Old 09-01-2003, 09:33 AM   #1
poison
Member#: 37678
Default Spun out this morning! (Or, How to correct understeer w/ tire pressure)
On my way to work (I know, Labor day) 5:45 AM, headed down Sunset Bl in Beverly Hills. All the sprinklers are on in the median divide; the road is fully wet. I take the left onto Foothill through the running water on the road at 50 like I do every morning...
Now I need to tell you that I have been looking to reduce the understeer on my TS. I installed a 17mm RSB off a WRX wagon, and a couple days ago I found the thread about tire pressures and how to tweak them to modify oversteer/understeer. Two days ago I put 34F and 39R (just for fun!).
...I start to straighten the wheel, but ? what's that ? I hear tires squealing and feel my rear sliding out and around. A lot. Counter steer, hit the gas. There's a parked car on the opposite side, it's not a wide street. F-it. I hit the brake and slide to a stop in the middle of the road.
I can't keep the smile off my face! Blessed oversteer! Now I know 1) tweaking tire pressures works in a not-so-subtle way, and 2) Be a little more progressive when trying out new mods.
I can't wait until it rains here, good for practice.
poison is offline   Reply With Quote
Old 09-01-2003, 09:17 PM   #2
Turbo X
Member#: 26249
02 Impreza WRX
Be sure you practice on a open parkin lot or something.
Turbo X is offline   Reply With Quote
Old 09-02-2003, 06:01 PM   #3
fuzzycuffs
Member#: 32309
2003 Silver WRX
Who needs a car in Tokyo?
Practice in between big and little Santa Monica where they are doing all that construction. I'm convinced they're building a rally course just for me.
fuzzycuffs is offline   Reply With Quote
Old 09-02-2003, 09:30 PM   #4
mauahah
Member#: 28827
04 STi
i think u might want to review your methods of correcting oversteer??? I learned at driving school to correct oversteer by lifting the gas slightly and not braking. Braking or over correcting will cause the back end of the car to slingshot in the other direction and cause u to loose control of the car and possibly spin in the other direction. Just a word of advice, but make sure to stick to things your comfortable doing. I curbed my rs pretty bad doing stuff like that in the rain.
mauahah is offline   Reply With Quote
Old 09-03-2003, 01:14 AM   #5
biggreen96
Member#: 12535
vf39 06 5MT XT
92 Legacy Rally EG33'd
4wd car + oversteer = floor it.
everybody whos pushed their suby at autoX and other places knows this.
biggreen96 is offline   Reply With Quote
Old 09-03-2003, 02:11 AM   #6
eastcoastbumps
Member#: 29201
BMW M3
Honda S2000x2
I did this one morning on a snow packed road. I was making a left turn and started getting sideways. I stayed on the gas and started putting the car straight but went a little too far. So now I'm pointing right and trying to go left. I cut again and spin the car to the left and up onto a snow bank. It gave my passenger the scare of his life. I then put it in reverse and backed down off of the 3ft snowbank. I had more fun in those few seconds than I did in the whole day of skiing.
Pete
eastcoastbumps is offline   Reply With Quote
Old 09-03-2003, 11:50 AM   #7
gregsatt
Member#: 38536
'02 WRX Wagon
FreeRentMoney.com White
So...did you add the sway bar AND mess with the tire pressure? I thought the sway bar alone would have helped out with the understeer. Did you experiment with the sway bar first then with the tire pressure.
I am about to put a stock WRX sedan sway bar on my WRX wagon to help out with the understeer. I'll try the tire pressure trick before I put the sway bar on to see what happens.
gregsatt is offline   Reply With Quote
So i went to the emergency room this morning or OMG socialist medicine SQ3.0dotJP Political Playground 293 08-16-2009 05:56 PM
Is it boost speak or creep, how to correct it? flyinghighlm Newbies & FAQs 9 10-20-2007 08:19 AM
How to correct AVI's when the sound/audio are out of sync? Sephro Off-Topic 4 08-06-2007 08:08 PM
Correct hand position, or how to not miss a shift Capt Crunch Newbies & FAQs 9 03-21-2003 02:51 PM
Any way to correct understeer? Imprezard Forester Forum 5 06-30-2001 06:59 PM
