Old 09-01-2003, 09:44 PM   #1
jblaine
Member Sales Rating: (36)
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Default Perrin Catch Can
Full thread is here
jblaine is offline   Reply With Quote
Old 11-05-2003, 04:18 PM   #2
thesmokingman
Member Sales Rating: (5)
Member#: 17751
2002 WRX Wagon
944 Turbo track
The Perrin Can is a POS.
I wasted 90 bucks on a 4" dia silicone hose, a pair of billet end caps, and misc pieces.
The instructions on the installation barely work for a 5spd car which makes it highly suspect to begin with. I have a 4eat, which made any installation remotely resembling the 5spd impossible.
I had to totally re-engineer the damn thing to get it to fit. I cut off like 3" off the hose, then used the otherwise useless supplied bracket to mount it to my throttle linkage. I had to reshape and grind the bracket in order for it to work. I'll post pics soon as I can, to share with the other 4eat owners.
But if you comtemplating this can, I suggest something else. After this install, I am highly suspect of ever buying another Perrin product.
thesmokingman is offline   Reply With Quote
Old 11-11-2003, 09:16 PM   #3
links_courses
Member#: 42207
2004 WRX Sedan
PartyPoker Fiend
FYI: I installed the Perrin Catch Can in my 2004 WRX with NO PROBLEMS. The directions from World One Performance were included and were easy to follow. I also did not need to remove the coolant reservoir, but it would have been easier if I did.
I suggest loosening the battery straps and pushing back the battery. Also, orientate the catch can bottom strap screw so that the head points toward the engine and not the sidewall. Then you can easily use a long screwdriver to twist it tight.
The red can and hoses look cool in my red WRX, and it does seem to be catching some blow-by.
Too expensive but works well and fits perfectly!
links_courses is offline   Reply With Quote
Old 11-15-2003, 04:50 PM   #4
supermarkus
Member Sales Rating: (13)
Member#: 6971
2008 WRX STi
SSM
Same here, mine works well, definitely less blowby. But fit was different for me since I'm using Morettes, they made fitting very simple.
supermarkus is offline   Reply With Quote
Old 04-02-2004, 04:31 PM   #5
SQC 155
Member#: 52622
2002 WRX stage IV...
Silver and now wrecked :(
Waste of Money; had mine forevrer and it never caught a drop of oil.
SQC 155 is offline   Reply With Quote
Old 04-02-2004, 04:35 PM   #6
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
I'll second that now after 4 months. The site tube remains empty. I'm going to remove it and examine the insides. Will likely replace the hose I cut for the install and leave it out of my car.
Old 04-02-2004, 04:36 PM   #7
SQC 155
Member#: 52622
I keep it in there for looks
Old 04-06-2004, 10:26 PM   #8
WRXSuby43
Member#: 59002
2004 Subaru STi
Thanks for the info guys, you just saved me a good amount of money!
WRXSuby43 is offline   Reply With Quote
Old 04-10-2004, 09:30 AM   #9
WRX 2002
Member Sales Rating: (14)
Member#: 11211
2004 STi
Rally Blue
Probably only needed if you track the car.
WRX 2002 is offline   Reply With Quote
Old 04-12-2004, 09:49 PM   #10
tm999xxx
Member Sales Rating: (3)
Member#: 34408
07 Spec B
SoapBox?
I took one off a car (sti)last week because he was going back to stock and there was a good 1/4inch in the bottom. I was pretty surprised. Now its on my car
tm999xxx is offline   Reply With Quote
Old 04-29-2004, 07:15 PM   #11
murrdogg24
Member Sales Rating: (44)
Member#: 50586
04 WRX
Flappy bird edition
mine catches a lot of crap but I drive like a bat out of hell!
murrdogg24 is offline   Reply With Quote
Old 05-04-2004, 03:19 PM   #12
wrxblue04
Member#: 60843
2004 WRX
I bought a Red one yesterday for my 04 WRX, Plan on installing in a few weeks along with my Defi Boost gauge and Oil pressure gauge, Radiator Shroud I'm guessing will only take a few mins
wrxblue04 is offline   Reply With Quote
Old 05-25-2004, 01:32 PM   #13
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
I finally got around to checking it out.
There's a 0.005mm coating of oil on the bottom (inside) after a hard 6000 miles (WOT to near redline every day in 2nd and 3rd at 16-17psi).
I double checked the bottom (outside) for any oil film or runoff and checked all underneath the can for any sign of leakage. The hose clamp is plenty tight and there's not a single sign of any oil outside the can on the bottom.
I can only deduce that this is very very near worthless for my car.
Also, given the amount of suction I feel from the hose at part throttle (out of gear), I wouldn't be surprised at all if anything put into the can is being sucked right back out. Stupid design. There needs to be a chamber inside it that lets the oil film run down through a center hole/drain and not get sucked back out. Or something...
Old 05-25-2004, 04:50 PM   #14
tm999xxx
Member#: 34408
07 Spec B
SoapBox?
Mine is now almost half full....Go figure
Old 05-25-2004, 04:55 PM   #15
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
I don't get it.
Old 12-30-2008, 05:27 PM   #16
T-WRX2002
Member#: 190191
2008 WRX STi Limited
World Rally Blue Mica
Originally Posted by jblaine View Post
I don't get it.
what dont you get?
T-WRX2002 is online now   Reply With Quote
Old 12-30-2008, 05:42 PM   #17
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
I don't get why you resurrected a thread from 2004.
Old 10-01-2009, 01:48 PM   #18
bannerd
Member#: 110771
2006 WRX
black
I have a Perrin catch can and it it's worthless. Drove for 2 years and not a single drop of oil. The design of it really has no way for the oil to actually get caught. When the motor is running the lines are way to close that it just sucks the oil back into the intake. I finally decided to do something about it, I bought a plastic pond filter and cut it in some what of a X shape. The bad air goes into the can and the oil sticks to the plastic (sweats kind of) and then the good air goes back into the intake. After doing this I noticed good results. I wouldn't use foam... it will fall apart really quick, has to be plastic or a more durable material.
bannerd is offline   Reply With Quote
wrx sti cheap parts! or best offer! perrin inlet, perrin catch can and stock box krytikel Engine/Power/Exhaust 4 11-23-2009 01:37 PM
fs: perrin catch can,perrin intake, axleback luvinboost Engine/Power/Exhaust 4 12-14-2007 08:40 AM
WTT: Cusco catch can for a perrin catch can sti charles Engine/Power/Exhaust 10 11-29-2007 01:04 AM
Perrin Catch Cans and IC hoses in almost every color in stock, but not for long! WorldOne Vendor 'For Sale' Classifieds 75 11-14-2003 01:31 AM
Perrin Catch can fitment Jsunn Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 08-07-2003 06:17 PM
