Old 09-02-2003, 10:18 PM   #1
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
Default My EJ205 engine swap is done!!:)
Hey you guys I thought I would let you guys know that I finished my engine swap about two weeks ago. i planned on taking pics in the two weeks that it has been but I have been unable to get a hold of my friends digi-camera. Well I hope to have some picks up for you. If you guys have questions about fitment or certain parts that can be used, let me know. I hope to have pics of my ugly yet quick car up soon.
Thanks, Micah
Old 09-03-2003, 03:13 PM   #2
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Which radiator, hoses, and fans were used? How was the clearance between the radiator fans and the crossover pipe?
-Jon
Old 09-04-2003, 12:04 AM   #3
Homemade WRX
Member#: 33782
96 bastard child
I used the stock 1.8 radiator, hoses and fans. there's not a ton of room between the engine and the fans but I can fit my hand down in there. I'll show you once I take the pictures.
Old 09-04-2003, 03:46 PM   #4
trackattack
Member#: 42836
Homemade WRX- Im looking into swapping an EJ20 into a '99 2.5RS. Can you list for me what I would need to do this(aside from the engine, tranny, wiring harness and ECU).
Did you use a WRX crossmember? I've heard these are needed.
trackattack is offline   Reply With Quote
Old 09-04-2003, 08:18 PM   #5
Homemade WRX
Member#: 33782
96 bastard child
Hi, Yes you do need to swap out the lower front crossmember. You can use either a WRX or Turbo Legacy one. I didn't have to change out my tranny. My stock tranny bolted right up although I am planning on swapping an STI tranny in. You'll need to modify you exhaust most likely. I went ahead and bought the Borla cat back and the stock downpipe. I then had a gap left in the piping (about 2.5-3 ft) and had an exhaust shop patch it up. The mounts didn't line up exactly and needed some coaxing. I went ahead and purchased an ACT clutch kit and installed that. When you are installing and doing all of the wiring be sure to buy the fuel pump controller. It is extremely easy to hook up and keeps your car from killing your gas by running super rich. All in all the only part that needed serious changing (other than the engine duh) was the lower front crossmember.
If you have any other questions feel free to ask, Micah
Old 09-04-2003, 10:48 PM   #6
awd4ever
Member#: 31573
I found the
meaning of life!
how about the dash?
did you have to use wrx dash?
how are you planing on fitting the sti 6 speed into a gc frame? i hear the tranny tunnel is not big enough.
How about the sifter linkage for Sti tranny?
awd4ever is offline   Reply With Quote
Old 09-05-2003, 01:02 AM   #7
Homemade WRX
Member#: 33782
96 bastard child
I used my stock dash and I never said I was using an STI 6-speed tranny. I'm going to be using a 5-speed STI tranny from the UK. There I can get one for any model year I want and I'm looking to get it off of a 96(the last year they made them with mechanical speedometers).
Old 09-05-2003, 01:32 AM   #8
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
FWIW, the 6MT will fit with a little massaging.
-Jon
Old 09-10-2003, 01:59 AM   #9
awd4ever
Member#: 31573
I found the
meaning of life!
-Jon
what the hell does that mean?
what is a "LITTLE MASSAGING"?
will a stock shifter linkage work, or do i need an sti one?
Old 09-10-2003, 02:02 AM   #10
totoherbs
Member#: 7321
.... 122 IggPoints
Work... ahhh... so tired.
No it wont work... and your going to have to do some tunnel work to get it to fit.
Old 09-10-2003, 02:49 AM   #11
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
The 6MT is significantly larger than the 5MT in all aspects. Because of this, some clearancing is needed within the transmission tunnel to get everything to fit properly.
-Jon
Old 09-10-2003, 08:29 AM   #12
mgalvez
Member#: 12495
Congrats man! How does it run? When I sold you the motor I thought it would take you longer than it did to swap it. Did you do the electrical yourself? Good job man!
mgalvez is offline   Reply With Quote
Old 09-10-2003, 11:33 AM   #13
Homemade WRX
Member#: 33782
96 bastard child
yeah It took longer than expected for the non included engine electronic parts to arrive at my house. All in all it was only 45-55 hours of work with occasional interuptions. Why didn't you tell me the engine was from a wrecked car?!!!!
Thanks, Micah
And yes the work was done by a friend and me.
Old 09-11-2003, 06:56 AM   #14
mgalvez
Member#: 12495
I did, it was part of the ebay description!
Old 09-11-2003, 02:32 PM   #15
Homemade WRX
Member#: 33782
96 bastard child
not the listing I read.... I read that thing about 100 times before I bought it. If I knew it was wrecked and didn't include the needed parts to make the car run I wouldn't have bought it for that much.
Old 09-12-2003, 06:17 PM   #16
awd4ever
Member#: 31573
I found the
meaning of life!
bad business...
all though any time you buy an engine on E-BAY or any other auction site you should assume it was from a wreck or the owner abused it.
Old 09-12-2003, 06:33 PM   #17
Homemade WRX
Member#: 33782
96 bastard child
yeah it figures.....shame on me... Oh well it runs.... but the crank apears to have a slight woble
Well now I guess I really should go ahead and build the internals.
Take it easy, Micah
Old 09-12-2003, 07:23 PM   #18
AWJunkies
Member#: 32934
99 2.5RS JDM WRX
Nice job glad to hear about these swaps and people doing them themsleves. Well what boost are you pushign stock around 12? How does it run top end any problems? Be very gentle with the speedo cable I already had to replace that once and trust me not fun car goes crazy without it. Also, trackattack you can get ahold of me I can tell you all that you need and how to do it. I would go with the legacy crossmember for all you guys debating which one to use.
AWJunkies is offline   Reply With Quote
Old 09-12-2003, 08:25 PM   #19
Crawford/I-Speed
Vendor
Member#: 12347
ECU ReProgramming
Dynapack AWD Dyno
Micah,
Nice to job finishing your project. Sorry to hear of your donor motor
Chris
Crawford/I-Speed is offline   Reply With Quote
Old 09-12-2003, 08:49 PM   #20
Homemade WRX
Member#: 33782
96 bastard child
I'm glad I didn't end up selling it to you because that would not look to good on my behalf, also because the car is a ton of fun.
Old 09-12-2003, 08:50 PM   #21
Coati
Member#: 9106
2015 FXT - DGM
2008 STI - Aspen White
Default It may be just fine.
How so? Are you looking at the pulley wobbling? Because you see a some of that wobble on stock, unwrecked WRXs.
Coati is offline   Reply With Quote
Old 09-12-2003, 11:31 PM   #22
Homemade WRX
Member#: 33782
96 bastard child
yeah the pulley wobbles but doesn't appear to be bent or warped in anyway. So does this happen on non-wrecked WRX engines?
Old 09-13-2003, 05:40 AM   #23
scoobynation
Member#: 40487
Default yo
congrat hm wrx!i am truly envious of you well how hard was the wiring...any tips or in depth info you can give me.i have a 95 impreza L awd.i to will want to do this swap.i plan on going with the jdm ej20t from nippon motors.i know about the cross members will need to be swaped and so on.the swap portion wont be to bad but the wiring is what im concerned about.well any info will help.and again congrats!
scoobynation is offline   Reply With Quote
Old 09-13-2003, 01:53 PM   #24
Homemade WRX
Member#: 33782
96 bastard child
The wiring wasn't really that difficult its was just extremely time consuming. If I were you or If I could do this all over again I would transfer the electronics formt the WRX in to my dash and have very few wires to solder.
Old 09-13-2003, 05:48 PM   #25
scoobynation
Member#: 40487
hey man thanks although im not exactly sure what you mean by this.maybe im just being vauge.hmmm could you run that by me one more time...in noob term thanks.
02 5mt swap with ej205 engine swap Gamble_WRX Drivetrain 11 04-01-2010 05:40 PM
My Swap is done, full V.7 JDM STI 04blue-meanie Member's Car Gallery 34 07-11-2006 10:50 PM
Swap is done & Paint is done JeremyRS Member's Car Gallery 61 05-20-2006 01:13 PM
My Engine Swap is Done! Cajual Legacy Forum 46 12-23-2003 03:46 PM
My engine swap is a tight fit??? rickG888 Subaru Conversions 5 10-05-2003 03:08 PM
