Old 09-01-2003, 03:50 AM   #1
dingo dave
Member#: 33177
2000 Impreza RS coup
white
Default Should i change tranny fluid if everything shifts fine?
I got my RS with 48K and now it sits at 54K. I am not sure if the transmission fluid has ever been changed or not. It's quite possible that it hasn't.
I seem to be shifting with no problem so i am hesitant to change tranny oil over to synthetic or if i even need to change it at all if everything seems to be fine. I have read stories where changing over tho synthetic in the gear box has created problems rahter than prevented them.
At the least i suppose i should stick some new dyno gear oil in there.
any thoughts?
dingo dave is offline   Reply With Quote
Old 09-01-2003, 08:20 AM   #2
tmat3
Member#: 2817
2001 Impreza 2.5RS
BRP
I would change it. Even though it may shift fine and probably will shift fine for a long while, it's always a good idea to change all fluids at recommended interval. If you're not sure when it was done, replace it.
tmat3 is offline   Reply With Quote
Old 09-01-2003, 10:06 PM   #3
VSG
Member#: 19435
I'm at that stage also. Bought my car used and am at about 55k miles. I plan to change all the fluids soon.
Should I use Synthetic tranny oil or go stick with reg oil? Any threads or pages for or against Synthetic?
thanks
-Mike
VSG is offline   Reply With Quote
Old 09-02-2003, 01:06 PM   #4
thng
Member#: 8062
I did this with every automatic I ever had. Synthetic is pretty much up to you. GM uses synthetic in most of their modern day models. I, more then likely, would switch to synthetix. But, my purpose here is to suggest an external tranny cooler in combination with the cooler in the radiator. I don't know how subaru feels about having a tranny cooler and is quite likely that they will use the presence of a tranny cooler to deny any warranty coverage.
I put them on my cars because I know I'm quite hard on my cars; either intentionally or not. Sometimes I sit in traffic for long periods with the engine at idle with the AC on full blast. If had gotten an automatic in my wrx then I would have put on a tranny cooler and routed the fluid to pass the cooler before going into the radiator. If the cooler makes it too cold then the radiator will bring it up to proper temp.
Just my POV.
thng is offline   Reply With Quote
Changed tranny fluid at 9K, it is noticibly darker than new fluid. Please help! 4EAT Obsessive Transmission (AT/MT) & Driveline 4 07-07-2010 12:04 AM
Shifting probs after dealer changed tranny fluid... help... fish_antlers Transmission (AT/MT) & Driveline 16 06-24-2008 12:38 PM
changing tranny fluid and differential fluid for first time Durmiente Transmission (AT/MT) & Driveline 16 05-23-2007 02:06 PM
changing Tranny Fluid goose Newbies & FAQs 3 05-16-2001 12:10 AM
