Old 12-05-2000, 07:13 AM   #1
PRODRIVEN
Member#: 111
1999 Impreza 2.5 RS
EJtwentyfied -> '04 STi
Angry My Cusco Shifter Bushing Fell Out
My car shifts like a garbage truck. Sometime last night on the highway half of the cusco shifter bushing fell out and the car was a pain to shift. The throws were extremely long and clunky. I thought the shifter fell out becaus eit was moving all over the palce. I had to take it to the dealer this morning and we found half the bushing gone and the other half just hanging in there. The bolt came loose over the last year and the driver's side half fell off. They temporarly fixed it by cutting another bushing in half and squeezing it in there. So now I need to find a new bushing somewhere. I would check the bolt on your bushing every once in a while. The rubber is so hard the vibrations must have worked the bolt loose over time.
PRODRIVEN is offline
Old 12-05-2000, 07:44 AM   #2
Keith
Member#: 191
2012 J train
Brown
Post
wow that sux...good luck getting new bushings...thanks for the heads up
keith
Keith is offline
Old 12-05-2000, 08:12 AM   #3
Fred Zaplitny
Gone... But not forgotten
Member#: 92
1999 2.5RS Coupe
Blueish Kind of
Post
Time for some Lock-Tite! Looks like I have something to do tonight. Thanks for the warning.
Fred Zaplitny is offline
Old 12-05-2000, 09:10 AM   #4
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
Post
Same thing happened to me! After four months, the nut fell off, then the metal plate, then one half of the bushing! I got the stock parts put back in under warranty, but when new bushings go in, so does a nylon lock nut!
Brian
http://members.nbci.com/_XMCM/northu...reza/index.htm
You and the Captain make it happen....
North Ursalia is offline
Old 12-05-2000, 09:11 AM   #5
RidinLow
Member#: 329
1995 325i
Arctic Gray
Post
Can you tell that something's wrong right before it goes?
RidinLow is offline
Old 12-05-2000, 10:54 AM   #6
Peaty
Techno Sapien
Member#: 449
2016 BRZ Limited
Ice Silver Metallic
Arrow
Since it happened to NU everytime I check my oil I check the nut to see if it's backing off. So far I haven't had a problem. I may take it off and put some Loc-tite on it though just in case. I don't think there will be a way to tell it's going to fall off short of getting under there and checking though.
Peaty
Peaty is offline
Old 12-05-2000, 11:20 AM   #7
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
92 5MT SVX
Post
No way to tell... one minute, it was on ok and working fine, the next shift went "CLUNK." The nut must have fallen off somewhere before, and the bushings and the plate held it on for a bit, but again ****CLUNK****** Car still shifted I found out, but very messily. I ended up making a bushing out of a block of wood, used a door striker plate for a plate, and a hose clamp as a 'nut' (I couldn't find ANY nut to fit that stud...not in a hurry anyway). Call me McGuyver, but it worked until the dealer got the parts in!
Brian
You and the Captain make it happen!
Old 12-06-2000, 12:39 AM   #8
Member#: 67
1999 Outlasting
the competition.
Post
for 35.00 shipped i can send you a kartboy kustoms shifter bushing set.
[email protected]
tom@kartboy is offline
Old 12-06-2000, 01:34 AM   #9
Big Tee
Member#: 1802
1998 Impreza RS2.5
Post
Here's something that'll work as a 'bandaid' fix, coat the visible threads outside the nut with RTV silicon. When dried, it'll keep the nut from vibrating off, but will not prevent its removal when you use a wrench. We used to call it 'poor man's safety wire'
Big Tee is offline
HTML code is On
Any interest in Cusco shifter bushings? J Colman Mid Atlantic Impreza Club -- MAIC 4 05-03-2002 04:10 PM
kartboy vs cusco shifter bushings blubaru Transmission (AT/MT) & Driveline 15 03-12-2002 11:38 PM
Cusco shifter bushing instructions? Steven Saunders Transmission (AT/MT) & Driveline 1 01-25-2002 11:50 AM
Cusco Shifter Bushings..... Bankheist Texas Impreza Club Forum -- TXIC 20 10-17-2001 11:15 PM
FS: CUSCO shifter bushings Strepto Rocky Mountains Impreza Club Forum -- RMIC 2 04-08-2001 12:54 AM
