Welcome to the North American Subaru Impreza Owners Club Sunday March 29, 2015
Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds
Old 09-02-2003, 12:56 PM   #1
AllSubaru.com
Vendor
Vendor Sales Rating: (0)
Member#: 19819
Exclamation ALL MRT Products on CLEARANCE!! Everything will go!! must go!!
Allsubaru.com has decided to discontinue our a good bit of our line of MRT related products - we're closing out on a ton of MRT items in stock - and we will no longer be accepting orders or placing orders for special ordered items which we do not have in stock......
thus - we are reducing the prices on ALL in stock MRT items. - prices reduced 30-75% on most items!!
items are no longer listed on allsubaru.com - to order you must either send paypal or phone in a credit card order
we have TONS of items in stock that we need to move!
contact me for more info on any of these items
here is just a sample of misc product....
MRT Top mount intercooler: sale price $925.00 SHIPPED (reg price $1100 + shipping)
description: Replacement top mount intercooler. Fits original factory mounts. Bar & plate design core for more efficient cooling - 15 inch (40mm) x 8 inch (205mm) x 4 1/2 (115 mm) thick. Hand fabricated alloy end tanks. Dual entry type. 90 elbow for attaching BOV either OE factory unit or aftermarket. Looks great and is extremely well made. (Not cast tanks!) Also includes high flow high pressure silicon inlet kit, to connect from turbo to intercooler. This replaces the factory plastic kit that can split under high boost or high temps. Easy fitting. approx 30 mins. NOTE top Bonnet / hood rubber seal needs to be trimmed or removed to allow added thickness. Best used with replacement top STi replica (larger) hood / bonnet scoop
photo:http://www.mrtrally.com.au/shop/imag...s/suwe126h.jpg
_______________________________________________
MRT exhausts: quantites limited - NO MRT gaskets available
1 - 031TA - $400 (Reg price $499)
2002 - onwards Impreza Turbo rear muffler
MRT Performance high quality Rear muffler bolts onto original exhaust without modification. Free flowing unit provides an increase in performance and a sportier sound. (Not loud!) Comes with 3" polished stainless steel tip
1 - 031TB - 2" twin tip version of 031TA - $500.00 (Reg price $699)
1 - 031TS - $375.00 - 4" stainless steel (reg price $500)
WRX/02- Impreza 3" inlet - 4" outlet - stainless steel
MRT Uppipe with flex joint: [i]2 - $325.00 - (reg price 449.95)
MRT Ram Pod Trumpet setup: 2 - $165.00 (reg price $219.95)
Suitable for 02 - onwards Subaru Impreza WRX and STi turbo models. Comes with foam element, support cage, alloy trumpet, bolt in bracket and complete fitting kit. Produces deep induction noise, improves throttle response and overall engine performance. Absolutely no modifications or drilling required for fitting. Suitable for road, race and rally
Blow off Valves: Go Fast Bits - 155.00 shipped
Hybrid - BLOW OFF VALVE HYBRID 01-ON WRX
Blow off valve to suit 2002 onwards, Impreza WRX and STi. (GD and GG models) Kit includes all parts to bolt directly to OE intercooler as well as custom bolt up flange to fit return hose. Unique design allows both venting to atmosphere to give that unique whoosh noise as well as part venting back to inlet to stop over fuelling and poor idle. (normally associated with externally venting BOV's) Non adjustable.
BLOW OFF VALVE ENTRY LEVEL WRX $95.00 shipped
Offers a very inexpensive entry for aftermarket BOV's still with great style, efficiency and quality. See notes on MRT main web page for externally venting valves if you choose to fit this to a car that has an AFM or AMM. OR see plumb back or Hybrid. Will fit 98 - 01 with bolt on BOV (requires flange adapter pipe see part#musse129g1) Adapter Included in this offer.
MRT 2002/2003 WRX Replica fog light covers:
*unpainted - fiberglass replicas - ready to fit*
*Solid 2002-2003 WRX/impreza - $85.00
*Version 4 Impreza (one set, no hardware) - sold out
Turbo Timer: TIMER Turbo BLITZ FATT Mk 2
$159.00 (reg priced $219.95)
High quality turbo timer with increased options and LCD display. Can be set to 1-10 minute run ons. Assembly with programmable pre-sets. Automatically calculates cool down time based on boost pressures in automatic mode. Programable pre-sets. Auto on feature. Voltage monitors warning for adjustable high and low settings.
photo: http://www.mrtrally.com.au/shop/imag...ts/mcb800e.jpg
Water Spray Kit: now $205.00 (reg price $299.00)
Carbon Fiber Battery Cover: sold out
Impreza RS Vent Scoop: 1 in stock - alloy - $123.00 - (reg price $165.95)
description: Suits turbo Impreza Ver 4,5,6 Bonnet only. Cast alloy scoop replaces drivers side bonnet vent to direct cold air into intake. Great with pod filters.
Brake Master Cylinder Support Bracket: sold out
Boost Control kits & Boost Cut Defender -
Boost control kit - sold out
BOOST CONTROL TMS-3KIT TT+DIG DISP - sold out
Boost cut defender: sold out
Some suspension bits:
Anti Lift Kits from Whiteline:
KCA362 - Comfort kit - 2002/03 WRX/impreza - sold out
KCA319A - Sport Kit - Legacy/93-2001 Impreza - sold out
KCA361 (6) - comfort kit - Legacy/93-2001 Impreza - $115.00
WRX STi rear strut tops: 1 set in stock - $95 EACH side - 190.00
STi Replica Front Strut Brace: 2 in stock - $75.00
Adjustable (Whiteline) Rear Control Arms - Sedan: 1 set in stock KTA109 - $210.00 (reg price 239.95)
other items include: (- all GREATLY reduced)
STi badges, Type RA badges
*Camber bolts... - $42 per pair 14mm (Qty 2 pairs) = One set left
*Subframe bolts - sold out
*steering rack bushings - GC body only!sold out
*Rear Diff Lock Bushing support Kit sold out
***added 9/4/2003***
Whiteline Heavy Duty Front End links - steel
fits 1993-2001 Impreza/Legacy AND
2002-2003 Subaru WRX WAGON ONLY....
sold out
ALLOY front end links:
WRX Sedan - Impreza 2002/2003 - $75.00
*I/C Water Spray Dash Switch - $35 shipped
*STi I/C Water Spray Nozzles - $14 each (shipped)[/b]
Short Shift - MRT - Impreza 1998-2001 - $55
Shortens throw between gears by approximately 30% for fast race style gear changing.
AUTOMeter Gauges - Boost - 52mm and 67mm
Your choice - $60 each
we have lots more...
let me know what you are looking for!
contact:
info@allsubaru.com
jamie@subiegal.com
800.426.1332 x161
or pm me here...
thanks! let's get this stuff moved!!!
jamie
www.allsubaru.com
AllSubaru.com is offline
Old 09-02-2003, 01:13 PM   #2
calworld
Member Sales Rating: (1)
Member#: 5711
2004 STI
Got a pic of the carbon fiber battery cover?
calworld is offline
Old 09-02-2003, 01:15 PM   #3
AllSubaru.com
Vendor
Member#: 19819
INFO from MRT's site:
COVER BATTERY CARBON PRNT 93-2001
Dress up your engine bay with this great looking battery cover. Custom made to shape to suit all Impreza's Ver 1 2 3 4 5 6 1993 - 2001 - Specially printed carbon fibre with polished finish. (Not adhesive or laminated like others) Pre-drilled for OE battery terminals. (requires 2 M6 nuts and washers to fit)
cheers
Jamie
Old 09-02-2003, 01:34 PM   #4
AllSubaru.com
Vendor
Member#: 19819
adding MORE product:
WRX - Impreza 2002/2003 - $75.00
2001 - older Impreza - $75.00
Old 09-02-2003, 02:11 PM   #5
Hank3
Member Sales Rating: (22)
Member#: 16157
'03 Mazda P5 <><
'02 WRX & '08 MS3 SOLD!!!
emaild ya Jamie
Hank3 is offline
Old 09-02-2003, 02:19 PM   #6
AllSubaru.com
Vendor
Member#: 19819
Originally posted by Hank3
emaild ya Jamie
emailed ya back
Jamie
Old 09-02-2003, 02:49 PM   #7
Kwyjibo
Member Sales Rating: (8)
Member#: 17851
2003 WRX
R.I.P. 7.27.2005
sending you email too
Kwyjibo is offline
Old 09-02-2003, 03:05 PM   #8
Scooby Blue
Member#: 12112
MY00 RS
Whay kind of parts for GCs? More info on these please:
are these for the WRX?
Also the STB are they the Whitelines? are you discontinuing those too? And how much for the camber bolts and subframe bolts? Thanks!
-jason
Scooby Blue is offline
Old 09-02-2003, 03:18 PM   #9
2000KSzRS
Member#: 6372
2004 STI
Default Water spray?
What's included? Is this the auto or manual kit?
2000KSzRS is offline
Old 09-02-2003, 03:42 PM   #10
4evryng
Member#: 31116
2003 WRX Shag Wag
Larry, Kiss Our Apps!
PM'd you Jamie
4evryng is offline
Old 09-02-2003, 04:57 PM   #11
AllSubaru.com
Vendor
Member#: 19819
-jason
hola...
here are some answers
14mm in stock
Subframe bolts - $14.00
steering rack bushings - GC body only! - $11.00
Rear Diff Lock Kit - $16.00
The STi replica strut bar is only for 2002 - on WRX/Impreza
non whiteline item
let me know if there are more questions.
i'll try to answer them as quickly as i can....
i have a LOT of stuff to go through
Jamie
Old 09-02-2003, 06:13 PM   #12
munkis
Member Sales Rating: (5)
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
mmmmm low prices
pm'ed ya @ allsubaru.com... I think...
LOL
well ya got a pm from me somewhere.
Jay
munkis is offline
Old 09-02-2003, 06:37 PM   #13
luv2xlr8
Member#: 42647
2002 wrx
PM'ed you!!!
luv2xlr8 is offline
Old 09-02-2003, 07:14 PM   #14
AllSubaru.com
Vendor
Member#: 19819
working on PM's and emails now
hey i'm quick... but not THAT quick
ill try to keep up as best i can
thank you for your patience
Old 09-02-2003, 07:34 PM   #15
etam
Member#: 439
www
Jamie, do you happen to have rear adjustable sway bar for 97 Legacy?
etam is offline
Old 09-02-2003, 08:29 PM   #16
spiralsmurf
Member Sales Rating: (35)
Member#: 16085
2005 STi
can you do the rear diff bushing, subframe bolts, and steering bushings for $45 shipped?
spiralsmurf is offline
Old 09-02-2003, 10:37 PM   #17
ChuckCheeze
Member#: 8143
2002 WRX ex-owner
WR Blue
emailed ya
ChuckCheeze is offline
Old 09-02-2003, 11:14 PM   #18
Hondaslayer
think you
Member Sales Rating: (11)
Member#: 4562
1995 Legacy LSi
1998 Forester, lifted.
Jamie
1 set of steering rack bushings
1 brake master cylinder bracket (is it for GC?)
1 Diff lock kit (what is it?)
regardless,as long as its for GC I will buy those.What time are you open until? Or can I order by fax?
Ben,
PS thanks for the spats,My car looks better than before!
Hondaslayer is offline
Old 09-02-2003, 11:46 PM   #19
wr wagon
Member#: 25429
2002 Impreza WRX Wag
WR Blue
Jamie
emailed you at subiegal.
wr wagon is offline
Old 09-03-2003, 12:45 AM   #20
Webster
Member#: 20082
1999 impreza rs 2.5
black diamond pearl
pm'ed / emailed you jamie....
Webster is offline
Old 09-03-2003, 02:33 AM   #21
imprezaboi
Member#: 7382
MY01 GC8 - 4
BRP
pm'ed you
imprezaboi is online now
Old 09-03-2003, 08:38 AM   #22
Edvig
Member Sales Rating: (6)
Member#: 16147
no more turbo
05 Legacy, 11 Outback
Hi Jamie...which endlinks are these.
Do you have a pic?
Thanks, Edvig
Edvig is offline
Old 09-03-2003, 11:48 AM   #23
AllSubaru.com
Vendor
Member#: 19819
i have one in stock
rear sway - 18-22mm adjustable 125.95 (reg price 139.95)
shipping is additional
let me know if i can assist.
sounds fair enough
*Allsubaru.com pm's are answered
*working on emails next
photo of the alloy end links:
similar to as seen here FRONTS ONLY! :
[img]//www.mrtrally.com.au/shop/images/products/muss126an.jpg[/img]
thank you
Jamie
Old 09-03-2003, 11:59 AM   #24
AllSubaru.com
Vendor
Member#: 19819
1 set of steering rack bushings - $11
1 brake master cylinder bracket (is it for GC?) -
yes it's for all impreza! - $40
1 subframe lock kit (what is it?) - Locks subframe for alignment control / Impreza/WRX/STi - $16
>>regardless,as long as its for GC I will buy those.What time are you open until? Or can I order by fax?<<
I am here until 4:30pm
today... and tomorrow... friday i am off racing.
you can order via fax
pm/email me for details.
thank you
Jamie
you're welcome
Old 09-03-2003, 01:21 PM   #25
Gspot
Member#: 30350
02 WRX
#900 STX
Nasioc discount on Prodrive shift knobs?
Gspot is offline
VOLK CLEARANCE - EVERYTHING MUST GO! RE's, CE's, and TE's ON SALE NOW!! DriveLineSales Wheels/Tires 32 01-30-2009 07:36 AM
Clearance! Clearance! Everything Must Go! Fizz Autosports Wheels/Tires 52 01-24-2009 07:45 PM
Clearance! Clearance! Everything Must Go! Fizz Autosports MWSOC Vendor Classifieds 0 12-23-2008 05:03 PM
Inventory clearance...Everything must go!!! NinosAutoAccesories Tri-State Area Vendor Classifieds 18 10-12-2004 04:29 PM
('93-'01) Huge clearance! Everything must go! live311 Impreza Forum 12 10-01-2002 06:15 PM
