Old 12-04-2000, 02:15 PM   #1
Bassem
Member#: 305
Post Speedo correction
is there a straightforward way to correct the speedo/mileage if you ise non-stock rolling diameter?
I'm asking, because i'm running the 18" p1 wheel/tire now, which are about 2.7% different in radius (and circumference) than the stock wheel/tire combo. i guess the difference is not all that whopping, but i was thinking, would a uk spec pickup help, or is it an ecu issue and i'm sol?
thanks,
bassem
Bassem is offline
Old 12-04-2000, 08:00 PM   #2
wac
Member#: 689
2005 Outback 2.5 XT
Champagne Gold Opal
Post
As far as I know, it's a speed sensor issue rather than an ECU issue. The speed sensor sends a small sine wave to the speedo. Then the speedo converts it to run the needle and also sends a square wave version to the ECU.
A'PEXi sells a Rev/Speed meter http://www.apexi-usa.com/revspeedmeter.htm that can correct for wheel sizing. However, I think your speedo will still be off, since it is meant to be installed at the ECU and not the speed sensor.
Hope this helps,
-WaC
Wayne
wac is offline
Old 12-04-2000, 08:13 PM   #3
tulit
Member#: 338
09 STi
Post
I did a bit of experimenting with modifying the speed sensor signal to compensate for these errors. It works, but is somewhat complex and cumbersome.
I think it would be more effective to just modify the signal from the ECU to your dash unit.
tulit is offline
Old 12-04-2000, 08:14 PM   #4
tulit
Member#: 338
09 STi
Post
oops.
i forgot to get to my actual point.
The answer to your question is NO, at least not easily
tulit is offline
Old 12-05-2000, 06:09 AM   #5
Bassem
Member#: 305
Post
well tulit, dont mean to be annoying...but what modifications can i do to the signal from the ecu?
thanks,
bassem
Bassem is offline
HTML code is On
04 STI- Tach and Speedo not reading correct please help intpostman23 Electrical & Lighting 3 04-01-2007 07:55 PM
Speedo corrections needed? 6MT into 02 WRX corey_dyck Transmission (AT/MT) & Driveline 3 03-17-2006 08:58 AM
Help:no boost and rev limit, looking for correct speedo V reading/other suggestions agterlik Subaru Conversions 9 04-15-2005 12:34 PM
If you go with JDM 6MT + 4.444 ratio, what about speedo correction? casualsurfer Transmission (AT/MT) & Driveline 4 01-11-2005 02:11 PM
