Notices
Old 09-01-2003, 11:22 AM   #1
Shifter
Member#: 3728
Have a Nice Day? Silly Mistake
In error I put about 3 ozs of brake fluid into my manuel transmission..Yea, I know it was a dumb error..Will this completely screw up the manual trans?? Yes I know the owners manuel calls for GL5 80w oil..
Shifter is offline   Reply With Quote
Old 09-01-2003, 12:02 PM   #2
Flexy
Member#: 34028
2000 Legacy GT
Titanium
I am pretty sure you wan't have any moisture in there.
HAVE IT FLUSHED LIKE 2-3 TIMES OR REALLY GOOD FLUSH WITH SOME KIND OF FLUID THEY USE IN GARAGE!!!!!!!!!
TRY NOT TO DRIVE ON IT. GET TOWING TRUCK!!!
Flexy is offline   Reply With Quote
Old 09-01-2003, 11:19 PM   #3
esteve
Member#: 28716
2006 STI
Hey, we've all done some dumb things before.
I don't think 3 oz is going to hurt anything, but I'd drain the tranny and with a suction gun keep spraying the insides as best as possible letting it drain out, and then fill it up again.
esteve is offline   Reply With Quote
Old 09-02-2003, 04:37 AM   #4
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
Dood...You need a Valium...Quick.
Shifter----
3oz. shouldn't cause any problems. Drain/re-fil your trans when you get a chance if you don't feel right about it.
3.7qt=~120oz.....3oz out of 120, unless it was battery acid or lye, shouldn't be any problem.
Old 09-02-2003, 01:20 PM   #5
thng
Member#: 8062
Brake fluid is water soluble and therefore shouldn't mix well with lubricant anyway. It'll want to stay on the bottom of the case. I would do a simple drain/fill sequence. If it does bother you I'd probably dump maybe a couple of quarts of ATF (this flows easier than 80W or 90W) and try to rinse out any remaining fluid.
But on the whole, the 3 ox should bother anything seriously. I'd just do the drain and fill and that should cure your nerves. Then take 2 aspirins and call your local porn store in the morning.
thng is offline   Reply With Quote
Silly question from a silly man STINOMORMONEY Newbies & FAQs 15 04-11-2009 12:44 PM
silly mistake tora Vancouver Impreza Club Forum -- VIC 37 01-11-2007 01:09 AM
Silly package deals...Silly!! NinosAutoAccesories Vendor 'For Sale' Classifieds 94 03-25-2004 08:23 AM
This will make silly season in the WRC very silly, indeed! Coati Motorsports 19 05-31-2003 07:00 PM
Silly silly question... A newbie obviously ScoobyEnthused Transmission (AT/MT) & Driveline 6 06-21-2002 05:58 PM
