Notices
Old 11-13-2000, 01:49 PM   #1
ZKRAZY
Member#: 2907
Post LSD Diff specs
Hi,
I own a Datsun 240Z and I recently found out that Subaru diffs are an almost direct swap for the Z's. Can anyone tell me what models came with the Limited Slip diff, and what ratio's they have? I'm looking to get into racing and a variety of ratio's would help. How much can I expect to pay for a diff in a wrecking yard?
This is a cool site, lots of info for a spec junkie.
Thanks,
Anthony
ZKRAZY is offline
Old 11-13-2000, 02:08 PM   #2
Reiflex
Member#: 774
2000 2.5RS
Silverthorn
Post
For info about the Subaru LSD check here :
http://www.subaru.com/frame_main.htm...html&start=awd
As far as I know LSD are in MY00 and up.
--Reiflex
ImprezaRacing
Reiflex is offline
Old 11-13-2000, 02:22 PM   #3
ZKRAZY
Member#: 2907
Post
Thanks Reiflex. Unfortunatly I did see that already. I can probably find an LSD pretty easy, I'm pretty sure the RS has it, and other models like the Outback and such that have all the options.
What I really need is the drive ratio. Also, how much torque and HP has been put through the stock diffs?
Thanks
Anthony
ZKRAZY is offline
Old 11-13-2000, 02:26 PM   #4
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
Post
The 2.5RS uses a Hitachi R160 rear differential. It can be easily upgraded to an R180, and not so easily to an R200.
The 5spd uses a 4.11:1 gear ratio and the automatic has a 4.44:1. You must ensure that the rear diff ratio is matched with the front (contained within the transmission) or the center differential will seize... so if you're changing from those stock ratios, make sure to change the front diff too.
ColinL is offline
Old 11-13-2000, 04:30 PM   #5
XT6Wagon
Member#: 524
04 STi
Post
Ok Subaru didn't put ANY rear LSDs in the 95-99 cars. In 2000 They put them in the Outback limited, the Forester S, and the 2.5RS. I THINK the Legacy GT got it in the limited version also.
Before that there is the clutch type in the 85-90 SOHC cars, but they are mostly found on turbos, and few are still unclaimed.
The 91-94 Legacy Turbo had a vicous style rear LSD, but these are RARE.
XT6Wagon is offline
Old 11-13-2000, 04:42 PM   #6
Travis R
Member#: 153
'07 Mazda CX-7, '91
BMW 535i & '06 Ninja 650R
Post
I'm not sure that anyone has reached the level of power to make the rear diff fail. That's not to say they aren't wearing out really quickly, but I've never heard of some one blowing the rear diff on a hard launch or anything (including the guys running high boost). But these cars are also AWD so not all the power is going through the rear diff.
There are a couple guys here with old Z's, so hopefully they'll chime in and give you a hand.
Good luck
Travis R is offline
Old 11-14-2000, 10:57 AM   #7
ZKRAZY
Member#: 2907
Post
Is the rear diff in the 2.5RS a limited slip? Only for 99-2000MY's? Are there any LSD R180's in Subaru's? If it's easily upgraded to an R180 (which the 240Z has) then where or what car to do I get one (a limited slip in 4.11:1 ratio).
Thanks for the info already given.
Anthony
[This message has been edited by ZKRAZY (edited November 14, 2000).]
ZKRAZY is offline
Old 11-14-2000, 11:03 AM   #8
ColinL
Member#: 114
'03 Evo, Rice White
'01 Erion CBR 929
Post
The 00-up 2.5RS has a viscous coupling LSD, and so does the 01 Forester S and Legacy GT.
ColinL is offline
HTML code is On
LSD assembly into an non LSD diff housing GrundleJuice Transmission (AT/MT) & Driveline 24 06-02-2009 06:43 PM
anyone know how to put a lsd diff in my 95 impreza turbocolin Subaru Conversions 11 09-20-2004 10:06 PM
Newb 2.5rs drivetrain questions. Clutch, LSD, Diffs... cwb124 Transmission (AT/MT) & Driveline 2 12-07-2003 06:55 PM
Can the rear LSD diff from 03 WRX be used on a 03 RS 2.5? key master Transmission (AT/MT) & Driveline 12 10-29-2002 03:36 PM
F/S: Legacy auto LSD diff and sway bars rrubel Legacy Forum 13 10-25-2001 08:03 PM
