenWon is offline
Old 12-05-2000, 11:48 PM   #15
ChosenWon
Member#: 2236
2000 Audi S4
Post
oh, and uh... welcome!
are you thinking of getting it?
Old 12-06-2000, 12:06 AM   #16
Redline8k
Member#: 2968
Beat it to fit,
Paint it to match!
Post
Can anyone read the Max boost rating on the spec sheet? I cant make it out and would like to know....
welcome to the board, I knew a guy from HRC with a 11sec Neon... damn fast
Redline8k is offline
Old 12-06-2000, 07:27 AM   #17
250k plus
Member#: 3144
WR Blue
Post
According to those specs, the max turbine speed is 190,000 RPM, and the max sustained boost pressure is 13.5 PSI @ 4800 RPM.
250k plus is offline
Old 12-06-2000, 07:27 AM   #18
lordgreatsharo
Guest
Member#:
Cool
Thanks for the info guys. I just talked to Trey Cobb of Cobb tuning (his shop is about 5minutes from me). He told me that we should be able to mod the computer to get ~250hp like the Jap spec without a problem. Im sure the WRX will take kindly to mods like 3" exhaust, upgraded intake, downpipes, intercoolers, UDP's and all those goodies (ppl have got neons into the 13's with just bolt ons!)
Hey, Redline8k, that HRC neon (owned by Len Ayala) you saw do 11's is now doing 10's (600bhp)... and is still street driven! Check it out: http://www.turbosystem.com/Hahn_Auto..._quickest.html
Chosenone: Yeah, im going to put my order for a white WRX wagon in this week! cant wait to get it!
peace,
shawn
Old 12-06-2000, 01:23 PM   #19
matt7184
Member#: 1797
2003 MazdaSpeed
Protege
Post
Did Trey say if just the chip got it or is expecting to get it to 250 or is that with additional mods?
matt7184 is offline
Old 12-06-2000, 02:25 PM   #20
kelley nelson
Member#: 135
Post
Imho you have to be careful with chips. Of course you can just wind up the boost, but often you need to do other things to the car to help make that safe. I am sure whatever Trey comes up with will be sound.
kelley nelson is offline
Old 12-06-2000, 04:52 PM   #21
dmross
Member#: 2818
2000 2.5RS
Post
http://www.geocities.com/clintsc9/ImpSpecs/ImpP07.jpg
^-- from previous brochure post
At the bottom of the page it says, "In fact, it is no longer possible for the workshop to 'tune' a new generation Subaru"
What the hell does that mean!? I don't see how this could be possible... maybe it is because of how tightly integrated everything is (electronically)
-Daniel
dmross is offline
Old 12-06-2000, 05:05 PM   #22
T-WRX
Member#: 2468
08 RS4
05 STi - Gone
Post
Yeah, I read that too. I think they are trying to say that the Impreza is already optimized.
BPM said that the difficulty in tuning the new impreza will "separate the men from the boys" in the aftermarket.
T-WRX is offline
HTML code is On
question for all you snowboarders out there... lennyTR Off-Topic 13 02-22-2009 02:56 PM
Kidney Stone question for all you doctors out there... MartinD Off-Topic 9 06-17-2005 12:47 AM
a question for all you autocrossers out there ChrisW Motorsports 13 10-25-2002 12:53 PM
Question for all you parents out there Mike Smith General Forum Archive 13 02-22-2001 07:37 AM
Question for all you parents out there... AudiGuy General Forum Archive 11 10-17-2000 12:54 AM
